Python Plugin: TUYA
itguy78
- Domoticz version: 12184
Python Plugin: TUYA
Now that TUYA and IFTTT are no longer cooperating I could no longer use IFTTT to control my TUYA devices, so I wrote a python plugin for my own use to control TUYA devices around the house.
There is a large number of brands that are manufactured by Tuya including Merkury, Geenie, etc (names may vary/change around the world) but with the features and price-range they are likely to be around for a long time.
This is working well for me, so anyone is welcome to use/try it and provide any feedback.
I only have a few LED lights (white/color) and wallplug switches but I am pretty sure this will work with most TUYA devices for on/off status and control. It is also able to activate 'scenes' created/configured in the TUYA app.
The main thing for me was a solution that does not require setting up IP addresses/port settings for each device (and have to manually update them when anything changed) and worse trying to find out device IDs and Keys, so this plugin automatically detects/redetects TUYA devices on your account and adds them with the name given in the TUYA app.
Fair warning: there are draw-backs from using the Cloud:
-Not being able to control the devices locally if your internet is down (I have fast/reliable internet and there's always the TUYA app as last resort)
-it can take up to 1 minute for the status of the device to be updated in the cloud (should not be an issue if you always use Domoticz to control it)
For Downloads/Install steps/Source see this link:
https://github.com/guino/tuyaha
- TuyaPlugin.png (299.24 KiB) Viewed 45241 times
Re: Python Plugin: TUYA
Will this also work when using the SmartLife app?
- sincze
- Domoticz version: 2024.4
Tnx.
Nice addition for people that have their Tuya devices in the cloud and not reflashed by Tasmota.
Don't forget to add the plugin to: https://www.domoticz.com/wiki/Plugins
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
itguy78
I have never tried but looking at some info I believe the only change required would be to change line 170 of plugin.py to say "smart_life" instead of "tuya" -- I don't have anything enrolled in the smart life app but if someone tries and it works I can make a setting for the plugin.
EDIT: I enrolled a device in the smart life app and made the change I suggested above and it appears to work -- I'll make the change to the plugin so you can configure the app type in the settings (when I have time)
itguy78
I honestly don't know how to edit this page -- I believe I need to login but it says forum user/pass won't work (and I tried) and there's no 'create account' anywhere that I can see as mentioned in the help login page, so no luck for me.sincze wrote: Saturday 27 June 2020 11:38 Tnx.
itguy78
I have made the changes that allow the plugin to be configured for SmartLife or Jinvoo Smart app (as well as Tuya). Simply select the app from the drop down in the hardware settings (Options are: Tuya, Smart Life or Jinvoo Smart) and it should automatically detect the devices from the app in question. The link on the original post has been updated with the latest version of the plugin.
It works. Nice, thx
DarkG
- Domoticz version: 4.10076
Is there a way to change temperature for my AC? I can only turn on and off.
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
itguy78
I wrote the plugin with support for on/off (any device with on/off switch) and for setting brightness/color for LED lights. These are the only devices I have to test with.DarkG wrote: Tuesday 14 July 2020 22:06 Is there a way to change temperature for my AC? I can only turn on and off.
The API has functions to read and set the 'target' temperature and to read the 'current' temperature, but I have no way to test these features. Someone with access to the device should be able to add in a new device that displays current temperature and allows changing the target temperature. Only way I could work on this is if you sent me your app account information (private message) so I could configure it and add it to the plugin -- obviously you'd have to not mind me messing with the settings for development.
EDIT: You should be able to create a 'scene' in the app to set the temperature of the AC to some fixed values you commonly use and then add these scene buttons to domoticz so it changes the temperature to these preset values.
DarkG
itguy78 wrote: Wednesday 15 July 2020 19:51I wrote the plugin with support for on/off (any device with on/off switch) and for setting brightness/color for LED lights. These are the only devices I have to test with.DarkG wrote: Tuesday 14 July 2020 22:06 Is there a way to change temperature for my AC? I can only turn on and off.
I wrote you a pm
- EdwinK
- Domoticz version: BETA
Thanks for this plugin. I now can use my LSC/Tuya LED-strip with domoticz.
Now I need to create some scenes for it.
- Xenomes
- Domoticz version: 2026.4
Hi itguy78,
Is your (plugin.py) script still under development? The plugin works perfectly, I miss some warm and cold contols for my RBGWW LED light (Realtek chip). I tried to edit / change your script by adding the CW and WW channel. But my coding skills are insufficient. Hopefully you see possibilities to add it. Of Course I want to test things for you and provide info to help your progress.
Ps. You still need to add it to the https://www.domoticz.com/wiki/Plugins
Greeting Xenomes
Greeting Xenomes
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
itguy78
I would need to know of a plugin that has the warm/cold controls to know what kind of properties are supposed to be set in Domoticz to display these controls. I would also need access to one of these lights so I can see the properties available and provide the controls for them. I only have some basic RGB lights and while lights to test with, so I am not sure what to look for but I would expect the current RGB control works for your lights too?Xenomes wrote: Sunday 30 August 2020 18:46 Hi itguy78,
Greeting Xenomes
I haven't added it to the wiki because my domoticz forum account doesn't work on it and the 'create account' function isn't working for me, so unless someone has a working account and can add it I don't have a way to do it myself. From what I looked at the 'Login' page should have a 'create account' link but it is not anywhere to be found:
- Xenomes
Maybe one of the most active users can help:itguy78 wrote: Monday 31 August 2020 3:04 I haven't added it to the wiki because my domoticz forum account doesn't work on it and the 'create account' function isn't working for me, so unless someone has a working account and can add it I don't have a way to do it myself. From what I looked at the 'Login' page should have a 'create account' link but it is not anywhere to be found:
These plugin uses the WW and WC for Tasmota flashed tuya bulbs, https://github.com/emontnemery/domoticz_mqtt_discovery and the https://github.com/mario-peters/ShellyCloudPlugin in the Bulb section, the device settings are Type 241, subType is 4 and SwitchType 7. If i set the rgb trigger in the middle then there is a strange blueish light.itguy78 wrote: Monday 31 August 2020 3:04 I would need to know of a plugin that has the warm/cold controls to know what kind of properties are supposed to be set in Domoticz to display these controls. I would also need access to one of these lights so I can see the properties available and provide the controls for them. I only have some basic RGB lights and while lights to test with, so I am not sure what to look for but I would expect the current RGB control works for your lights too?
