dzVents Garbage pick-up alternating dates two pick-ups [Solved]
plugge
I use waaren's getGarbageDates.lua for [ dzVents >= 2.4 ]. It works, but it cannot handle two different pick-up types on the same date.
Type 1 ("restgft") is picked-up every week
Type 2 ("plastic") is picked-up every other week on the same date as Type 1.
It seems the script checks for only one pick-up Type per date and ignores additional pick-ups of another type on the same date.
Or does it?
Or does it?
- waaren
Re: dzVents Garbage pick-up alternating dates two pick-ups
What do you expect and what is not working ? Is it the alert device, the text device and/or the notification?plugge wrote: Saturday 29 August 2020 17:54 I use waaren's getGarbageDates.lua for [ dzVents >= 2.4 ]. It works, but it cannot handle two different pick-up types on the same date.
Or does it?
If you send me the script via PM as you use it now including zipcode / housenumber, I will have a look and see if I can make it work for you?
plugge
Hi waaren,
I have two types of garbage collection "plastic" and "restgft" occurring on the same date, once every two weeks, but every week "restgft"
The devices: Ofcourse the Alert device lists only one, but text device should list two pickups on 2020-09-03 and on 2020-09-17.
I have the impression that the current script cannot handle two pick-up type on the same date. Am I correct?
See the list below of the table "ophaaldagen" I retrieved, as an example:
------------- snip snip -------
{"nameType":"pmd","type":"plastic","date":"2020-09-03"}, ----> Ok, this one is in the virtual text device and in the Alert device
{"nameType":"rest\/gft","type":"restgft","date":"2020-09-03"}, -----> this one is skipped, i.e., not in the virtual text device
{"nameType":"rest\/gft","type":"restgft","date":"2020-09-10"}, -----> this one is skipped, i.e., not in the virtual text device
{"nameType":"rest\/gft","type":"restgft","date":"2020-09-17"}, -----> this one is skipped, i.e., not in the virtual text device
{"nameType":"pmd","type":"plastic","date":"2020-09-17"}, -----> this one is skipped, i.e., not in the virtual text device
{"nameType":"textiel","type":"textiel","date":"2020-09-22"}, ---> Ok, this one is in the virtual text device
{"nameType":"rest\/gft","type":"restgft","date":"2020-09-24"}, -----> this one is skipped, i.e., not in the virtual text device
{"nameType":"papier","type":"papier","date":"2020-09-25"}, ---> Ok, this one is in the virtual text device
--------------snip snip -----------------------------------
plugge
Thanks to waaren, this dzVents script handles multiple (at least two) garbage pickups on the same date.
--[[ getGarbageDates.lua for [ dzVents >= 2.4.28 ]
By waaren
this script is only useful in those areas of the Netherlands where the household garbage collector is connected to afvalwijzer.nl
Enter your zipcode and housenumber in the appropriate place between the lines starting with --++++
Next is to set your virtual text and or virtual alert device.
the text device will contain the most nearby collectdates for the various types of household garbage
the alert device will contain the date and type for the garbagecollection that will arrive first
History:
20180705: Start Coding
20180725: First public release
20180819: Changed target URL to mijnafvalwijzer
20181108: use curl because of badly formatted json return
20200614: sort lines before posting them to text device
20200614: code cleanup
20200614: Prepared for period close to end of year (ophaaldagenNext)
20200615: Fixed notification bug
20200615: Add choice for notification subsystem(s)
20200830: Change method of determining next collection dates
tbc 20201210: interpret dates in next year ??
return
on =
timer =
--'every 1 minutes',
'at 18:10',
'at 08:10'
devices =
-- 'getGarbage', -- Only for test purposes can be ignored
httpResponses =
'getGarbage_Response' -- Trigger to handle Json part
logging =
level = domoticz.LOG_ERROR, -- set to LOG_DEBUG when something does not work as expected
marker = 'collectGarbage',
data =
garbage =
initial = {}, -- Keep a copy of last json just in case
execute = function(dz, item)
--++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
local myZipcode = '1111AA' -- Your zipcode like '3085RA'
local myHousenumber = 1 -- Your housenumber like 38
local myTextDevice = 'Garbage type pickup dates' -- Name with quotes or idx without when created as virtual text device
local myAlertDevice = 'Next garbage pickup date' -- Name with quotes or idx without when created as virtual alert device
local myNotificationTable =
-- table with one or more notification systems.
