create DzVents script based on Smoke Alarm Fibaro Smoke 2  [Solved]
Re: create DzVents script based on Smoke Alarm Fibaro Smoke 2
Ragdag wrote: Thursday 04 June 2020 16:08 Yours also works but the lastupdate can be removed as that is no longer needed since that switch is only triggered once.
Thx for the feedback.
that means that
if ( item.state == 'On' and item.lastUpdate.secondsAgo > 60 ) or item.state == 'Off'  then
            pushover(PushoverUsers.USER1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm ' .. item.alarmText .. '\nStatus: ' .. dz.devices(item.alarmDevice).state, 1, 'siren' )
can become
Ragdag
Post by Ragdag »
waaren wrote: Thursday 04 June 2020 16:16
that means that
can become
I guess so indeed :)
Ragdag
Post by Ragdag »
As always Home Automation is never as straight forward as hoped :)
Got an Alarm today through Pushover but only for a Clear not an actual Smoke alert.
It looks like the switch updated its status but did not change anything.
Switch log
In Devices I do see a last update time of the switch in question
I might need to move the trigger to idx 319 as that still has the same changed time as the actual Alarm tests
Domoticz Log
2020-06-05 13:51:54.596 Status: dzVents: Info: FireAlarm: ------ Start internal script: DZ_FireAlarm: Device: "$Smoke Alarm - Overloop (Z-wave)", Index: 320
2020-06-05 13:51:54.597 Status: dzVents: Debug: FireAlarm: Processing device-adapter for $Smoke Alarm - Schuur: Switch device adapter
2020-06-05 13:51:54.598 Status: dzVents: Debug: FireAlarm: OpenURL: url = https://api.pushover.net/1/messages.json
2020-06-05 13:51:54.598 Status: dzVents: Debug: FireAlarm: OpenURL: method = POST
2020-06-05 13:51:54.598 Status: dzVents: Debug: FireAlarm: OpenURL: post data = {"message":"Brand Alarm Overloop\nStatus: Clear","priority":1,"sound":"siren","title":"Brand Alarm","token":"aaa","user":"bbb"}
2020-06-05 13:51:54.598 Status: dzVents: Debug: FireAlarm: OpenURL: headers = {["Content-Type"]="application/json"}
2020-06-05 13:51:54.598 Status: dzVents: Debug: FireAlarm: OpenURL: callback = FireAlarm
2020-06-05 13:51:54.599 Status: dzVents: Info: FireAlarm: ------ Finished DZ_FireAlarm
Also a weird log entry
The idx that triggered was the Overloop
Ragdag
Post by Ragdag »
that means that
can become
Is there a way to check a switches previous state to see if it actually toggled from off to on?
I'll probably need to work with persistent variable for the 3 switches
Ragdag wrote: Saturday 06 June 2020 10:42 Is there a way to check a switches previous state to see if it actually toggled from off to on?
No
Yes persistent variables or use virtual devices in your script. In pseudo code something like:
on =
{ actualswitches }
if virtualSwitch.state ~= actualSwitch.state then
    virtualSwitch.toggleSwitch()
    otherActions based on new state
  noAction needed
Ragdag
Post by Ragdag »
waaren wrote: Saturday 06 June 2020 11:07
No
on =
{ actualswitches }
  noAction needed
Man as always you are fast :D
I went with the Persistant variables
could you do a sanity check of my code :)
local scriptVar = 'FireAlarm'
return
    on =
        devices =
            303, -- Schuur
            320, -- Overloop
            330, -- Zolder
    data =
        lastStateSchuur = { initial = '' },
        lastStateOverloop = { initial = '' },
        lastStateZolder = { initial = '' },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
	execute = function(dz, item)
        if item.isHTTPResponse then
            dz.log(item.data,dz.LOG_DEBUG)
            return
        local function pushover(PushoverUser, PushoverApp, title, message, priority, sound)
            dz.openURL({
                url = 'https://api.pushover.net/1/messages.json',
                method = 'POST',
                callback = scriptVar,
                postData =
                    token = PushoverApp.token,
                    user =  PushoverUser.key,
                    message = message,
                    title = title or 'Pushover from dzVents',
                    priority = priority or 0,
                    sound = sound or 'echo',
        local PushoverUsers =
