Mastering the "at" command  [Solved]
Number8
Domoticz version: 2022.1
Post by Number8 »
Hello
I'm currently running dzvents 3.0.9. I'm wondering whether the command item.switchOn().at("18:35") and item.switchOff().at("18:36") will stay active until item.cancelQueuedCommands() is sent. If not, how should it be handled?
Thank you
Debian buster on NUC and three RPi with buster.
Re: Mastering the "at" command  [Solved]
Number8 wrote: Saturday 18 July 2020 19:37 Hello
Thank you
Underlying the at method is translated to an afterSec method with the calculated number of seconds. So behavior is the same and it stays active until cancelled explicitly (using the cancelQueuedCommand() or -implicitly (by a domoticz restart)
Number8
Post by Number8 »
Thanks waaren
