create DzVents script based on Smoke Alarm Fibaro Smoke 2  [Solved]
Ragdag
Post by Ragdag »
I have several Fibaro Smoke Sensors, and I am using those as temperature sensor.
I'm looking into if it is possible to kick of a DzVents script based on a smoke alarm
When I manuall trigger the sensor I see this in the logs
2020-06-02 13:45:41.671 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-02 13:45:41.684 (Z-wave) Light/Switch (Smoke Alarm)
2020-06-02 13:45:41.668 Status: OpenZWave: Alarm received (Smoke Alarm: Smoke Test), NodeID: 12 (0x0c)
2020-06-02 13:45:53.681 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-02 13:45:53.688 (Z-wave) Light/Switch (Smoke Alarm)
2020-06-02 13:45:53.674 Status: OpenZWave: Alarm received (Smoke Alarm: Clear), NodeID: 12 (0x0c)
Also I see these Devices under the Sensor
Is there a way to pick up Alarm Type: Smoke Alarm 1 (0x01) in DzVents?
Re: create DzVents script based on Smoke Alarm Fibaro Smoke 2
Ragdag wrote: Tuesday 02 June 2020 14:04 I have several Fibaro Smoke Sensors, and I am using those as temperature sensor.
I don't know for sure but you can use below script to check what devices are picked up by dzVents.
local myAlarm = { 319,320,320,321,322,323,324,325,326,327}
return
    on =
        devices = myAlarm,
    logging =
        level = domoticz.LOG_INFO,
    execute = function(dz, item)
        dz.log('Device ' .. item.name .. ' (' .. item.idx .. ') triggered this script', dz.LOG_INFO)
        for _, idx in ipairs(myAlarm) do
            local device = dz.devices(idx)
            if dz.utils.deviceExists(idx) then
                dz.log('Device ' .. device.name .. ' (' .. device.idx .. ') state: ' .. device.state .. '; last Updated: ' .. device.lastUpdate.rawDateTime, dz.LOG_INFO)
Ragdag
Post by Ragdag »
I would probably need to add them all first right?
Only Temp is added at the moment
After that I would need to trigger another smoke alarm?
Ragdag wrote: Tuesday 02 June 2020 16:10 I would probably need to add them all first right?
Yes. ( They are easy to inactivate afterwards if / when no longer needed.)
Yes
Ragdag
Post by Ragdag »
That does give us some insight :)
2020-06-02 16:35:54.115 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-02 16:35:54.132 (Z-wave) Light/Switch (Smoke Alarm)
2020-06-02 16:35:54.284 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Alarm Type: Smoke Alarm 1 (0x01) (Z-wave)", Index: 326
2020-06-02 16:35:54.284 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) triggered this script
2020-06-02 16:35:54.285 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:35:54.286 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.287 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.288 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:35:54.289 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:35:54.290 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:35:54.291 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:35:54.292 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:35:54.292 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Smoke Test; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.293 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:35:54.293 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:35:54.387 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Smoke Alarm (Z-wave)", Index: 320
2020-06-02 16:35:54.387 Status: dzVents: Info: Device Smoke Alarm (320) triggered this script
2020-06-02 16:35:54.388 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:35:54.389 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.389 Status: dzVents: Info: Device Smoke Alarm (320) state: On; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.390 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:35:54.391 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:35:54.392 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:35:54.393 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:35:54.394 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:35:54.395 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Smoke Test; last Updated: 2020-06-02 16:35:54
2020-06-02 16:35:54.395 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:35:54.396 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:35:54.396 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Smoke Alarm (Z-wave)", Index: 320
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Smoke Alarm (320) triggered this script
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Smoke Alarm (320) state: On; last Updated: 2020-06-02 13:56:44
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:35:54.396 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:35:54.396 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Smoke Test; last Updated: 2020-06-02 16:35:54
2020-06-02 16:35:54.396 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:35:57.696 (Power-Gas) P1 Smart Meter (kWh Totaal)
2020-06-02 16:36:07.699 (Power-Gas) P1 Smart Meter (kWh Totaal)
2020-06-02 16:36:15.314 (Z-wave) Light/Switch (Sensor)
2020-06-02 16:36:15.330 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-02 16:36:15.345 (Z-wave) Light/Switch (Smoke Alarm)
2020-06-02 16:36:15.690 (Z-wave) Temp (Temp Overloop)
2020-06-02 16:36:15.307 Status: OpenZWave: Alarm received (Smoke Alarm: Clear), NodeID: 12 (0x0c)
2020-06-02 16:36:15.453 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Sensor (Z-wave)", Index: 319
2020-06-02 16:36:15.453 Status: dzVents: Info: Device Sensor (319) triggered this script
2020-06-02 16:36:15.454 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:36:15.454 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-06-02 13:56:44
