I've done some searching and am wondering how folks have implemented use of the Security Panel? I was looking for a simple Z-Wave security panel, but didn't find many solutions. I've seen HA use an Android with a MQTT application to use the security panel.
I was wanting to use a Raspberry Pi with a keypad and LED status screen, but I wasn't finding any easy solutions to make that happen. I was also thinking a touch screen that showed the security panel URL might be a route to go down as well. My main reason for wanting to stick with a rPi is because I also want to run Node-Red for BLE scanning. Also wanting to stay away from anything that is cloud connected.
Would love to hear how others have implemented this.
What hardware do you use for the Security Panel?
Re: What hardware do you use for the Security Panel?
Is there no one using the security panel feature of Domoticz?
Within Dashticz you can add a security panel linked to the Domoticz security status.
See https://dashticz.readthedocs.io/en/mast ... panel.html
What hardware do people typically use though? That's just another way to display the web page version right?
- Domoticz version: 4.11083
I have bought a rfid panel at aliexpress
something like this;
https://nl.aliexpress.com/item/32916658 ... hweb201603_
then couple this to a smart implant from fibaro and you have what you want.
succes
Jan
succes
Jan
- Domoticz version: 2020.2
My alarm is switch on for at home mode in my goodnight scene and is automatically switched off in the morning when someone is at home.
For away mode I use either HomeKit/Siri and the alarm is switched off when arriving back home.
As backup I have a hidden Xioami button with which I can switch it on/off also, but Almost never use it.
My goal is to make my house smart, in my opinion that means the house should know when to switch on/off the alarm so a panel is not needed.
- elzorrovega
- Domoticz version: 2024.7
I am using a simple Z-Wave compatible keypad which I inherited from my old alarm system. It very simple for it has two settings: home and away. One toggles between them with either a four digit code or keys linked to panel. I attached the user documentation downloaded from internet.
It does not have any fancy LED interface but it works for me.
regards
Zipato MINI KEYPAD RFiD/Z-WAV
regards
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bullseye -64 bit OS 6.1.21-v8+ #1642
Domoticz Version: 2024.7
zwave-js-ui: 9.30.1.46a9eda
zwave-js: 14.3.8
home id: 3714679688
home hex: 0xdd698388*
zwave-js: 14.3.8
home id: 3714679688
