Moderators: leecollings , htilburgs , robgeerts
Lokonli
Posts: 2292 Joined: Monday 29 August 2016 22:40
Post
by Lokonli » Monday 18 May 2020 17:10
A new beta release of Dashticz, with as new functionality dials for your EvoHome devices, thermostats and dimmers:
To enable the dial representation for your device add the type parameter to the block definition as follows:
blocks['My device'] = {
idx: 123,
type: 'dial'
For documentation see:
https://dashticz.readthedocs.io/en/beta ... st-changes
Thanks to clinkadink for the dial functionality. For the dedicated 'Dial' topic see:
https://www.domoticz.com/forum/viewtopi ... 67&t=32749
jaaap
Posts: 59 Joined: Sunday 28 July 2019 22:59
Post
by jaaap » Tuesday 19 May 2020 23:32
Hi! The new version looks very nice! It also works like a charm on all my android devices...
However, if I try to load it on an apple ipad 3, it loads forever and finally it gives me:
error loading custom/custom.js
ReferenceError: Can't find variable: Intl at line 11:14
Here's my custom.js file:
/** afterGetDevices will be called when Dashticz receives any Domoticz device update */
function afterGetDevices(){
// wasmachine klaar functie
if(alldevices[35].Status == 'On') {
$('div.block_35').addClass('wasmachineklaar');
$('div.block_35').removeClass('invisible');
else {
$('div.block_35').removeClass('wasmachineklaar');
$('div.block_35').addClass('invisible');
// wasmachine draait functie
if(alldevices[52].Data == 'Wasmachine draait' || alldevices[52].Data == 'Wasmachine is bijna klaar'){
$('div.block_52').removeClass('invisible');
$('div.block_34').addClass('wasdraait');
else {
$('div.block_52').addClass('invisible');
$('div.block_34').removeClass('wasdraait');
$('div.block_34').addClass('invisible');
// dakraam open bij regen
if(alldevices[23].Data != 'Voorlopig blijft het droog!' && alldevices[40].Data == 'Open'){
$('.block_40').addClass('warning');
$('div[data-id="dakraamalarm"] .dt_title').addClass('warning');
$('div[data-id="dakraamalarm"]').removeClass('invisible');
else {
$('.block_40').removeClass('warning');
$('div[data-id="dakraamalarm"] .dt_title').removeClass('warning');
$('div[data-id="dakraamalarm"]').addClass('invisible');
/** getStatus_<idx> will be called when Dashticz receives an update for device <idx>
* @param {block}
function getStatus_1(block) {
var device = block.device; //The Domoticz device
var idx = block.idx; //The block idx, as used in CONFIG.js
if (device.Status==='On') {
block.icon = 'fas fa-car';
block.title = 'Device is on';
block.addClass = 'myOwnCSSClass' //The class 'myOwnCSSClass' will be applied
//Define this class in custom.css
Dashticz.setBlock('123', { //Example how to redefine another block
icon:'fas fa-car',
addClass: 'myOtherCSSClass'
else {
block.icon = 'fas fa-bus';
block.title = '';
block.addClass = '';
//function getStatus_35(idx,value,device){
// if(device['Status']=='On'){
// $('div.block_35').addClass('wasmachineklaar');
// $('div.block_35').removeClass('invisible');
// $('div.block_34').addClass('invisible');
// else {
// $('div.block_35').removeClass('wasmachineklaar');
// $('div.block_35').addClass('invisible');
// $('div.block_34').removeClass('invisible');
//function getStatus_52(idx,value,device){
// if(device['Data']=='Wasmachine draait' || device['Data']=='Wasmachine is bijna klaar'){
// $('div.block_34').addClass('wasdraait');
// else {
// $('div.block_34').removeClass('wasdraait');
/** getExtendedBlockTypes will be called to extend the predefined blocktypes
* As an example a blocktype for the Domoticz device with subtype 'MySubtype' has been added
* The function MUST return blocktypes as it receives as parameter.
* For more examples see js/blocktypes.js
* @param {blocktypes}
function getExtendedBlockTypes(blocktypes){
blocktypes.SubType['MySubtype'] = {
icon: 'fas fa-seedling',
title: '<Name>',
value: '<Data>+ <Desc>',
return blocktypes;
I hope you can help me get it going. Thanks in advance!
Lokonli
Post
by Lokonli » Wednesday 20 May 2020 9:59
jaaap wrote: Tuesday 19 May 2020 23:32
else {
else {
else {
* @param {block}
icon:'fas fa-car',
else {
block.title = '';
// else {
// else {
title: '<Name>',
return blocktypes;
Your iPad 3 is using iOS 9?
It seems Intl is not supported on iOS 9 (it's used for some time/date formatting).
We can look for an alternative.
jaaap
Post
by jaaap » Wednesday 20 May 2020 11:15
Hi Lokonli,
Thanks for the reply. My iPad is limited to iOS 9 indeed. Apple doesn't support a newer version of iOS unfortunately
How would an alternative look? Can I fix it myself or is it something that could be added in a new version of Dashticz?
EDIT:
The version 3.4.0 of Dashticz works fine on the iPad.
jaaap on Wednesday 20 May 2020 21:01, edited 1 time in total.
Lokonli
Post
by Lokonli » Wednesday 20 May 2020 12:41
We have to change something it Dashticz. I've to investigate whether we can use a different javascript library for the date/time localization. We already use a different library which probably can be used for this, but I've to check the side effects ....
Lokonli
Post
by Lokonli » Wednesday 20 May 2020 12:43
There are also some issues with IE11 which we are investigating.
toro
Posts: 47 Joined: Wednesday 09 August 2017 23:05
Post
by toro » Wednesday 20 May 2020 15:56
Very nice, I really love the look of this new dials.
I’m on 3.4.7 now and the dial shows great.
But I'm having a problem with the screens now.
The slide function no longer work and all the screens are placed underneath each other.
So it's one long vertical page now.
I didn’t have the options vertical_scroll and enable_swiper yet. I added them now but it made no difference.
Edit:
Also, the clock isn't showing anymore, and the sunrise and sunset only shows the icons, not the time.
The console shows this error: TypeError: Cannot read property 'split' of undefined, don't know if this is related
Aadr
Posts: 19 Joined: Tuesday 09 June 2015 21:26
Post
by Aadr » Wednesday 20 May 2020 21:53
I had the same problem, with the clock and the swipe.
But it was already with v.3.4.6.
I removed some graphs and the problem was gone. I was not able to pinpoint exact what the problem is, but it is related with graphs. I suppose an old graph block.
jaaap
Post
by jaaap » Thursday 21 May 2020 14:42
Version 3.4.8 works perfect on iOS 9. Thanks Lokonli!
toro
Post
by toro » Saturday 23 May 2020 23:00
Aadr wrote: Wednesday 20 May 2020 21:53
I skipped version 3.4.6, so that's indeed very good possible.
After some debugging I found a problem with a block with a subdevice in config.js
I removed this and it's ok now.