2020-06-02 16:36:15.455 Status: dzVents: Info: Device Smoke Alarm (320) state: On; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:15.456 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.457 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.458 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.459 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.459 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.460 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Smoke Test; last Updated: 2020-06-02 16:35:54
2020-06-02 16:36:15.461 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.461 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:36:15.558 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Smoke Alarm (Z-wave)", Index: 320
2020-06-02 16:36:15.558 Status: dzVents: Info: Device Smoke Alarm (320) triggered this script
2020-06-02 16:36:15.559 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:36:15.560 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-05-24 16:31:46
2020-06-02 16:36:15.560 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:15.561 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:15.561 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.562 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.563 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.564 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.565 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.566 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Clear; last Updated: 2020-06-02 16:35:54
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.567 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:36:15.567 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Smoke Alarm (Z-wave)", Index: 320
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Smoke Alarm (320) triggered this script
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-05-24 16:31:46
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.567 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.567 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.568 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Clear; last Updated: 2020-06-02 16:35:54
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.568 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:36:15.568 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Alarm Type: Smoke Alarm 1 (0x01) (Z-wave)", Index: 326
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) triggered this script
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Temp Overloop (185) state: 26.1; last Updated: 2020-06-02 16:22:23
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-05-24 16:31:46
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.568 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.569 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.569 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.569 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.569 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Clear; last Updated: 2020-06-02 16:35:54
2020-06-02 16:36:15.569 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.569 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:36:15.775 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Temp Overloop (Z-wave)", Index: 185
2020-06-02 16:36:15.775 Status: dzVents: Info: Device Temp Overloop (185) triggered this script
2020-06-02 16:36:15.775 Status: dzVents: Info: Device Temp Overloop (185) state: 26.4; last Updated: 2020-06-02 16:22:23
2020-06-02 16:36:15.776 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-05-24 16:31:46
2020-06-02 16:36:15.777 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:15.778 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.779 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.780 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.781 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:15.781 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:15.782 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Clear; last Updated: 2020-06-02 16:36:15
2020-06-02 16:36:15.783 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:15.783 Status: dzVents: Info: ------ Finished DZ_Test
2020-06-02 16:36:17.693 (Z-wave) General/kWh (kWh Droger)
2020-06-02 16:36:17.713 (Power-Gas) P1 Smart Meter (kWh Totaal)
2020-06-02 16:36:24.079 (Z-wave) Temp (Temp Overloop)
2020-06-02 16:36:24.217 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Temp Overloop (Z-wave)", Index: 185
2020-06-02 16:36:24.217 Status: dzVents: Info: Device Temp Overloop (185) triggered this script
2020-06-02 16:36:24.217 Status: dzVents: Info: Device Temp Overloop (185) state: 26.5; last Updated: 2020-06-02 16:36:15
2020-06-02 16:36:24.218 Status: dzVents: Info: Device Sensor (319) state: Off; last Updated: 2020-05-24 16:31:46
2020-06-02 16:36:24.219 Status: dzVents: Info: Device Smoke Alarm (320) state: Off; last Updated: 2020-05-25 19:20:50
2020-06-02 16:36:24.220 Status: dzVents: Info: Device Heat (321) state: Off; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:24.221 Status: dzVents: Info: Device Home Security (322) state: On; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:24.222 Status: dzVents: Info: Device Power Management (323) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:24.223 Status: dzVents: Info: Device System (324) state: Off; last Updated: 2020-06-02 13:45:00
2020-06-02 16:36:24.223 Status: dzVents: Info: Device General (325) state: On; last Updated: 2020-06-02 13:54:20
2020-06-02 16:36:24.224 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Clear; last Updated: 2020-06-02 16:36:15
2020-06-02 16:36:24.225 Status: dzVents: Info: Device Alarm Type: Home Security 7 (0x07) (327) state: Tampering - Cover Removed; last Updated: 2020-06-02 13:54:19
2020-06-02 16:36:24.225 Status: dzVents: Info: ------ Finished DZ_Test
Ragdag wrote: Tuesday 02 June 2020 16:36 That does give us some insight :)
With this you should have enough information to build a dzVents script with actions based on the various states of device 326
Ragdag
Post by Ragdag »
I'm a bit stuck.