            ['User1'] = { ['key'] = 'aaa' },
            ['User2'] = { ['key'] = 'bbb'},
            ['Familie'] = { ['key'] = 'ccc'},
        local PushoverApps =
            ['Domoticz'] = { ['token'] = 'ddd' },
            ['Huis'] = { ['token'] = 'eee' },
            ['Test'] = { ['token'] = 'fff' },
            ['Was'] = { ['token'] = 'ggg' },
            ['Alarm'] = { ['token'] = 'hhh' },
        if item == dz.devices(303) then
            if dz.devices(303).state ~= dz.data.lastStateSchuur then
                item.alarmDevice = 336
                item.alarmText = 'Schuur'
                dz.log('Schuur current State: ' .. dz.devices(303).state, dz.LOG_DEBUG)
                dz.log('Schuur previous State: ' .. dz.data.lastStateSchuur, dz.LOG_DEBUG)
                dz.data.lastStateSchuur = dz.devices(303).state
                dz.log('Nothing to do with Schuur', dz.LOG_DEBUG)
                return
        elseif item == dz.devices(320) then
            if dz.devices(320).state ~= dz.data.lastStateOverloop then
                item.alarmDevice = 326
                item.alarmText = 'Overloop'
                dz.log('Overloop current State: ' .. dz.devices(303).state, dz.LOG_DEBUG)
                dz.log('Overloop previous State: ' .. dz.data.lastStateSchuur, dz.LOG_DEBUG)
                dz.data.lastStateOverloop = dz.devices(320).state
                dz.log('Nothing to do with Overloop', dz.LOG_DEBUG)
                return
        elseif item == dz.devices(330) then
            if dz.devices(330).state ~= dz.data.lastStateZolder then
                item.alarmDevice = 329
                item.alarmText = 'Zolder'
                dz.log('Zolder current State: ' .. dz.devices(303).state, dz.LOG_DEBUG)
                dz.log('Zolder previous State: ' .. dz.data.lastStateSchuur, dz.LOG_DEBUG)
                dz.data.lastStateZolder = dz.devices(330).state
                dz.log('Nothing to do with Zolder', dz.LOG_DEBUG)
                return
            dz.log('Unknown device', dz.LOG_ERROR)
            return
        pushover(PushoverUsers.User1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm ' .. item.alarmText .. '\nStatus: ' .. dz.devices(item.alarmDevice).state, 1, 'siren' )
Ragdag wrote: Saturday 06 June 2020 11:19 I went with the Persistant variables
Looks good !
Not sure if the extra comma before logging is going to cause an error but you wil see it quickly enough..
Matter of personal preference but I don't like repeating (allmost) the same code lines when it can be prevented.
So I would do it like below.
return
    on =
        devices =
            303, -- Schuur
            320, -- Overloop
            330, -- Zolder
    data =
    logging =
        marker = scriptVar,
            dz.openURL({
                method = 'POST',
                postData =
                    message = message,
        local schuur = dz.devices(303)
        local overloop = dz.devices(320)
        local zolder = dz.devices(319)
        schuur.alarmDevice = 336
        schuur.alarmText = 'Schuur'
        overloop.alarmDevice = 326
        overloop.alarmText = 'Overloop'
        zolder.alarmDevice = 329
        zolder.alarmText = 'Zolder'
        local lastState = 'lastState' .. item.alarmText
        if item.state ~= dz.data[lastState] then
            dz.log(item.alarmText .. ' current State: ' .. item.state, dz.LOG_DEBUG)
            dz.log(item.alarmText .. ' previous State: ' .. dz.data[lastState], dz.LOG_DEBUG)
            dz.data[lastState] = item.state
            dz.log('Nothing to do with ' .. item.alarmText, dz.LOG_DEBUG)
Ragdag
Post by Ragdag »
Yours look again a lot more elegant.
What is the reason you don't define these as local?
Ragdag wrote: Saturday 06 June 2020 12:12 What is the reason you don't define these as local?
:oops: Forgot
Ragdag
Post by Ragdag »
waaren wrote: Saturday 06 June 2020 12:16
:oops: Forgot
So they should be local :P
Will give yours a try
Ragdag wrote: Saturday 06 June 2020 12:25 So they should be local :P
No these are just attributes of already declared tables. They need to stay as they are !
