xiaomi door sensor loosing connection to zigate
wuffer
Post by wuffer »
I have xiaomi door sensor on my mailbox, so i can get a notification when i get mail. The problem is that if i dont get mail after some days, it looses connection and then i have to push the button on the side.
Battery is fine.
Is there something i can do, so it doesn't looses connection?
pipiche
Re: xiaomi door sensor loosing connection to zigate
Post by pipiche »
If you could give us some context. What is your Zigate network about. How many routers do you have how many end devices ? How far is the Xiaomi Door sensor from the next router (or Zigate) ?
What is the Zigate channel ?
What is your Wifi 2.4 channel ?
wuffer
Post by wuffer »
Not good with distance. But i live on the second floor and its just outside the front door, concrete building.
Cc2531 router couldn't reach it, so im using a cc2591 router
I only have 8 zigbee devices where 3 is routers, 2 xiaomi plugs and the cc2591 router.
2.4ghz is channel 11
zigate also at 11.
Should i change channel on zigate?
pipiche
Post by pipiche »
wuffer wrote: Monday 03 August 2020 19:22 Not good with distance. But i live on the second floor and its just outside the front door, concrete building.
zigate also at 11.
Wifi and Zigbee channels both set to 11 is perfect, as you avoid overlap .
Can you try to set the Zigate to FCC certification mode. You have to go the plugin Web Admin settings. (This might help)
Screenshot 2020-08-03 at 19.26.01.png (110.38 KiB) Viewed 694 times
How do you do the pairing ? with the sensor closed to the ZiGate or , the sensor in the mailbox ?
wuffer
Post by wuffer »
Normally i just use the accept new hardare in the plugin web admin settings and then allow for 5 minutes in domoticz settings.
pipiche
Post by pipiche »
But where is the Xiaomi sensor ? Still in your mailbox outside or with you next to the zigate
wuffer
Post by wuffer »
I pair it next to the cc2591 router. Then when it sits in the mailbox, it seems to be enough just to press the button on the side, for it to connect again