-- uncomment the notification systems that you want to be used
-- Can be one or more of
-- dz.NSS_FIREBASE_CLOUD_MESSAGING,
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_LOGITECH_MEDIASERVER,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHBULLET,
-- dz.NSS_PUSHOVER,
-- dz.NSS_PUSHSAFER,
dz.NSS_TELEGRAM,
local longGarbageName =
['restgft'] = 'Kliko', --'Restafval en GFT',
['plastic'] = 'Plastic', --'Plastic, Blik en Drankkartons',
['papier'] = 'Papier en karton',
['textiel'] = 'Textiel',
['kerstbomen'] = 'Kerstbomen'
--++++---------------------------- No changes required below this line --------------------------------------------
local function collectGarbageDates(secondsFromNow)
local getGarbage_url = 'http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=' ..
myZipcode .. '&street=&huisnummer=' ..
myHousenumber .. '&toevoeging'
dz.openURL ({ url = getGarbage_url ,
callback = 'getGarbage_Response' }).afterSec(secondsFromNow)
-- Add entry to log and notify to set subsystems
local function errorMessage(message)
dz.log(message,dz.LOG_ERROR)
dz.notify('Garbage',message, dz.PRIORITY_HIGH, dz.SOUND_DEFAULT, "" , myNotificationTable)
local function convertDateFormat(dateString, fromPattern, toFormat)
local fromPattern = fromPattern or '(%d+)-(%d+)-(%d+)'
local toFormat = toFormat or '%a %d %b'
local runyear, runmonth, runday= dateString:match(fromPattern)
return os.date(toFormat, os.time({year = runyear, month = runmonth, day = runday}) )
local function text(lines)
if dz.utils.deviceExists(myTextDevice) then
dz.devices(myTextDevice).updateText( '<tt>' .. table.concat(lines, '\n') .. '</tt>\n')
local function alertLevel(delta)
if delta < 2 then return dz.ALERTLEVEL_RED end
if delta < 3 then return dz.ALERTLEVEL_YELLOW end
if delta < 4 then return dz.ALERTLEVEL_ORANGE end
return dz.ALERTLEVEL_GREEN
local function alert(lines)
if dz.utils.deviceExists(myAlertDevice) then
dz.devices(myAlertDevice).updateAlertSensor(alertLevel(lines.delta), lines[1])
if dz.time.matchesRule('at 08:00-17:00') and lines.delta == 0 then
dz.notify('Huisafval',lines[1]:match('%: (.*)') .. ' will be collected today', dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
elseif dz.time.matchesRule('at 18:00-22:00') and lines.delta == 1 then
dz.notify('Huisafval',lines[1]:match('%: (.*)') .. ' will be collected tomorrow', dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
function table.merge (t1, t2)
for k,v in ipairs(t2) do
table.insert(t1, v)
return t1
local function selectRecords(t)
dateRecords = {}
for _, garbage in ipairs(t) do
if garbage.date >= dz.time.rawDate then
if dateRecords[garbage.date] then
table.insert(dateRecords[garbage.date], longGarbageName[garbage.type] )
dateRecords[garbage.date] = { longGarbageName[garbage.type] }
return dateRecords
local function makeLines(t)
local startDate = dz.time
local futureDay = 0
local lineCounter = 1
local textLines = {}
while lineCounter < 5 and futureDay < 60 do
local traverseDate = startDate.addDays(futureDay).rawDate
if t[traverseDate] then
local textLine = convertDateFormat(traverseDate) .. ': ' .. table.concat(t[traverseDate], ' & ')
if lineCounter == 1 then textLines['delta'] = futureDay end
textLines[lineCounter] = textLine
lineCounter = lineCounter + 1
futureDay = futureDay + 1
return textLines
local function handleResponse()
if not(item.json) then
item.json = dz.utils.fromJSON(item.data:gsub('"ophaaldagen:','"ophaaldagen":')) -- Some responses are even crippled in this part
if type(item.json) == 'table' then
rt = selectRecords(table.merge(item.json.data.ophaaldagen.data, item.json.data.ophaaldagenNext.data))
dz.data.garbage = rt
errorMessage('Problem with response (no data). Try using data from earlier run')
rt = dz.data.garbage -- json empty. Get last valid from dz.data
if #rt < 1 then -- No valid data in dz.data either
errorMessage('No previous data. Are zipcode and housenumber ok and available in afvalkalender?')
return false
textLines = makeLines(rt)
alert(textLines)
text(textLines)
-- Main
if item.isHTTPResponse then
if item.ok then
handleResponse()
errorMessage('Problem with response (not ok)')
collectGarbageDates(600) -- response not OK, try again after 10 minutes
collectGarbageDates(1)
}- waaren
New version because http ://json.mijnafvalwijzer.nl/ - only accepts calls from paying customers.
