galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
I've uploaded a new beta with changes to the way i build api calls.
It should improve the speed throughout the application.. Please test beta (as i dont want the shit we had last release)
niki_lauda
Post by niki_lauda »
galadril wrote: Wednesday 05 February 2020 17:08 New update is coming for the Android app with quite some big rework.
I've released it to the beta channel of Android at the moment!
Changelog version 0.2.192 (6889)
- New themes (including day/night themes)
- New notification inbox
- Rebuild all preferences screens from scratch
- Added the option to trigger/send notifications
- Updated the look on Wear OS
- Added action button on notifications to inbox
- Improved error state handling
- Fixed some other various layout/device issues
Theme picker (with day/night options)
Complete new rebuild of preferences with category icons:
New notification inbox to check your notification history AND send notifications:
Where can I find the Inbox?
I'm on 0.2.226(7631). I would like to clean it.
joyride1176
Post by joyride1176 »
galadril wrote: Friday 19 June 2020 11:31 I've uploaded a new beta with changes to the way i build api calls.
I had same permissions issue "you don't have the rights to..." on paid and lite version
I confirm you beta release 3rd July has fixed the issue
After one hour of testing issue disappeared and before was persistent without workaround possible
Tested on multiple servers
niki_lauda
New date 32/7 :-)
The app displays a date that to my knowledge doesn't exist.
galadril
Post by galadril »
niki_lauda wrote: Sunday 05 July 2020 12:55 Where can I find the Inbox?
Its in you settings/notifications/history or Inbox
Or you click on the Inbox button when you've received a new notification
galadril
Re: New date 32/7 :-)
Post by galadril »
niki_lauda wrote: Tuesday 04 August 2020 7:51 The app displays a date that to my knowledge doesn't exist.
Oef thats weird.. ok ill put it on my list to check, thanks
galadril
Post by galadril »
New beta is uploaded to the play store (0.2.230 (7815))
galadril
Post by galadril »
Can somebody assist on the translations?
https://crowdin.com/project/domoticz-for-android
galadril
Post by galadril »
New beta is coming with a new feature (multi graph for temp devices):
Full changelog for this beta (0.2.232 (7878))
- Implemented camera background for connected switches
- Improved camera detail page
- Added new multi graph option for temperature devices
- Reworked slider component
- Added new Dark Blue theme
- Use Tasker for Automation
- Updated translations
- Improved import/export settings with file picker implementation
- Removed unsecure LoginCheck calls
- Fix for filtering Logs
Luigi87
Post by Luigi87 »
There seems to be somthing wrong in the app. The switches in the room plans are most of the time not working. I have to switch the switch from slider or buttons in the settings to get the app working again.
There are more people with this:
https://www.domoticz.com/forum/viewtopi ... 37&t=33696
Its in the payed app and in the lite version also!
paolone919191
Post by paolone919191 »
Luigi87 wrote: Sunday 23 August 2020 14:07 There seems to be somthing wrong in the app. The switches in the room plans are most of the time not working. I have to switch the switch from slider or buttons in the settings to get the app working again.
I can confirm the same problem, on my android 9 and 10 devices.
To make the switch working, i don't need to change the "kind" of switch, but simply open and close the settings menu of the app.
Thanks for your support
Paolo
Michalux
Post by Michalux »
I've been testing domoticz widgets lately and it seems there is something wrong with push on/off button.
It generates three actions instead of one. When I use a switch type push on/off button in domoticz, than it generates one action (on or off).
But android widget generates on+off+on or off+on+off.
So it looks like something is wrong here :(
Zoonie81
Post by Zoonie81 »
Hello, paid user here. Not sure this is the right place to report bugs and erratic behavior but here goes.
I've had the app for a year or two. The latest updates seem to have caused a bug where the slider for a particular z-wave dimmer activates other devices randomly. It can turn on/off other devices or adjust dimming on other devices - randomly every time.
  • This only happens in the app and only in the Dashboard-view.
  • Same slider in Switches-view acts normally in the app.
  • Same slider in the domoticz web gui acts normally - independent of dash/switch view.
  • All other devices/sliders/switches act normally when interacted with through Dashboard.
  • Domoticz server is up-to-date, running on a rpi3.
  • Android app is up-to-date. Have tried clearing cache, removing app, reinstalling app etc.
  • The z-wave device with the affected slider has been part of the network for couple of years and worked flawlessly earlier.
  • I noticed the problems about a couple of weeks ago. Could be longer and I just missed noticing it.
If problem is on my end I welcome suggestions.
Thx, Z
juankar
Domoticz version: 4.
Post by juankar »
Hi, I¡m using Domitcz Lite and it's updated.
Some times when I try to send a command (switch on or off) I receive an error message telling that I have no rights for this action!(well I receive it in spanish, usted no tiee derechos para esta acción)
When I switch off several times or change any settings, then I can do the action, but after some time I receive the error message again.
Where is the mistake?
Johndomo
Post by Johndomo »
I also experience some bugs with the latest app. Paid verion, everything up-to-date, Android 9
Problems occur with Zwave (Fibaro) dimmers.
When I switch on / off devices, everything goes ok. But when I change the level of one of the dimmers, other devices are switched on too and set to the same level.
When I change the level of dimmer 1, dimmer 2...5 are switched on and set to the same level.
When I change the level of dimmer 2, dimmer 3...5 are switched on and set to the same level. Dimmer 1 is not changed.
When I chnage the level of dimmer 3, dimmer 4...5 are switched on and set to the same level. Dimmer 1..2 are not changed.
etc.
This only happens in the app, not in the web based application on the laptop.
Hope this can be solved in a future version.
John
Zoonie81
Post by Zoonie81 »
Johndomo wrote: Thursday 17 September 2020 21:58 Hi,
etc.
John
So this must indeed be a bug introduced in one of the app updates, as it resembles my own experience. Let's hope it gets fixed by next update.
Regards, Z
Pancak1998
Post by Pancak1998 »
Hi! I am a happy user of the paid app.
But as of this weekend I am trying to move to a new phone without Google Play Services.
Any way to activate the 'premium' function on a phone without the Google Play Services / Framework?
galadril
Post by galadril »
etc.
John
Sorry guys, im fixing the dimmers as we speak!
galadril
Post by galadril »
Zoonie81 wrote: Sunday 13 September 2020 20:42 I've had the app for a year or two. The latest updates seem to have caused a bug where the slider for a particular z-wave dimmer activates other devices randomly. It can turn on/off other devices or adjust dimming on other devices - randomly every time.
Have you checked the latest update, that should fix the dimmers/sliders
Zoonie81
Post by Zoonie81 »
galadril wrote: Thursday 01 October 2020 8:57
Thanks for replying. I've updated, unfortunately to no avail. Also, last week the paid version suddenly started crashing at startup and auto-closing. I tested everything, force close, clear cache, remove data, uninstall, reinstall. Nothing worked, so I was forced to use the Lite version, until now. The update fixed the crashing and I'm back on the paid version, but the bug is still alive.
