Hello
I'm currently running dzvents 3.0.9. I'm wondering whether the command item.switchOn().at("18:35") and item.switchOff().at("18:36") will stay active until item.cancelQueuedCommands() is sent. If not, how should it be handled?
Thank you
Mastering the "at" command [Solved]
Number8
- Domoticz version: 2022.1
Debian buster on NUC and three RPi with buster.
- waaren
Re: Mastering the "at" command [Solved]
Underlying the at method is translated to an afterSec method with the calculated number of seconds. So behavior is the same and it stays active until cancelled explicitly (using the cancelQueuedCommand() or -implicitly (by a domoticz restart)Number8 wrote: Saturday 18 July 2020 19:37 Hello
Thank you