This script is only useful in those areas of the Netherlands where the household garbage collector is connected to afvalwijzer.nl
the alert device will contain the date and type for the garbage collection that will arrive first
A notification is send in the morning when garbage collection will happen today and in the evening when garbage collection will happen tomorrow.
History:
20200930: Scraping HTTP return because http://json.mijnafvalwijzer.nl/ - only accepts calls from paying customers
return
on =
timer =
'at 18:10',
'at 08:10'
devices =
httpResponses =
'getGarbage_Response' -- Trigger to handle HTTP response
logging =
data =
garbage =
initial = {}, -- Keep a copy of yeardates just in case
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
dz.NSS_TELEGRAM,
local myGarbageLabels =
['Restafval'] = 'Kliko', --'Restafval en GFT',
['Plastic'] = 'Plastic', --'Plastic, Blik en Drank kartons',
['Papier'] = 'Papier en karton',
['Textiel'] = 'Textiel',
['Kerstbomen'] = 'Kerstbomen'
local months =
['januari'] = 1,
['februari'] = 2,
['maart'] = 3,
['april'] = 4,
['mei'] = 5,
['juni'] = 6,
['juli'] = 7,
['augustus'] = 8,
['september'] = 9,
['oktober'] = 10,
['november'] = 11,
['december'] = 12,
local function collectGarbageDates(delay)
local getGarbage_url = 'https://www.mijnafvalwijzer.nl/nl/' .. myZipcode .. '/' .. myHousenumber
dz.openURL(
}).afterSec(delay)
table.insert(t1, v)
return t1
dz.data.garbage = t -- store for future use
for date in pairs(t) do
if date < dz.time.rawDate then
t[date] = nil
return t
local futureDay = 0
return textLines
local function handleResponse(t, freshData)
local garbage = {}
if freshData then
local date = ''
for line in t:gmatch('[^\r\n]+') do -- read response line by line
if line:find('<span class=%"span%-line%-break%">%a+%s%d+%s%a') then
local dutchDate = line:match('%b><'):sub(2,-2)
date = dz.time.year .. '-' .. dz.utils.leadingZeros(months[dutchDate:match('%a+%s+%d+%s+(%a+)')],2) .. '-' .. dz.utils.leadingZeros(dutchDate:match('%a+%s+(%d+)'),2)
elseif line:find('<span class=%"afvaldescr%">') then
local garbageLong = line:match('%b><'):sub(2,-2)
if garbage[date] then
table.insert(garbage[date], myGarbageLabels[garbageLong:match("(%a+)%.*")])
garbage[date] = { myGarbageLabels[garbageLong:match("(%a+)%.*")] }
elseif t ~= nil and next(dz.data.garbage) then
garbage = t
errorMessage('Problem with response and no previous data')
return
textLines = makeLines(selectRecords(garbage))
alert(textLines)
text(textLines)
-- Main
if item.ok then
handleResponse(item.data, true)
errorMessage('Problem with response (not ok) Using previous data')
handleResponse(dz.data.garbage)
}Debian buster, bullseye on RPI-4, Intel NUC.
plugge
Thanks waaren, works like a charm!waaren wrote: Wednesday 30 September 2020 11:53 New version because http ://json.mijnafvalwijzer.nl/ - only accepts calls from paying customers.
And good learning material for scraping in dzVents.
deluccio
- Domoticz version: 2020.2
Can someone help me out on this? I have used the script from "Waaren".
Because a notification looks helpfull for me as well I tried to make the script working as well. But Helaas peanut butter, i failt
Maybe i missed some steps:
1. I have created a dummy Alert "Next garbage pickup date" (Idx=56) and a dummy Text "Garbage type pickup dates" (Idx=55)
I have adjusted the code, filled in my postal code and housenumber and last but not least i changed the Device name to my Idx code.
Where it goes wrong? What step did i missed?
local myTextDevice = 55 -- Name with quotes or idx without when created as virtual text device
local myAlertDevice = 56 -- Name with quotes or idx without when created as virtual alert deviceWhere it goes wrong? What step did i missed?
plugge
Could you copy paste here what the log shows after you set logging to level = domoticz.LOG_DEBUG?deluccio wrote: Monday 19 October 2020 13:32 Can someone help me out on this? I have used the script from "Waaren".
