Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee) Topic is solved
Thorgal789
- Target OS: -
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
Take only firmwares proposed in phoscon. The firmware ______Many2one.bin.gcf is a beta fiwmare, in test.
But yes the deCONZ_RaspBeeII_0x26610700.bin.GCF is the last one, and it's the one you have.
Thorgal789
- Target OS: -
I have made somes modifications on code to better ignore the conbee https://github.com/Smanar/Domoticz-deCO ... /plugin.py
I think thy will solve your problem.
salopette
- Domoticz version: BETA
Thank you! I continue to watch for errors:
Plantje
Have another stupid question... While moving to the new server: do I need to create a new API key? Or will stuff be migrated from old to new with the export and import of the Phoscon/deCONZ and Domoticz configurations?
Thorgal789
- Target OS: -
If you use the backup/restaure feature from phoscon and use the same device, you will have a perfect clone, so nothing will change, in phoscon or domoticz.
For information, network config is stored on the device, devices configurations are on the host.
The backup, put all those information in one tar file.
Plantje
It is all working great! Thanks for your support!
- superelch
hi,
i have a problem with the opple 6x switch.
single click works fine, but doubleclick and longclick ist mixed up.
for example: switch 1 double get me the same result as switch 3 single.
the switch appears with B1-B8.
i get more by adding more (B9-Bx) but sw1 double is still the same as sw3 single.
any idea?
hi,
any idea?
Raspberry / Domoticz (beta) / z-wave & xiaomi & habridge & 5x Alexa & google dots & milight & yeelight & harmony hub & Netatmo & ITTT & sonoff & Conbee II .... & a girlfriend who hates that stuff ...
Thorgal789
- Target OS: -
Ok so yes there is a problem ^^
You need to have a switch with
To reconize the switch I m using the model id, it need to finish by "86opcn01", you can see it with enabling log for exemple (debug info only)
And BTW wich one plugin version are you using ?
kwarg['Options'] = {"LevelActions": "|||||||||||||||||", "LevelNames": "Off|B1|B2|B3|B4|B5|B6|B1L|B2L|B3L|B4L|B5L|B6L|B1RL|B2RL|B3RL|B4RL|B5RL|B6RL|B1D|B2D|B3D|B4D|B5D|B6D|B1T|B2T|B3T|B4T|B5T|B6T", "LevelOffHidden": "true", "SelectorStyle": "1"}And BTW wich one plugin version are you using ?
- superelch
wow, that´s fast....
i use deCONZ plugin 127.0.0.1
Domoticz is latest beta
phoscon recognizes the switch as:
Hersteller Xiaomi
Produkt OPPLE Schalter 3-fachWXCJKG13LM
Version 20190730
Domoticz error log shows me
2020-08-30 17:37:14.292 Error: (Zigbee) Unknow MAJ{'attr': {'lastannounced': None, 'lastseen': '2020-08-30T15:37Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x264a0700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}
2020-08-30 17:38:14.290 Error: (Zigbee) Unknow MAJ{'attr': {'lastannounced': None, 'lastseen': '2020-08-30T15:38Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x264a0700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}
2020-08-30 17:38:56.880 Error: CheckAuthToken(3f72a06468482f8447adb15ba8497970_MTFmYTBmODEtMWJhOS00NjljLTkwZTEtOWMyYTgzYjU3ODkz) : session id not found
2020-08-30 17:39:16.694 Error: (Zigbee) Unknow MAJ{'attr': {'lastannounced': None, 'lastseen': '2020-08-30T15:39Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x264a0700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}
2020-08-30 17:40:17.941 Error: (Zigbee) Unknow MAJ{'attr': {'lastannounced': None, 'lastseen': '2020-08-30T15:40Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x264a0700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:05:a3:70-01'}
Hersteller Xiaomi
Version 20190730
Thorgal789
- Target OS: -
127.0.0.1 is your local IP ^^.
But nevermind, looking your error, you haven't the last version for sure.
- Try update your version, just need to type "git pull".
- delete the bad widget for the opple
- restart the plugin, hardware/deconz/update
The widget will be re-created with a better one.
If you still have the problem, enable log to find the opple device model ID.
- superelch
facepalm * copy and paste without brain
Thorgal789
- Target OS: -
^^, and BTW your problem is solved now ?
- superelch
I had a problem with updating via command line, but replacing the files does the magic.
my problem was that I thought that
keeping deconz-rest-plugin up-to-date would help. now I see more clearly.
THANKS, problem solved !!!
Thorgal789
- Target OS: -
Hello, someone is making a "custom page" usable in domoticz to improves deconz features usable direclty in domoticz. Problem it works only on last domoticz version.
Just by curiosity, are you using older or last domoticz version (after 2020, versions that are working only on buster) ?
salopette
Cool! I think there are hardly any people who use the older version!
When can I test the new site?
Plantje
I'm on the latest version as well
Thorgal789
- Target OS: -
I m using it ^^. I don't like the SQL management on new version, and don't need buster (I know it s stupidsalopette wrote: Thursday 03 September 2020 19:07 Cool! I think there are hardly any people who use the older version!
The code is not from me, and it s not finished (we can do so much thing with this system), but you can take a look https://github.com/JayPearlman/Domoticz ... _interface.
To test it you can keep your deconz version and just copy the files from the "frontend" folder and copy them to domoticz/www/templates
The files can be copied directly in to domoticz/www/templates and then a new page will appear under the "Custom" top navigation to test them out.
Hey, there is a lot of how-tos on how to install and maintain, but there is not much on how to uninstall and completeley remove the plugin?
I wont be needing it anymore, so how do I uninstall it? I am running headless on raspberry pi (buster)
Thanks 4 help
Thanks 4 help
Thorgal789
- Target OS: -
Hello, this plugin have nothing special, so it 's the same procedure than for all plugins.
- In domoticz go in hardware and delete the "hardware" deconz.
- In plugins folder, delete the plugin folder.
- The hardware will be visible till you restart domoticz, but it is already uninstalled.
If you are talking about deconz, depend of how you have installed it, if you have used package
sudo apt remove deconz-
salopette
2020-10-02 18:05:00.028 (deconz) ### Groupe > 65520 Name:All
2020-10-02 18:05:00.032 Status: (deconz) ### Create Device GROUP_All > All (LightGroup) as Unit 149
2020-10-02 18:05:00.001 Error: (deconz) Websocket error, unknow device > 65520 (groups)
Hi, I keep getting this error.
Can you suppress that?
