CATT show Domoticz on Google Hub
Andyyyy
Re: CATT show Domoticz on Google Hub
Post by Andyyyy »
i am to using catt to stream domoticz to my Lenovo Smart Display. It works but i cannot use the pulldowns to switch between floorplans.
Did anyone solve this problem ?
Andyyyy
FireWizard
Post by FireWizard »
@Andyyyy
Do you use the standard interface, as I do not recognize, what you mean.
I my case, I have 5 floor-plan drawings, which I can call-up by touching the small "circle" under the drawing.
So I do not have "pulldowns". I stream to the Google Nest Hub.
See: https://www.domoticz.com/forum/viewtopi ... hilit=CATT
Andyyyy
Post by Andyyyy »
Hi FireWizard,
sorry i mean the room selector pulldown.
I use the ThinkTheme.
Andyyyy
Droid
Post by Droid »
Here an update.
I gave up on the dummy switch solution.
Instead I've installed Node-RED with NORA plugin. I've created a switch which then executes a shell script.
Works like a charm
FireWizard
@Droid.
In principle, I do exactly the same.
However, because CATT and Node Red run on different hardware, I push the command with MQTT to the machine with CATT installed.
Indeed, that works like a charm.
gropi
Domoticz version: 4.11786
Post by gropi »
I placed my script under the scripts folder in domoticz and I can activate it from Domoticz.
catt -d 192.1.1.1 cast_site http://192.2.2.2:8082/ &
sleep 60
catt stop
exit 0
Domoticz Version: 2023.1
Platform: Openmediavault 6; Docker; HP Microserver Gen8
Plugin/Hardware: MySensors Gateway; Philips HUE Bridge; OMG; ZigBee;