NB: also set a temporary new timer to force the script to execute, otherwise you have to wait until this evening
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_DEBUG when something does not work as expected
deluccio
- Spoiler: show
The only (debug) response i get for now is:NB: also set a temporary new timer to force the script to execute, otherwise you have to wait until this evening![]()
2020-10-19 13:58:05.410 Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/Afvalwijzer.lua-
plugge
See the code below.deluccio wrote: Monday 19 October 2020 13:59
Hmm noob question perhaps: but how to do this
The only (debug) respons i get for now is:
timer =
'at 14:30', -- set this on a time in the future, close to your current time, save the script and wait until the script fired.
'at 18:10',
'at 08:10'
},And maybe, to be sure set:
Setup -> Settings -> Other -> dzVents ->
Enabled: On (=green)
Log level = Debug (eveything)
deluccio
Perfect it worked now
Hehe i was to unpatient
The timer setting solved the "problem"
plugge
Good to hear that. Thanx for the feedback.
deluccio
No i have got another "problem". I receive a <empty> result for GFT pickup date.
I thought the solution was easy and I just simply added a extra Garbage label "GFT" but this did not worked for me.
It should be noted that in my region "Restafval and "GFT" are collected separately.
['GFT'] = 'Groente, Fruit en Tuinafval'Code: Select all
['Kerstbomen'] = 'Kerstbomen',
- waaren
Re: dzVents Garbage pick-up alternating dates two pick-ups [Solved]
If you send me your myZipcode and myHousenumber ( via PM ) I wil have a look.deluccio wrote: Tuesday 20 October 2020 18:29 Now i have got another "problem". I receive a <empty> result for GFT pickup date.
deluccio
Thanks for your help. You solved my problem.waaren wrote: Tuesday 20 October 2020 19:40If you send me your myZipcode and myHousenumber ( via PM ) I wil have a look.deluccio wrote: Tuesday 20 October 2020 18:29 Now i have got another "problem". I receive a <empty> result for GFT pickup date.
I almost was right, but I used the wrong tag. Instead of GFT it should be Groente.
['Groente'] = 'Groente, Fruit en Tuinafval'-
deluccio
I hijacked the forumtopic a bit and perhaps i should create a new topic, but let's give it a try and collect all information about "afvalwijzer" on one place.
I've got a new problem... i reinstalled Domoticz (new server, fresh reinstall) and used the same script as before. The problem is that i get incorrect pickup dates:
Example:
The next pickup date (which is also mentioned on afvalwijzer.nl) is 25 Nov.
The scripts shows:
24 Nov
25 Nov
Both with the same type, and this happens to every type with double information, except for the date, which is always -1
Anyone else has the same issue ?
Example:
The scripts shows:
24 Nov
25 Nov
- waaren
If you send me your zipcode / housenumber and the script as you have it now and if possible the complete log output of the script in debug mode (via PM), I will have a look.deluccio wrote: Wednesday 18 November 2020 8:32 I've got a new problem... i reinstalled Domoticz (new server, fresh reinstall) and used the same script as before. The problem is that i get incorrect pickup dates:
- waaren
New version needed to enable script to deal with situations where afvalwijzer shows pickup dates for two years.
History:
20201118: Use scriptVar for httpResponse, -callBack and marker
20201118: Don't assume this year but get year(s) from response
local scriptVar = 'getGarbage_20201118'
return
on =
timer =
'at 18:10',
'at 08:10',
devices =
httpResponses =
scriptVar, -- Trigger to handle HTTP response
logging =
marker = scriptVar,
data =
garbage =
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
dz.NSS_TELEGRAM,
['Restafval'] = 'Kliko', --'Restafval',
local months =
['januari'] = 1,
['februari'] = 2,
['maart'] = 3,
['april'] = 4,
['mei'] = 5,
['juni'] = 6,
['juli'] = 7,
['augustus'] = 8,
['september'] = 9,
['oktober'] = 10,
['november'] = 11,
['december'] = 12,
dz.openURL(
callback = scriptVar,
}).afterSec(delay)
table.insert(t1, v)
return t1
t[date] = nil
return t
-- dz.utils.dumpTable(t)
local futureDay = 0
return textLines
local garbage = {}
if freshData then
local year = '%d%d%d%d'
local date = ''
local garbageYear, dutchDate
if line:find('<div id=%"jaar%-' .. year .. '%" class=%"ophaaldagen%">') then
garbageYear = line:match(year)
elseif line:find('<span class=%"span%-line%-break%">%a+%s%d+%s%a') then
date = (garbageYear or dz.time.year) .. '-' ..
garbage = t
return
alert(textLines)
text(textLines)
-- Main
if item.ok then
