Zigbee2mqtt rssi
Jasper79
Zigbee2mqtt rssi
Post by Jasper79 »
I'd like to see the rssi from a sonoff basiczbr3 zigbee switch. I placed it on the bathroom ceiling and I'd like to see if it still has a good signal.
EddyG
Re: Zigbee2mqtt rssi
Post by EddyG »
You can see the link quality in the network map of the zigbee plugin or in Zigbee2MQTTAssistent
Jasper79
Post by Jasper79 »
It shows this
EddyG
Post by EddyG »
That is really bad. I have sometimes already have problems with a link-quality of 31.
That link-quality give a signal strength of 2 or 3 in Domoticz
What type of controller do you have and what is the distance.
Jasper79
Post by Jasper79 »
Zigbee CC2531 with 8dbi antenna distance is 10 meters with a wooden floor in between.
EddyG
Post by EddyG »
Then there is something wrong with your controller or device.
Check with an other zigbee device which give trouble.
Does SONOFF act normal or is there a delay?
Jasper79
Post by Jasper79 »
No other devices arrived so far, it does respond quickly 95% of the time. I'll have to wait for another device or try to connect the IKEA Tradfri RGB light to it. That's the only other zigbee I have.
Jasper79
Post by Jasper79 »
Okay I received my Mijia sensors and they have a great connection.
3x 170
1x 10
and the sonoff Baciszbr3 still at 0 which is 2 meters above a sensor that reads 170 signal strengt.
