Daikin blockly
Bospieper
Domoticz version: 2022.1
Daikin blockly
Post by Bospieper »
I am using a simple blockly program for controlling my Daikin airco. The program has four timing schedules. The first switch on the airco in de mode cooling and with a Fan Rate, the second schedule sets the Fan Rate to a lower level, the third schedule switches from cooling to fan with the Fan Rate Silence and fourth schedule switches off the airco for a period of time. Every night my Domoticz service exited (is stopped) around the same time as the airco switches from cooling to fan. I've ruled out other possibilities in stopping the Domoticz service so my guess is that there is something in my blockly program that causes Domoticz to stop. Perhaps there is someone who could help me with this problem.
P.S I have a similar blockly running for switching on bathroom light after moving detection with different light strengths
Blokly Daikin.JPG (84.31 KiB) Viewed 910 times
Egregius
Domoticz version: v2024.7
Re: Daikin blockly
Post by Egregius »
Your first else if can never be true.
Bospieper
Re: Daikin blockly
Post by Bospieper »
Hello, can you explain a bit more?
Egregius
Re: Daikin blockly
Post by Egregius »
It can never be later than 23:45 AND before 3:00, you need to use OR for this one.
Besides that, that can't cause the crash. Why does your system restart at 3:00?
Bospieper
Re: Daikin blockly
Post by Bospieper »
It's the reason why I posted this question. I've ruled out other possibilities. The Daikin blockly makes the domoticz service to stop at 03:00 so it's not restarting only domoticz stops.
I wil test your answer and let you know the result, thanx
Egregius
Re: Daikin blockly
Post by Egregius »
So if you disable this blockly your service doesn't stop?
What's in the logfile at that moment?
Bospieper
Re: Daikin blockly
Post by Bospieper »
Yes I have several blockly programs running and only when I am disable the Daikin program the Domoticz service keeps running.
Which of the logfiles in Domoticz you need?
Egregius
Re: Daikin blockly
Post by Egregius »
To my knowledge there's only one domoticz logfile...
Bospieper
Re: Daikin blockly
Post by Bospieper »
This is the crash log from 01:15. The event log is empty after the domoticz service is stopped.
[New LWP 13415]
[New LWP 13420]
[New LWP 13422]
[New LWP 13423]
[New LWP 13424]
[New LWP 13425]
[New LWP 13426]
[New LWP 13427]
[New LWP 13428]
[New LWP 13429]
[New LWP 13430]
[New LWP 13431]
[New LWP 13440]
[New LWP 13441]
[New LWP 13442]
[New LWP 13443]
[New LWP 13444]
[New LWP 13445]
[New LWP 13446]
[New LWP 13447]
[New LWP 13453]
[New LWP 13454]
[New LWP 13455]
[New LWP 13456]
[New LWP 13458]
[New LWP 13459]
[New LWP 13460]
[New LWP 13461]
[New LWP 13462]
[New LWP 13463]
[New LWP 13480]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
__GI___nanosleep (remaining=0x7eb169c8, requested_time=0x7eb169c8) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
28 ../sysdeps/unix/sysv/linux/nanosleep.c: Bestand of map bestaat niet.
