GoodWe Solar: get data from the new semsportal (lua script)
franzel
Domoticz version: 20.2
Re: GoodWe Solar: get data from the new semsportal (lua script)
Post by franzel »
I use the LUA script since some months and AFAIK in most cases the script works ok.
In the previous Domoticz version most, if not all devices seem to work properly so there was no need to look at the logfile and therefor I hardly ever checked the log so I didn’t notice whether there actually were errors. From te moment I reinstalled my PI with the 2020.2 Version I experienced some issues so to try to solve these issues I checked the log much more then before. From that moment I noticed errors like this.
2020-05-24 23:55:10.329 Error: EventSystem: Warning!, lua script Opbrengst has been running for more than 10 seconds
2020-05-25 00:13:10.058 Error: EventSystem: Warning!, lua script Opbrengst has been running for more than 10 seconds
2020-05-25 00:55:10.073 Error: EventSystem: Warning!, lua script Opbrengst has been running for more than 10 seconds
2020-05-25 04:37:10.238 Error: EventSystem: Warning!, lua script Opbrengst has been running for more than 10 seconds
I still think that the script shows the proper values but I still wonder where these errors come from.
Frans
franzel
Post by franzel »
Has all the support on this board vanished or has noone an idea what be the cause of this? :(
bofisko
Post by bofisko »
HI
Can you help me. How can I get tokken. I I tried it but it is not working. [DEBUG] 06:55:04: 2020-12-27 06:55:04.312152 [ fatal] Unknown exception: /opt/fibaro/scenes/29.lua:82: attempt to index global 'otherdevices_lastupdate' (a nil value)
CrazyFrog
Post by CrazyFrog »
I will look into it, i use macos.
Give me some time to find it out
Mareg
Post by Mareg »
Hello, thanks for the script!
But I have a question - there isn't a way to get data directly from inverter?
There isn't an API on the inverter interface?
Mareg
fojtp
Post by fojtp »
Mareg wrote: Sunday 04 April 2021 17:45 Hello, thanks for the script!
Mareg
this works for me:
https://github.com/mletenay/home-assist ... e-inverter
script: inverter_test.py
franzel
Post by franzel »
Version: 2021.1
Build Hash: 8547c5b7e
Compile Date: 2021-04-17 17:29:11
dzVents Version: 3.1.7
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
The Lua script from Raymond has worked flawlessly until some weeks ago. Some days showed a negative revenue of my solarpanels where the data from Semsportal is ok. I added some pictures.
Anyone knows what goes wrong in my situation?