I am running your script with the latest version of tuyaha (0.0.7)
Edit: I have added a warm/cold white channel support.
Line 205
Domoticz.Device(Name=dev.name(), Unit=unit, Type=241, Subtype=4, Switchtype=7, DeviceID=dev.object_id()).Create()
elif Command == 'Set Color':
# Convert RGB to Hue+Saturation
rgb = json.loads(Hue)
h, s = rgb_to_hs(rgb.get("r"), rgb.get("g"), rgb.get("b"))
mode = rgb.get("m")
t = rgb.get("t")
Domoticz.Debug("color="+str(rgb)+" h="+str(h)+" s="+str(s))
# If color changed
if Devices[Unit].Color != Hue:
if mode == 3:
dev.set_color( [ h*360, s*100 ] )
Domoticz.Debug("Set color called")
if mode == 2:
temp = round(1000+(9000/255*(255-t)))
Domoticz.Debug("temp = " + str(temp))
dev.set_color_temp( temp )
Domoticz.Debug("Set white called")
# If level changed
Tinytuya
Tinytuya
itguy78
The changes look simple enough -- I'll test it with my regular color lights to make sure it works then I can merge them in. Thanks!
- Xenomes
Here a other modification for detect on/off, brightness, WW, RGB and RGBWW lights.
if dev_type == "light":
if dev.data.get("color_mode") is not None and dev.data.get("color_temp") is not None and dev.data.get("brightness") is not None:
# Light Color and White temperature contol
elif dev.data.get("color_mode") is not None and dev.data.get("color_temp") is None and dev.data.get("brightness") is not None:
# Light Color control
Domoticz.Device(Name=dev.name(), Unit=unit, Type=241, Subtype=2, Switchtype=7, DeviceID=dev.object_id()).Create()
elif dev.data.get("color_mode") is None and dev.data.get("color_temp") is not None and dev.data.get("brightness") is not None:
# Light White temperature control
Domoticz.Device(Name=dev.name(), Unit=unit, Type=241, Subtype=8, Switchtype=7, DeviceID=dev.object_id()).Create()
elif dev.data.get("color_mode") is None and dev.data.get("color_temp") is None and dev.data.get("brightness") is not None:
# Light Brightness control
Domoticz.Device(Name=dev.name(), Unit=unit, Type=241, Subtype=3, Switchtype=7, DeviceID=dev.object_id()).Create()
elif dev.data.get("color_mode") is None and dev.data.get("color_temp") is None and dev.data.get("brightness") is None:
# Light On/Off control
Domoticz.Device(Name=dev.name(), Unit=unit, Type=244, Subtype=73, Switchtype=7, Image=0, DeviceID=dev.object_id()).Create()
else:
Domoticz.Debug("No controls found for your light device!")HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
cobra045
- Domoticz version: 3.4834
I found it, here you can create the requested accountitguy78 wrote: Monday 31 August 2020 3:04
https://www.mediawiki.org/w/index.php?t ... n=loginCTA
Cobra045
- Xenomes
Hi itguy78,
Is it possible that you change your github clone in a standalone project? called 'Domoticz-TUYA-Plugin' (as in the file) your script is only depending on tuyaha and not based on. I am running it now without the original files in the directory but installed sudo pip3 install tuyaha . An other benefit is that users can make issues/device support request and you can make a beta branch for developing. Others can clone and modify and make improvements. Think about it.
Greeting Xenomes
Greeting Xenomes
Tinytuya
Tinytuya
Chris12
- Domoticz version: 2021.1
Hi, I ran into this topic because I just received a wifi smartplug via AliExpress which I want to use to control my garden lights based on the daylight/sunrise times.
The smartplug works fine via the smartplug app. I can see that the plug has firmware version 1.4.2 (Main/MCU)
My domoticz (beta 2020.2) runs on a Synology NAS, and I added the TUYA plugin so it is visable in teh hwardware list.
When adding the TUYA hardware, that goes fine, I cannot see any devices created after that?
In the logging I can see this:
2020-09-03 15:13:05.892 Error: (tuya) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/tuyaha-master/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload:/volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages'.
2020-09-03 15:13:05.892 Error: (SmartPlug-1) Module Import failed, exception: 'ImportError'
2020-09-03 15:13:05.892 Error: (SmartPlug-1) Module Import failed: ' Name: requests'
2020-09-03 15:13:05.892 Error: (SmartPlug-1) Error Line details not available.
Am I missing a step here? Of can someone point me in the right direction to get this solved?
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
- Xenomes
You need to Install a python Library 'requests'.
pip3 install requestsHP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
