What hardware do you use for the Security Panel?
mrbrown38
Post by mrbrown38 »
I've done some searching and am wondering how folks have implemented use of the Security Panel? I was looking for a simple Z-Wave security panel, but didn't find many solutions. I've seen HA use an Android with a MQTT application to use the security panel.
I was wanting to use a Raspberry Pi with a keypad and LED status screen, but I wasn't finding any easy solutions to make that happen. I was also thinking a touch screen that showed the security panel URL might be a route to go down as well. My main reason for wanting to stick with a rPi is because I also want to run Node-Red for BLE scanning. Also wanting to stay away from anything that is cloud connected.
Would love to hear how others have implemented this.
mrbrown38
Re: What hardware do you use for the Security Panel?
Post by mrbrown38 »
Is there no one using the security panel feature of Domoticz?
Lokonli
Post by Lokonli »
Within Dashticz you can add a security panel linked to the Domoticz security status.
See https://dashticz.readthedocs.io/en/mast ... panel.html
mrbrown38
Post by mrbrown38 »
What hardware do people typically use though? That's just another way to display the web page version right?
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
I have bought a rfid panel at aliexpress
something like this;
https://nl.aliexpress.com/item/32916658 ... hweb201603_
then couple this to a smart implant from fibaro and you have what you want.
succes
Jan
ronaldbro
Post by ronaldbro »
My alarm is switch on for at home mode in my goodnight scene and is automatically switched off in the morning when someone is at home.
For away mode I use either HomeKit/Siri and the alarm is switched off when arriving back home.
As backup I have a hidden Xioami button with which I can switch it on/off also, but Almost never use it.
My goal is to make my house smart, in my opinion that means the house should know when to switch on/off the alarm so a panel is not needed.
elzorrovega
Domoticz version: 2025.2
Post by elzorrovega »
I am using a simple Z-Wave compatible keypad which I inherited from my old alarm system. It very simple for it has two settings: home and away. One toggles between them with either a four digit code or keys linked to panel. I attached the user documentation downloaded from internet.
It does not have any fancy LED interface but it works for me.
regards
Zipato MINI KEYPAD RFiD/Z-WAV
Zipato RFID Keypad.pdf
(232.63 KiB) Downloaded 160 times
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