Yours obviously worked
return
    on =
        devices = myAlarm,
    logging =
This is the log entry from you script
2020-06-03 12:33:36.765 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-03 12:33:36.783 (Z-wave) Light/Switch (Smoke Alarm)
2020-06-03 12:33:36.742 Status: OpenZWave: Alarm received (Smoke Alarm: Smoke Test), NodeID: 12 (0x0c)
2020-06-03 12:33:36.906 Status: dzVents: Info: ------ Start internal script: DZ_Test: Device: "Alarm Type: Smoke Alarm 1 (0x01) (Z-wave)", Index: 326
2020-06-03 12:33:36.906 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) triggered this script
2020-06-03 12:33:36.907 Status: dzVents: Info: Device Alarm Type: Smoke Alarm 1 (0x01) (326) state: Smoke Test; last Updated: 2020-06-03 12:29:09
2020-06-03 12:33:36.908 Status: dzVents: Info: ------ Finished DZ_Test
When I try to incorporate that in my script it is not even triggered.
local scriptVar = 'FIREALARM'
local myAlarm = { 326,329,336}
return
	on =
		devices =
            myAlarm,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
        if item.isHTTPResponse then
            dz.log(item.data,dz.LOG_DEBUG)
            return
        local function pushover(PushoverUser, PushoverApp, title, message, priority, sound)
            dz.openURL({
                url = 'https://api.pushover.net/1/messages.json',
                method = 'POST',
                callback = scriptVar,
                postData =
                    token = PushoverApp.token,
                    user =  PushoverUser.key,
                    message = message,
                    title = title or 'Pushover from dzVents',
                    priority = priority or 0,
                    sound = sound or 'echo',
        local PushoverUsers =
            ['USER1'] = { ['key'] = 'aaa' },
            ['USER2'] = { ['key'] = 'bbb'},
            ['Familie'] = { ['key'] = 'ccc'},
        local PushoverApps =
            ['Domoticz'] = { ['token'] = 'ddd' },
            ['Huis'] = { ['token'] = 'eee' },
            ['Test'] = { ['token'] = 'fff' },
            ['Was'] = { ['token'] = 'ggg' },
            ['Alarm'] = { ['token'] = 'hhh' },
        dz.log('Device ' .. item.name .. ' (' .. item.idx .. ') triggered this script', dz.LOG_DEBUG)
				dz.log('Device ' .. device.name .. ' (' .. device.idx .. ') state: ' .. device.state .. '; last Updated: ' .. device.lastUpdate.rawDateTime, dz.LOG_DEBUG)
				pushover(PushoverUsers.USER1, PushoverApps.Alarm, 'Brand Alarm', 'Device ' .. device.name .. ' state: ' .. device.state, 1, 'siren' )
Ragdag wrote: Wednesday 03 June 2020 12:41 I'm a bit stuck.
myAlarm is already a table so the extra pair of {} do not work
try:
	on =
		devices = myAlarm,
Ragdag
Post by Ragdag »
waaren wrote: Wednesday 03 June 2020 15:58
try:
	on =
		devices = myAlarm,
This is already much better :)
I'm getting messages through PushOver but it seems that it is repeating the alerts each time the alarm sounds during a test
Need to figure out how to weed those out.
PS: Is there a way for the log in Domoticz not to roll over so fast?