Id Target Id Frame
* 1 Thread 0x76f82010 (LWP 13414) "domoticz" __GI___nanosleep (remaining=0x7eb169c8, requested_time=0x7eb169c8) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
2 Thread 0x75b31220 (LWP 13415) "Watchdog" __GI___nanosleep (remaining=0x75b30bd0, requested_time=0x75b30bd0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
3 Thread 0x75330220 (LWP 13420) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
4 Thread 0x74b2f220 (LWP 13422) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
5 Thread 0x73cfc220 (LWP 13423) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
6 Thread 0x734fb220 (LWP 13424) "Webem_ssncleane" 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x734fa378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
7 Thread 0x72cfa220 (LWP 13425) "WebServer_8080" 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x72cf9348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
8 Thread 0x722ff220 (LWP 13426) "Webem_ssncleane" 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x722fe378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
9 Thread 0x71afe220 (LWP 13427) "WebServer_443" 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x71afd348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
10 Thread 0x710ff220 (LWP 13428) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
11 Thread 0x708fe220 (LWP 13429) "TCPServer" 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x708fd378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
12 Thread 0x6feff220 (LWP 13430) "MainWorker" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
13 Thread 0x6f6fe220 (LWP 13431) "MainWorkerRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f6fdbb8, expected=0, futex_word=0xabb68c <m_mainworker+4196>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
14 Thread 0x6e2ff220 (LWP 13440) "MainWorker" 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x6e2fe360, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
15 Thread 0x6d8ff220 (LWP 13441) "P1 Meter" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
16 Thread 0x6ceff220 (LWP 13442) "ZWaveBase" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
17 Thread 0x6c6fe220 (LWP 13443) "SBFSpot" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
18 Thread 0x6befd220 (LWP 13444) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6befcbcc, expected=0, futex_word=0xabb154 <m_mainworker+2860>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
19 Thread 0x6b6fc220 (LWP 13445) "Plugin_ASIO" __waitpid (options=0, stat_loc=0x6b6fafb0, pid=2927) at ../sysdeps/unix/sysv/linux/waitpid.c:30
20 Thread 0x6aefb220 (LWP 13446) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
21 Thread 0x6a6fa220 (LWP 13447) "EventSystemQueu" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a6f9af8, expected=0, futex_word=0xaba774 <m_mainworker+332>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
22 Thread 0x69ef9220 (LWP 13453) "Plugin_PP-MANAG" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
23 Thread 0x694ff220 (LWP 13454) "Plugin_ems-gate" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
24 Thread 0x68aff220 (LWP 13455) "Plugin_BRP069A4" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
25 Thread 0x682fe220 (LWP 13456) "Plugin_xfr_spee" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
26 Thread 0x67265220 (LWP 13458) "OZW-driver" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x67264b08, expected=0, futex_word=0x63fe5d20) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
27 Thread 0x66a64220 (LWP 13459) "OZW-dns" futex_wait_cancelable (private=0, expected=0, futex_word=0x6ed0f868) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
28 Thread 0x66263220 (LWP 13460) "OZW-timer" futex_wait_cancelable (private=0, expected=0, futex_word=0x6ff01df0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
29 Thread 0x65a62220 (LWP 13461) "OZW-driver" __GI___select (timeout=0x65a619c8, exceptfds=0x65a61a48, writefds=0x0, readfds=0x65a619c8, nfds=37) at ../sysdeps/unix/sysv/linux/select.c:41
