Magic Home RGB WiFi controller integration Topic is solved
Re: Magic Home RGB WiFi controller integration
Has there been any movement on this? I've just got an LED strip, which works great but it would be good to be able to adjust the brightness too.
I would be also interested into! Would do some coding... if i could ;p
In the moment im thinking about some bad workarounds, and use virtual switches for Szenes and run a script in the background. Not that nice, but will work for now.
Any news on that folks?
I fixed the dimmer issues in the Arilux driver and it seems to work with my Magic Home compatible led controllers. The code should be available in the next beta build.
Arilux AL-LC0x subtype RGBWZ timers does not send command ON, only brightness level.
also on the slider works off but not on
command
manual switching on, it works
Off command work ok
i use Magic Home wifi controller
command
Off command work ok
- Domoticz version: 2020.2
i made a video on this topic: https://www.youtube.com/watch?v=o-UT2XG ... iyqAIR8dMA
please, can you make hardware plugin for magic home the same as arilux just modified command for ON via the slider - send first command ON then brightnes from 1 to 100. and in timers first ON command
in my case
also on the slider works off and brighness but not ON
command
Off command work ok
in my case
command
Off command work ok
I solve my problem.
i put the flux_led.py script in ON Action, and now it works timers option and On command from slider
I bought a Led Light Bulb from "Magic Home" on AliExpress, and now I'm trying to integrate with Domoticz, but I have some problems.
I used it integrated with APP, it works.
1- In Domoticz, if I use Airlux hardware, I get: Error: Arilux: Exception: connect: Connection refused;
2- I installed the flux_led scripts, but didn't work. Here my commands and outputs:
# Ping the lamp it's OK.
pi@London ~ $ ping 192.168.1.166
PING 192.168.1.166 (192.168.1.166) 56(84) bytes of data.
64 bytes from 192.168.1.166: icmp_seq=1 ttl=255 time=85.1 ms
64 bytes from 192.168.1.166: icmp_seq=2 ttl=255 time=95.3 ms
64 bytes from 192.168.1.166: icmp_seq=3 ttl=255 time=14.6 ms
# trying to scan from my Raspberry
pi@London ~ $ python -m flux_led -s
0 bulbs found
# trying to take some information by lamp
pi@London ~ $ sudo python -m flux_led -i 192.168.1.166
Unable to connect to bulb at [192.168.1.166]: [Errno 32] Broken pipe
I'm using:
- Raspberry Pi2
- Domoticz 4.11665
Can someone help me ?
0 bulbs found
I'm using:
- Raspberry Pi2
- Domoticz 4.11665