My log rolls over in about 20 minutes
Ragdag wrote: Thursday 04 June 2020 13:11 This is already much better :)
can you try changing
to
if device.lastUpdate.secondsAgo > 60 then
I log to an os.file() ( You can do that by modifying /etc/init.d/domoticz.sh and restart domoticz )
and after archiving it once a day, I start with an empty one. (using sudo truncate -s 0 /var/log/domoticz.log)
Ragdag
Post by Ragdag »
waaren wrote: Thursday 04 June 2020 13:35
to
There also seems to be a switch associated with the Smoke Alarm
If I view the logging there it seems to only fire once when the alarm is triggered and switching off when it is done.
So I think I use that one as a hidden Switch to trigger the PushOver alert and then read the Alarm State for the message.
Weird thing here is that it somehow attaches the switch action to the user of my wife :?: while it is only triggered directly through the Smoke Sensor
On the logging, won't logging to SD Card wear out my SD card really fast?
Ragdag wrote: Thursday 04 June 2020 13:44 On the logging, won't logging to SD Card wear out my SD card really fast?
Faster then without but I never had any corrupt SD card during the years I still used SD cards for this. If you do a quick search in this forum you will find that there are many opinions on the topic and also a lot of creative alternatives.
Ragdag
Post by Ragdag »
waaren wrote: Thursday 04 June 2020 13:54
Thanks, will take a stab at that.
Just tested with my revised script but it also looks trips multiple times using the switch.
It does not make sense for me since I do not see the switch being sent multiple times in the log
It triggers at 14:13:15.652 and that triggers 3 devices.
Then at 14:13:27.723 it finished the test and holds the alarm and switches off the 3 devices
2020-06-04 14:13:15.652 (Z-wave) Light/Switch (Sensor)
2020-06-04 14:13:15.665 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-04 14:13:15.682 (Z-wave) Light/Switch (Smoke Alarm - Overloop)
2020-06-04 14:13:15.649 Status: OpenZWave: Alarm received (Smoke Alarm: Smoke Test), NodeID: 12 (0x0c)
2020-06-04 14:13:15.896 Status: dzVents: Info: FireAlarm: ------ Start internal script: DZ_FireAlarm_v2: Device: "Smoke Alarm - Overloop (Z-wave)", Index: 320
2020-06-04 14:13:15.897 Status: dzVents: Debug: FireAlarm: Processing device-adapter for $Smoke Alarm - Schuur: Switch device adapter
2020-06-04 14:13:15.898 Status: dzVents: Debug: FireAlarm: Processing device-adapter for $Smoke Alarm - Zolder: Switch device adapter
2020-06-04 14:13:15.901 Status: dzVents: Debug: FireAlarm: OpenURL: url = https://api.pushover.net/1/messages.json
2020-06-04 14:13:15.901 Status: dzVents: Debug: FireAlarm: OpenURL: method = POST
2020-06-04 14:13:15.901 Status: dzVents: Debug: FireAlarm: OpenURL: post data = {"message":"Brand Alarm Schuur\nStatus: Clear","priority":1,"sound":"siren","title":"Brand Alarm","token":"bbb","user":"aaa"}
2020-06-04 14:13:15.901 Status: dzVents: Debug: FireAlarm: OpenURL: headers = {["Content-Type"]="application/json"}
2020-06-04 14:13:15.901 Status: dzVents: Debug: FireAlarm: OpenURL: callback = FireAlarm
2020-06-04 14:13:15.901 Status: dzVents: Debug: FireAlarm: OpenURL: post data = {"message":"Brand Alarm Schuur\nStatus: Smoke Test","priority":1,"sound":"siren","title":"Brand Alarm","token":"bbb","user":"aaa"}
2020-06-04 14:13:15.902 Status: dzVents: Debug: FireAlarm: OpenURL: callback = FireAlarm
2020-06-04 14:13:15.902 Status: dzVents: Info: FireAlarm: ------ Finished DZ_FireAlarm_v2
2020-06-04 14:13:19.512 (Power-Gas) P1 Smart Meter (kWh Totaal)
2020-06-04 14:13:26.175 (Z-wave) Temp (Temp Overloop)
2020-06-04 14:13:27.013 (Z-wave) Usage (Unknown)
2020-06-04 14:13:27.023 (Z-wave) General/kWh (kWh Wasmachine)
2020-06-04 14:13:27.723 (Z-wave) Light/Switch (Sensor)
2020-06-04 14:13:27.729 (Z-wave) General/Alarm (Alarm Type: Smoke Alarm 1 (0x01))
2020-06-04 14:13:27.737 (Z-wave) Light/Switch (Smoke Alarm - Overloop)