30 Thread 0x65261220 (LWP 13462) "OZW-poll" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x65260b10, expected=0, futex_word=0x6956b500) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
31 Thread 0x64a60220 (LWP 13463) "Plugin_Buienrad" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
32 Thread 0x635fe220 (LWP 13480) "PluginMgr" futex_wait_cancelable (private=0, expected=0, futex_word=0x68b25934) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
Thread 32 (Thread 0x635fe220 (LWP 13480)):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x68b25934) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0x68b25908) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x68b25908, mutex=0x0) at pthread_cond_wait.c:655
#3 0x003e1088 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#4 0x003ef464 in boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_scheduler_runner>::run() ()
#5 0x003deae0 in boost_asio_detail_posix_thread_function ()
#6 0x76baf494 in start_thread (arg=0x635fe220) at pthread_create.c:486
#7 0x76a62578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 31 (Thread 0x64a60220 (LWP 13463)):
#0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
#1 0x0092225c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
#2 0x00621410 in Plugins::CPlugin::Do_Work() ()
#3 0x009447ec in execute_native_thread_routine ()
#4 0x76baf494 in start_thread (arg=0x64a60220) at pthread_create.c:486
#5 0x76a62578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 30 (Thread 0x65261220 (LWP 13462)):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x65260b10, expected=0, futex_word=0x6956b500) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x65260b10, mutex=0x0, cond=0x6956b4d8) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x6956b4d8, mutex=0x0, abstime=0x65260b10) at pthread_cond_wait.c:667
#3 0x00876134 in OpenZWave::Internal::Platform::EventImpl::Wait(int) ()
#4 0x008700ac in OpenZWave::Internal::Platform::Wait::Multiple(OpenZWave::Internal::Platform::Wait**, unsigned int, int) ()
#5 0x007fd438 in OpenZWave::Driver::PollThreadProc(OpenZWave::Internal::Platform::Event*) ()
#6 0x008740b4 in OpenZWave::Internal::Platform::ThreadImpl::Run() ()
#7 0x008740d0 in OpenZWave::Internal::Platform::ThreadImpl::ThreadProc(void*) ()
#8 0x76baf494 in start_thread (arg=0x65261220) at pthread_create.c:486
#9 0x76a62578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 29 (Thread 0x65a62220 (LWP 13461)):
#0 __GI___select (timeout=0x65a619c8, exceptfds=0x65a61a48, writefds=0x0, readfds=0x65a619c8, nfds=37) at ../sysdeps/unix/sysv/linux/select.c:41
#1 __GI___select (nfds=37, readfds=0x65a619c8, writefds=0x0, exceptfds=0x65a61a48, timeout=0x0) at ../sysdeps/unix/sysv/linux/select.c:37
#2 0x00875b84 in OpenZWave::Internal::Platform::SerialControllerImpl::Read(OpenZWave::Internal::Platform::Event*) ()
#3 0x00875bdc in OpenZWave::Internal::Platform::SerialControllerImpl::ReadThreadProc(OpenZWave::Internal::Platform::Event*) ()
#4 0x008740b4 in OpenZWave::Internal::Platform::ThreadImpl::Run() ()
#5 0x008740d0 in OpenZWave::Internal::Platform::ThreadImpl::ThreadProc(void*) ()
#6 0x76baf494 in start_thread (arg=0x65a62220) at pthread_create.c:486
Thread 28 (Thread 0x66263220 (LWP 13460)):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x6ff01df0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0x6ff01dc8) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x6ff01dc8, mutex=0x0) at pthread_cond_wait.c:655
#3 0x00875fb4 in OpenZWave::Internal::Platform::EventImpl::Wait(int) ()
#5 0x00819c7c in OpenZWave::Internal::TimerThread::TimerThreadProc(OpenZWave::Internal::Platform::Event*) ()
#8 0x76baf494 in start_thread (arg=0x66263220) at pthread_create.c:486
Thread 27 (Thread 0x66a64220 (LWP 13459)):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x6ed0f868) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0x6ed0f840) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x6ed0f840, mutex=0x0) at pthread_cond_wait.c:655
#5 0x008291bc in OpenZWave::Internal::DNSThread::DNSThreadProc(OpenZWave::Internal::Platform::Event*) ()
#8 0x76baf494 in start_thread (arg=0x66a64220) at pthread_create.c:486
