Email Camera Snapshot  [Solved]
ultratoto14
Post by ultratoto14 »
Hi Guys,
I'm trying to convert some of my scripts to dzVents to use the new features introduced with it (like history).
I'm looking for the api to send a camera snapshot by email but it seems to be lacking.
Is someone using that ?
Is this something easy to implement ?
Thanks,
U.
SweetPants
Re: Email Camera Snapshot
Post by SweetPants »
I think you can send camera snapshots if using Gmail email
ultratoto14
Hi SweetPants,
I already send camera snapshots using the api:
/json.htm?type=command&param=emailcamerasnapshot&camidx='..camIdxs..'&subject='..urlencode(subject)
I just do not find this api in the dzVents implementation.
Regards,
F.
BakSeeDaa
Post by BakSeeDaa »
ultratoto14 wrote: Thursday 07 September 2017 8:12 Hi SweetPants,
Regards,
F.
Why don't you just use
domoticz.openURL(url)
Have a look in the documentation at here
You can build up your URL based on
domoticz.settings['Domoticz url']
ultratoto14
@BakSeeDaa thanks for the help.
My goal is to enhance dzVents, more than finding a workaround.
I already use my own lua modules to do most of the things.
I was trying to move to dzVents to see its potential.
I solved it by adding in runtime/domoticz.lua:
 -- have domoticz send an email with camera snapshot
 function self.emailCamera(subject, indexes)
    if (indexes == nil or #indexes == 0) then
       utils.log('No camera indexes provided', utils.LOG_ERROR)
       if (subject == nil) then subject = '' end
       self.sendCommand('SendCamera:'..table.concat(indexes,';'), subject)
Maybe @dannybloe will add it in the future.
Thanks again to the helpers.
F.
BakSeeDaa
Post by BakSeeDaa »
ultratoto14 wrote: Thursday 07 September 2017 13:50 @BakSeeDaa thanks for the help.
F.
Instead of changing dzVents I believe a better idea would be to create a shared helper function. Doing so, your code will not disappear when you upgrade Domoticz.
ultratoto14
Nice functionality !
Will try that.
Thanks.
BakSeeDaa
Post by BakSeeDaa »
ultratoto14 wrote: Thursday 07 September 2017 19:13 Nice functionality !
Will try that.
Thanks.
You can also use the dzVents logging functionality.
domoticz.log('No camera indexes provided', domoticz.LOG_ERROR)
But then, you'd also need to pass the domoticz object to your function.
The function can then be defined as
	emailCamera = function(domoticz, subject, indexes)
ultratoto14
Thanks a lot BakSeeDaa, this is exactly what i did and i just see your message.
Thanks for your time
The complete code
    helpers = {
            domoticz.log('No camera indexes provided', utils.LOG_ERROR)
            domoticz.sendCommand('SendCamera:'..table.concat(indexes,';'), subject)
Then use
domoticz.helpers.emailCamera(domoticz, subject, array_of_indexes)
example:
domoticz.helpers.emailCamera(domoticz, 'Alarm triggered', {1, 2})
BakSeeDaa
Post by BakSeeDaa »
Looks great!
But you should use the domoticz.LOG_ERROR.
I took me the liberty to change your code a little bit like this:
	helpers = {
			subject = subject or ''
			if not indexes or #indexes == 0 then
Gravityz
Domoticz version: 2022.2
Post by Gravityz »
i am working my way in dzVents(coming from lua) but i really do not see how this works
can anybody explain it to me in a way i can implement this code/function so i can use it to send an email snapshot from my camera
eg:
where do i put the camera info
do i use the complete api string i curently use in lua
anasazi
Post by anasazi »
I'm using this command within dzvents:
domoticz.openURL('http://x.x.x.x/json.htm?type=command&param=emailcamerasnapshot&camidx=1&subject=Test')
I am receiving an e-mail but the image seems to be base64 decoded beacuse all I see is some random tect and not the image.
Do you have any idea how to fix this?
<img src="data:image/jpeg;base64,(here comes the random text).
Derik
Post by Derik »
Perhaps a someone have a script to send the [ or some of them ] pictures directly to a gmail drive???
So we can use the drive as a backup... [ for when you see after x days you miss something in the garden :-) :-( ]
elgringo
Domoticz version: Left
Post by elgringo »
I use this script above:
        domoticz.log('SEND '..table.concat(indexes,';'), domoticz.LOG_ERROR)
		end,
This works without problem for a single camera, but for 2 it does not work.
Is it possible to send multiple camera pictures in a single email?
elgringo wrote: Sunday 20 September 2020 15:26 Is it possible to send multiple camera pictures in a single email?
Currently not but maybe it could be implemented. What do you get when you
http://<domoticzIP:domoticzPort>/json.htm?type=command&param=emailcamerasnapshot&camidx=1;2&subject=Test
or
http://<domoticzIP:domoticzPort>/json.htm?type=command&param=emailcamerasnapshot&camidx=1,2&subject=Test
elgringo
Post by elgringo »
waaren wrote: Monday 21 September 2020 12:34
or
The ; separated version works like a charm :)
I assume there is currently not a way to trigger this via DzVents?
For now I just use the url.
Last edited by elgringo on Monday 21 September 2020 18:46, edited 1 time in total.
elgringo wrote: Monday 21 September 2020 18:25 I assume there is currently not a way to trigger this via DzVents?
not natively in the current version but can you check if
domoticz.sendCommand('SendCamera:'.. "1;2", "test")
works?
if that does not work, below dzVents command should
domoticz.openURL("http://<domoticzIP:domoticzPort>/json.htm?type=command&param=emailcamerasnapshot&camidx=1;2&subject=Test")
If one of the above does work I will implement as a native option in a next version
elgringo
Post by elgringo »
does not work
elgringo wrote: Monday 21 September 2020 18:48
does not work
And can you confirm the domoticz.openurl does?
elgringo
Post by elgringo »
Yes this does work