2020-06-04 14:13:27.720 Status: OpenZWave: Alarm received (Smoke Alarm: Clear), NodeID: 12 (0x0c)
2020-06-04 14:13:27.975 Status: dzVents: Info: FireAlarm: ------ Start internal script: DZ_FireAlarm_v2: Device: "Smoke Alarm - Overloop (Z-wave)", Index: 320
2020-06-04 14:13:27.976 Status: dzVents: Debug: FireAlarm: Processing device-adapter for $Smoke Alarm - Schuur: Switch device adapter
2020-06-04 14:13:27.976 Status: dzVents: Debug: FireAlarm: Processing device-adapter for $Smoke Alarm - Zolder: Switch device adapter
2020-06-04 14:13:27.979 Status: dzVents: Debug: FireAlarm: OpenURL: url = https://api.pushover.net/1/messages.json
2020-06-04 14:13:27.979 Status: dzVents: Debug: FireAlarm: OpenURL: method = POST
2020-06-04 14:13:27.979 Status: dzVents: Debug: FireAlarm: OpenURL: post data = {"message":"Brand Alarm Schuur\nStatus: Clear","priority":1,"sound":"siren","title":"Brand Alarm","token":"bbb","user":"aaa"}
2020-06-04 14:13:27.979 Status: dzVents: Debug: FireAlarm: OpenURL: headers = {["Content-Type"]="application/json"}
2020-06-04 14:13:27.979 Status: dzVents: Debug: FireAlarm: OpenURL: callback = FireAlarm
2020-06-04 14:13:27.980 Status: dzVents: Debug: FireAlarm: OpenURL: url = https://api.pushover.net/1/messages.json
2020-06-04 14:13:27.980 Status: dzVents: Debug: FireAlarm: OpenURL: method = POST
2020-06-04 14:13:27.980 Status: dzVents: Debug: FireAlarm: OpenURL: post data = {"message":"Brand Alarm Schuur\nStatus: Clear","priority":1,"sound":"siren","title":"Brand Alarm","token":"bbb","user":"aaa"}
2020-06-04 14:13:27.980 Status: dzVents: Debug: FireAlarm: OpenURL: headers = {["Content-Type"]="application/json"}
2020-06-04 14:13:27.980 Status: dzVents: Debug: FireAlarm: OpenURL: callback = FireAlarm
2020-06-04 14:13:27.980 Status: dzVents: Info: FireAlarm: ------ Finished DZ_FireAlarm_v2
Somehow in the DzVents script is triggered 6 times while the switch that triggers the DzVents is only switched 2 times
Here is my current script
local scriptVar = 'FireAlarm'
return
    on =
        devices =
            303, -- Schuur
            320, -- Overloop
            330, -- Zolder
    logging =
        marker = scriptVar,
            return
            dz.openURL({
                method = 'POST',
                postData =
                    message = message,
        local SchuurSmokeSwitch = dz.devices(303)
        local OverloopSmokeSwitch = dz.devices(320)
        local ZolderSmokeSwitch = dz.devices(330)
        local SchuurSmokeAlarm = dz.devices(336)
        local OverloopSmokeAlarm = dz.devices(326)
        local ZolderSmokeAlarm = dz.devices(329)
        if (item.isDevice) then
            if (SchuurSmokeSwitch.state == 'On') then
                pushover(PushoverUsers.USER1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm Schuur\nStatus: ' .. SchuurSmokeAlarm.state, 1, 'siren' )
            elseif (SchuurSmokeSwitch.state == 'Off') then
            if (OverloopSmokeSwitch.state == 'On') then
                pushover(PushoverUsers.USER1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm Overloop\nStatus: ' .. OverloopSmokeAlarm.state, 1, 'siren' )
            elseif (OverloopSmokeSwitch.state == 'Off') then
            if (ZolderSmokeSwitch.state == 'On') then
                pushover(PushoverUsers.USER1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm Zolder\nStatus: ' .. ZolderSmokeAlarm.state, 1, 'siren' )
            elseif (ZolderSmokeSwitch.state == 'Off') then
Ragdag wrote: Thursday 04 June 2020 14:28 Somehow in the DzVents script is triggered 6 times while the switch that triggers the DzVents is only switched 2 times
The log is lying :D
See this issue (Also applicable for standard switches)
I still think that the
approach should provide you with a workable solution
Ragdag
Post by Ragdag »
waaren wrote: Thursday 04 June 2020 14:35
The log is lying :D
But wouldn't the log still have z-wave commands for the switches being triggered as all z-wave commands are logged, can understand in the Switch GUI log that it is truncated.
