i am to using catt to stream domoticz to my Lenovo Smart Display. It works but i cannot use the pulldowns to switch between floorplans.
Did anyone solve this problem ?
Andyyyy
CATT show Domoticz on Google Hub
- FireWizard
Re: CATT show Domoticz on Google Hub
@Andyyyy
You wrote:
I my case, I have 5 floor-plan drawings, which I can call-up by touching the small "circle" under the drawing.
So I do not have "pulldowns". I stream to the Google Nest Hub.
See: https://www.domoticz.com/forum/viewtopi ... hilit=CATT
@Andyyyy
You wrote:
Do you use the standard interface, as I do not recognize, what you mean.It works but i cannot use the pulldowns to switch between floorplans
Hi FireWizard,
sorry i mean the room selector pulldown.
I use the ThinkTheme. Andyyyy
Droid
Here an update.
I gave up on the dummy switch solution.
Instead I've installed Node-RED with NORA plugin. I've created a switch which then executes a shell script. Works like a charm
- FireWizard
@Droid.
In principle, I do exactly the same.
However, because CATT and Node Red run on different hardware, I push the command with MQTT to the machine with CATT installed.
Indeed, that works like a charm.
@Droid.
gropi
- Domoticz version: 4.11786
I placed my script under the scripts folder in domoticz and I can activate it from Domoticz.
catt -d 192.1.1.1 cast_site http://192.2.2.2:8082/ &
sleep 60
catt stop
exit 0
Domoticz Version: 2023.1
Platform: Openmediavault 6; Docker; HP Microserver Gen8
Plugin/Hardware: MySensors Gateway; Philips HUE Bridge; OMG; ZigBee;
