I'm trying to switch my lights with MQTT but I don't got it to work. Now I'm testing it with mosquitto_pub and the following occurs:
When I try command [1] only: nothing happened
[1] mosquitto_pub -h localhost -m '{"command": "switchlight", "idx": 310, "switchcmd": "Toggle" }' -t 'domoticz/in'
But when I enter command [2] after command [1]: the the light switched on:
[2] mosquitto_pub -h localhost -m '{"command": "getdeviceinfo", "idx": 310 }' -t 'domoticz/in'
what am I missing / doing wrong??
MQTT: executing 2 commands for switching light
- waaren
Re: MQTT: executing 2 commands for switching light
If you have your domoticz MQTT "hardware" configured with Prevent Loop True (the default) the incoming commandpedemo wrote: Wednesday 26 August 2020 9:50 I'm trying to switch my lights with MQTT but I don't got it to work. Now I'm testing it with mosquitto_pub and the following occurs:
mosquitto_pub -h localhost -m '{"command": "switchlight", "idx": 506, "switchcmd": "Toggle" }' -t domoticz/inthe incoming request
mosquitto_pub -h localhost -m '{"command": "getdeviceinfo", "idx": 506 }' -t domoticz/inCode: Select all
mosquitto_sub -F "%U - %t - %p" -v -p 1883 -t "#"
1598431402.400431855 - domoticz/in - {"command": "getdeviceinfo", "idx": 506 }
1598431402.558232479 - domoticz/out - {
"Battery" : 255,
"RSSI" : 12,
"description" : "",
"dtype" : "Light/Switch",
"hwid" : "3",
"id" : "0001424A",
"idx" : 506,
"name" : "MQTT test",
"nvalue" : 0,
"stype" : "Switch",
"svalue1" : "0",
"switchType" : "On/Off",
"unit" : 1
}Debian buster, bullseye on RPI-4, Intel NUC.
pedemo
- Domoticz version: V 2020.2
Okay clear, but the command mosquitto_pub -h localhost -m '{"command": "switchlight", "idx": 310, "switchcmd": "Toggle" }' -t 'domoticz/in' doesn't toggle my light. How can I switch my light?
I'm a newby so forgive any "dumb" questions
- waaren
I cannot replicate that, My lights do toggle from Off to On and vice-versa with that command.pedemo wrote: Wednesday 26 August 2020 11:04 Okay clear, but the command mosquitto_pub -h localhost -m '{"command": "switchlight", "idx": 310, "switchcmd": "Toggle" }' -t 'domoticz/in' doesn't toggle my light. How can I switch my light?
How is your MQTT configured in domoticz?
What do yo see in the domoticz log when entering that command?
What do see when entering that command when you listen to port 1883 with
mosquitto_sub -F "%U - %t - %p" -v -p 1883 -t "#"Debian buster, bullseye on RPI-4, Intel NUC.
pedemo
Firts of all: many thanks for helping me!!
* Nothing is shown in the Domoticz log file when entering that command. When I exectue both commands the lights went on but nothing is shown in the log
* When entering command: mosquitto_sub -F "%U - %t - %p" -v -p 1883 -t "#" it stated a bunch of info
i.e.
* What is the deviceType / subtype of your device as seen on the device tab in domoticz?
I don't know where to find it (maybe you can put it here in Dutch because I'm using it in Dutch
* I install it with sudo install mosquittowaaren wrote: Wednesday 26 August 2020 11:16 How is your MQTT configured in domoticz?
CODE: SELECT ALL
i.e.
1598435533.506968029 - domoticz/out - {
"Battery" : 255,
"RSSI" : 12,
"description" : "",
"dtype" : "P1 Smart Meter",
"hwid" : "10",
"id" : "1",
"idx" : 244,
"name" : "Power",
"nvalue" : 0,
"stype" : "Energy",
"svalue1" : "1401695",
"svalue2" : "1671932",
"svalue3" : "312",
"svalue4" : "0",
"svalue5" : "357",
"svalue6" : "0",
"unit" : 1
1598435533.607205366 - domoticz/out - {
"Battery" : 255,
"RSSI" : 12,
"description" : "",
"dtype" : "General",
"hwid" : "10",
"id" : "00000001",
"idx" : 245,
"name" : "Voltage L1",
"nvalue" : 0,
"stype" : "Voltage",
"svalue1" : "234.200",
"unit" : 1
}I don't know where to find it (maybe you can put it here in Dutch because I'm using it in Dutch
pedemo
I figured it out by myself. In DOMOTICZ | HARDWARE I edited my MQTT GATEWAY
I set the 'Prevent Loop' from TRUE to FALSE (see attachment) and now it reacts on the first command
- 2020-08-26_14-01-47.png (39.94 KiB) Viewed 1217 times
- waaren
Just switch to English for a momentpedemo wrote: Wednesday 26 August 2020 11:55 I don't know where to find it (maybe you can put it here in Dutch because I'm using it in Dutch
this is not describing /showing how you configured MQTT in domoticz.* I install it with sudo apt install mosquitto
I mean this page If you don't see anything in the log it could mean that the commands are not received by domoticz or that your logging does not show the normal / status log. What is the output of
grep DAEMON /etc/init.d/domoticz.sh | grep logDebian buster, bullseye on RPI-4, Intel NUC.
