Using RFXMeter (Electric) from node-red
Jordindc
Post by Jordindc »
I'm trying to use a RFXMeter counter (device type = 113, subtype = 0) to show the daily energy production and the total energy produced by my solar installation. I'm sending the next message to mqtt topic domoticz/in:
{"type":"command","param":"udevice","idx":765,"nvalue":0,"svalue":"2772;7188405"}
and all I can get is, in this case, 2,772 kWh in the top right corner of the device box, and same quantity as total accumulated.
If I send another message later, with a new instant production in Watts and a current total energy produced (kWh), the new instant production is shown either in top right corner as in the middle of the device box.
No idea how RFXMeters are updated from MQTT (or via JSON API, the result is the same).
Any suggestions?
Thanks in advance,
Jordi
FireWizard
Re: Using RFXMeter (Electric) from node-red
Post by FireWizard »
@Jordindc
As you have configured a virtual device of type Electric, you can read at: https://piandmore.wordpress.com/2019/02 ... -domoticz/ under
Electric
The electric sensor will show the current usage of electricity in Watt and the cumulative usage in kWh. You can add digits after the decimal if needed.
{"command":"udevice", "idx":1234, "svalue":"us;cu"}
where us is usage in Watt and cu is cumulative usage in Wh (even though it is displayed in kWh)
1.
As you can see, the command, you send from Node Red by MQTT is not correct. It should be:
{"command":"udevice","idx":765,"nvalue":0,"svalue":"2772;7188405"}
2. After you have created your virtual sensor, like
Screenshot_Electric Counter1.png (37.78 KiB) Viewed 2803 times
you should "Edit" the device.
If your device sends the accumulated consumption, you have to set "Energy read" to "From device".
Screenshot_Electric Counter2.png (31.16 KiB) Viewed 2803 times
Jordindc
Post by Jordindc »
Hi FireWizard, Thanks for your fast reply.
I fixed the message I send, but what I'm getting is the current reading in the top right corner and the cumulative energy from the readings I sent in the Today total. In fact, what I created is a RFXMeter, devices that I'm already using in a python plugin, where what appears in the top right corner is the cumulative daily produced energy and in the middle the absolute total energy produced is shown. In my previous example, 2772 Watts would be aggregated to the daily produced energy and 7188.405 kWh would shown in the middle (with no legend or label).
FireWizard
@Jordindc
If I understand you, you have created a "Counter Incremental" and "Energy".
Can you confirm?
Jordindc
Post by Jordindc »
@FireWizard
The counter I created from virtual sensor hardware is an Electric (Instant + Counter) device. The RFXMeter is created using JSON url:
[domoticz_ip:8080]/json.htm?type=createvirtualsensor&idx=29&sensorname=CounterRFX-test&sensortype=113
[domoticz_ip:8080]/json.htm?type=setused&idx=DEVICE_ID&name=RFXMeter&switchtype=0&used=true
In my python plugin I use RFXMeter (created from the plugin)
Regards,
JN
FireWizard
@Jordindc
I created a virtual device, exactly the way you did with a JSON call.
Tested it, and I noticed exactly the same behavior, as you described. It is according the Wiki: https://www.domoticz.com/wiki/Domoticz_ ... counter.29 and also: https://piandmore.wordpress.com/2019/02 ... -domoticz/
It is sufficient to send only the first value (2772). The second value (7188405) has no effect and is not used. You have already noticed that.
I think you have to use another device as a counter, which has been set to "Energy".
Perhaps P1 Smart meter?
Screenshot_RFX meter.png (131.65 KiB) Viewed 2743 times
However I have not figured out how to create a P1 Smart meter device with a JSON call.
Regards,
