Email Camera Snapshot [Solved]
Hi Guys,
I'm trying to convert some of my scripts to dzVents to use the new features introduced with it (like history).
I'm looking for the api to send a camera snapshot by email but it seems to be lacking.
Is someone using that ?
Is this something easy to implement ?
Thanks,
U.
Thanks,
U.
Re: Email Camera Snapshot
Hi SweetPants,
I already send camera snapshots using the api:
/json.htm?type=command¶m=emailcamerasnapshot&camidx='..camIdxs..'&subject='..urlencode(subject)
I just do not find this api in the dzVents implementation.
Regards,
F.
Regards,
F.
Why don't you just useultratoto14 wrote: ↑Thursday 07 September 2017 8:12 Hi SweetPants,
Regards,
F.
domoticz.openURL(url)
You can build up your URL based on
domoticz.settings['Domoticz url']
@BakSeeDaa thanks for the help.
My goal is to enhance dzVents, more than finding a workaround.
I already use my own lua modules to do most of the things.
I was trying to move to dzVents to see its potential.
I solved it by adding in runtime/domoticz.lua:
Maybe @dannybloe will add it in the future.
Thanks again to the helpers.
F.
-- have domoticz send an email with camera snapshot
function self.emailCamera(subject, indexes)
if (indexes == nil or #indexes == 0) then
utils.log('No camera indexes provided', utils.LOG_ERROR)
if (subject == nil) then subject = '' end
self.sendCommand('SendCamera:'..table.concat(indexes,';'), subject)
F.
Instead of changing dzVents I believe a better idea would be to create a shared helper function. Doing so, your code will not disappear when you upgrade Domoticz.ultratoto14 wrote: ↑Thursday 07 September 2017 13:50 @BakSeeDaa thanks for the help.
Maybe @dannybloe will add it in the future.Code: Select all
-- have domoticz send an email with camera snapshot function self.emailCamera(subject, indexes) if (indexes == nil or #indexes == 0) then utils.log('No camera indexes provided', utils.LOG_ERROR) else if (subject == nil) then subject = '' end self.sendCommand('SendCamera:'..table.concat(indexes,';'), subject) end end
F.
Nice functionality !
Will try that.
Thanks.
Will try that.
Thanks.
You can also use the dzVents logging functionality.
domoticz.log('No camera indexes provided', domoticz.LOG_ERROR)
The function can then be defined as
emailCamera = function(domoticz, subject, indexes)
Thanks a lot BakSeeDaa, this is exactly what i did and i just see your message.
Thanks for your time
The complete code
Then use
example:
The complete code
helpers = {
domoticz.log('No camera indexes provided', utils.LOG_ERROR)
domoticz.sendCommand('SendCamera:'..table.concat(indexes,';'), subject)
domoticz.helpers.emailCamera(domoticz, subject, array_of_indexes)
domoticz.helpers.emailCamera(domoticz, 'Alarm triggered', {1, 2})
Looks great!
But you should use the domoticz.LOG_ERROR.
I took me the liberty to change your code a little bit like this:
helpers = {
subject = subject or ''
if not indexes or #indexes == 0 then
- Domoticz version: 2022.2
i am working my way in dzVents(coming from lua) but i really do not see how this works
can anybody explain it to me in a way i can implement this code/function so i can use it to send an email snapshot from my camera
eg:
where do i put the camera info
do i use the complete api string i curently use in lua
eg:
I'm using this command within dzvents:
I am receiving an e-mail but the image seems to be base64 decoded beacuse all I see is some random tect and not the image.
Do you have any idea how to fix this?
domoticz.openURL('http://x.x.x.x/json.htm?type=command¶m=emailcamerasnapshot&camidx=1&subject=Test')
<img src="data:image/jpeg;base64,(here comes the random text).
- Domoticz version: BETA
Perhaps a someone have a script to send the [ or some of them ] pictures directly to a gmail drive???
So we can use the drive as a backup... [ for when you see after x days you miss something in the garden
- Domoticz version: Left
I use this script above:
This works without problem for a single camera, but for 2 it does not work.
Is it possible to send multiple camera pictures in a single email?
domoticz.log('SEND '..table.concat(indexes,';'), domoticz.LOG_ERROR)
end,
- waaren
Currently not but maybe it could be implemented. What do you get when you
http://<domoticzIP:domoticzPort>/json.htm?type=command¶m=emailcamerasnapshot&camidx=1;2&subject=Test
or
http://<domoticzIP:domoticzPort>/json.htm?type=command¶m=emailcamerasnapshot&camidx=1,2&subject=Test
The ; separated version works like a charmwaaren wrote: ↑Monday 21 September 2020 12:34Currently not but maybe it could be implemented. What do you get when you
or
I assume there is currently not a way to trigger this via DzVents?
For now I just use the url.
Last edited by elgringo on Monday 21 September 2020 18:46, edited 1 time in total.
- waaren
not natively in the current version but can you check if
domoticz.sendCommand('SendCamera:'.. "1;2", "test")
if that does not work, below dzVents command should
domoticz.openURL("http://<domoticzIP:domoticzPort>/json.htm?type=command¶m=emailcamerasnapshot&camidx=1;2&subject=Test")
- waaren
And can you confirm the domoticz.openurl does?elgringo wrote: ↑Monday 21 September 2020 18:48does not workCode: Select all