Thread 26 (Thread 0x67265220 (LWP 13458)):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x67264b08, expected=0, futex_word=0x63fe5d20) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x67264b08, mutex=0x0, cond=0x63fe5cf8) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x63fe5cf8, mutex=0x0, abstime=0x67264b08) at pthread_cond_wait.c:667
#5 0x0080e3fc in OpenZWave::Driver::DriverThreadProc(OpenZWave::Internal::Platform::Event*) ()
#8 0x76baf494 in start_thread (arg=0x67265220) at pthread_create.c:486
Thread 25 (Thread 0x682fe220 (LWP 13456)):
#4 0x76baf494 in start_thread (arg=0x682fe220) at pthread_create.c:486
Thread 24 (Thread 0x68aff220 (LWP 13455)):
#4 0x76baf494 in start_thread (arg=0x68aff220) at pthread_create.c:486
Thread 23 (Thread 0x694ff220 (LWP 13454)):
#4 0x76baf494 in start_thread (arg=0x694ff220) at pthread_create.c:486
Thread 22 (Thread 0x69ef9220 (LWP 13453)):
#4 0x76baf494 in start_thread (arg=0x69ef9220) at pthread_create.c:486
Thread 21 (Thread 0x6a6fa220 (LWP 13447)):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a6f9af8, expected=0, futex_word=0xaba774 <m_mainworker+332>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x6a6f9af8, mutex=0x0, cond=0xaba748 <m_mainworker+288>) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0xaba748 <m_mainworker+288>, mutex=0x0, abstime=0x6a6f9af8) at pthread_cond_wait.c:667
#3 0x0025f4e8 in CEventSystem::EventQueueThread() ()
#4 0x009447ec in execute_native_thread_routine ()
#5 0x76baf494 in start_thread (arg=0x6a6fa220) at pthread_create.c:486
#6 0x76a62578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 20 (Thread 0x6aefb220 (LWP 13446)):
#2 0x00256d80 in CEventSystem::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x6aefb220) at pthread_create.c:486
Thread 19 (Thread 0x6b6fc220 (LWP 13445)):
#0 __waitpid (options=0, stat_loc=0x6b6fafb0, pid=2927) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 __waitpid (pid=2927, stat_loc=0x6b6fafb0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
#2 0x002db8ec in dumpstack_gdb(bool) ()
#3 0x002dbeb8 in signal_handler(int, siginfo_t*, void*) ()
#4 <signal handler called>
#5 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
#6 <signal handler called>
#7 0x67694488 in ?? ()
#8 0x006484d0 in boost::asio::detail::reactive_socket_recv_op<boost::asio::mutable_buffers_1, boost::_bi::bind_t<void, boost::_mfi::mf2<void, Plugins::CPluginTransportTCP, boost::system::error_code const&, unsigned int>, boost::_bi::list3<boost::_bi::value<Plugins::CPluginTransportTCP*>, boost::arg<1> (*)(), boost::arg<2> (*)()> >, boost::asio::detail::io_object_executor<boost::asio::executor> >::do_complete(void*, boost::asio::detail::scheduler_operation*, boost::system::error_code const&, unsigned int) ()
#9 0x003e1268 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#10 0x00626270 in Plugins::BoostWorkers() ()
#11 0x007c287c in thread_proxy ()
#12 0x76baf494 in start_thread (arg=0x6b6fc220) at pthread_create.c:486
#13 0x76a62578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 18 (Thread 0x6befd220 (LWP 13444)):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6befcbcc, expected=0, futex_word=0xabb154 <m_mainworker+2860>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x6befcbcc, mutex=0x0, cond=0xabb128 <m_mainworker+2816>) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0xabb128 <m_mainworker+2816>, mutex=0x0, abstime=0x6befcbcc) at pthread_cond_wait.c:667
#3 0x002c0b88 in CNotificationSystem::QueueThread() ()
#5 0x76baf494 in start_thread (arg=0x6befd220) at pthread_create.c:486
Thread 17 (Thread 0x6c6fe220 (LWP 13443)):
#2 0x005ad774 in CSBFSpot::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x6c6fe220) at pthread_create.c:486
Thread 16 (Thread 0x6ceff220 (LWP 13442)):
#2 0x00614d18 in ZWaveBase::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x6ceff220) at pthread_create.c:486
Thread 15 (Thread 0x6d8ff220 (LWP 13441)):
#2 0x00568b40 in P1MeterSerial::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x6d8ff220) at pthread_create.c:486
Thread 14 (Thread 0x6e2ff220 (LWP 13440)):
#0 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x6e2fe360, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#1 0x003dfa1c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