I'll give that a try with the last updatetime :)
Ragdag
Post by Ragdag »
Hold on I now see the problem :D
The logic I have is this
                pushover(PushoverUsers.User1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm Schuur\nStatus: ' .. SchuurSmokeAlarm.state, 1, 'siren' )
                pushover(PushoverUsers.User1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm Overloop\nStatus: ' .. OverloopSmokeAlarm.state, 1, 'siren' )
                pushover(PushoverUsers.User1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm Zolder\nStatus: ' .. ZolderSmokeAlarm.state, 1, 'siren' )
When 1 switch is triggered it will evaluate all if statements and fire off the respective messages resulting in 6 messages.
Is there a way to only evaluated the if statement for the device that triggers the script?
Would it help if I moved the (item.isDevice) into the separate if statments?
Ragdag wrote: Thursday 04 June 2020 14:57 Hold on I now see the problem :D
Can you try this ?
return
    on =
        devices =
            303, -- Schuur
            320, -- Overloop
            330, -- Zolder
    logging =
        marker = scriptVar,
            return
            dz.openURL({
                method = 'POST',
                postData =
                    message = message,
        if item == dz.devices(303) then
            item.alarmDevice = 336
            item.alarmText = 'Schuur'
        elseif item == dz.devices(320) then
            item.alarmDevice = 326
            item.alarmText = 'Overloop'
        elseif item == dz.devices(330) then
            item.alarmDevice = 329
            item.alarmText = 'Zolder'
            dz.log('Unknown device', dz.LOG_ERROR)
            return
        if ( item.state == 'On' and item.lastUpdate.secondsAgo > 60 ) or item.state == 'Off'  then
            pushover(PushoverUsers.USER1, PushoverApps.Alarm, 'Brand Alarm', 'Brand Alarm ' .. item.alarmText .. '\nStatus: ' .. dz.devices(item.alarmDevice).state, 1, 'siren' )
Ragdag
Re: create DzVents script based on Smoke Alarm Fibaro Smoke 2  [Solved]
Post by Ragdag »
Figured it out with the help of this thread https://www.domoticz.com/forum/viewtopi ... pt#p248557
This is now the complete script
return
    on =
        devices =
            303, -- Schuur
            320, -- Overloop
            330, -- Zolder
    logging =
        marker = scriptVar,
            return
            dz.openURL({
                method = 'POST',
                postData =
                    message = message,
            if (item == SchuurSmokeSwitch) then
            if (item == OverloopSmokeSwitch) then
            if (item == ZolderSmokeSwitch) then
With this beautiful result
waaren, again thank you for you help and support!
EDIT:
I now see that you suggested a similar approach but yours seems to be more intelligent :)
Ragdag wrote: Thursday 04 June 2020 15:27 I now see that you suggested a similar approach.
I updated my last post just yet. Can you please test the latest version?
Ragdag
Post by Ragdag »
waaren wrote: Thursday 04 June 2020 15:36
Yours also works but the lastupdate can be removed as that is no longer needed since that switch is only triggered once.
Since your script is more elegant than mine I will use that one :)