#2 0x003e0fa0 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#3 0x003e79fc in boost::asio::io_context::run() ()
#4 0x007c287c in thread_proxy ()
#5 0x76baf494 in start_thread (arg=0x6e2ff220) at pthread_create.c:486
Thread 13 (Thread 0x6f6fe220 (LWP 13431)):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6f6fdbb8, expected=0, futex_word=0xabb68c <m_mainworker+4196>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x6f6fdbb8, mutex=0x0, cond=0xabb660 <m_mainworker+4152>) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0xabb660 <m_mainworker+4152>, mutex=0x0, abstime=0x6f6fdbb8) at pthread_cond_wait.c:667
#3 0x002af354 in MainWorker::Do_Work_On_Rx_Messages() ()
#5 0x76baf494 in start_thread (arg=0x6f6fe220) at pthread_create.c:486
Thread 12 (Thread 0x6feff220 (LWP 13430)):
#2 0x002a9ee4 in MainWorker::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x6feff220) at pthread_create.c:486
Thread 11 (Thread 0x708fe220 (LWP 13429)):
#0 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x708fd378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x00677854 in tcp::server::CTCPServer::Do_Work() ()
#5 0x76baf494 in start_thread (arg=0x708fe220) at pthread_create.c:486
Thread 10 (Thread 0x710ff220 (LWP 13428)):
#2 0x002d08f4 in CScheduler::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x710ff220) at pthread_create.c:486
Thread 9 (Thread 0x71afe220 (LWP 13427)):
#0 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x71afd348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x006bf7ec in http::server::server_base::run() ()
#4 0x0031bc14 in http::server::CWebServer::Do_Work() ()
#5 0x009447ec in execute_native_thread_routine ()
#6 0x76baf494 in start_thread (arg=0x71afe220) at pthread_create.c:486
Thread 8 (Thread 0x722ff220 (LWP 13426)):
#0 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x722fe378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76baf494 in start_thread (arg=0x722ff220) at pthread_create.c:486
Thread 7 (Thread 0x72cfa220 (LWP 13425)):
#0 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x72cf9348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#6 0x76baf494 in start_thread (arg=0x72cfa220) at pthread_create.c:486
Thread 6 (Thread 0x734fb220 (LWP 13424)):
#0 0x76a629d0 in epoll_wait (epfd=<optimized out>, events=0x734fa378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76baf494 in start_thread (arg=0x734fb220) at pthread_create.c:486
Thread 5 (Thread 0x73cfc220 (LWP 13423)):
#2 0x003b71e4 in CInfluxPush::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x73cfc220) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x78
Thread 4 (Thread 0x74b2f220 (LWP 13422)):
#2 0x00626940 in Plugins::CPluginSystem::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x74b2f220) at pthread_create.c:486
Thread 3 (Thread 0x75330220 (LWP 13420)):
#2 0x003128dc in CSQLHelper::Do_Work() ()
#4 0x76baf494 in start_thread (arg=0x75330220) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0xe
Thread 2 (Thread 0x75b31220 (LWP 13415)):
#0 __GI___nanosleep (remaining=0x75b30bd0, requested_time=0x75b30bd0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 __GI___nanosleep (requested_time=0x75b30bd0, remaining=0x75b30bd0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2 0x00270c24 in sleep_milliseconds(long) ()
#3 0x002dc020 in Do_Watchdog_Work() ()
#5 0x76baf494 in start_thread (arg=0x75b31220) at pthread_create.c:486
Thread 1 (Thread 0x76f82010 (LWP 13414)):
#0 __GI___nanosleep (remaining=0x7eb169c8, requested_time=0x7eb169c8) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 __GI___nanosleep (requested_time=0x7eb169c8, remaining=0x7eb169c8) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2 0x00270b90 in sleep_seconds(long) ()
#3 0x001eef2c in main ()
Main thread:
[Inferior 1 (process 13414) detached]
Bospieper
Re: Daikin blockly
Post by Bospieper »
When reviewing the log of the switches from the Daikin I noticed some strange issue. It looks like that another event (Camera) is influencing the Daikin event.
Daikin textlog fan switch.JPG (55.17 KiB) Viewed 839 times
