Dashticz IP Cameras - Features, Fixes & Updates
janumix
Re: Dashticz IP Cameras - Features, Fixes & Updates
Post by janumix »
Great !
Thank you.
clinkadink
Post by clinkadink »
Please try the latest beta.
Sent from my HD1913 using Tapatalk
janumix
Post by janumix »
"Ghost" icons disappeared ! Thanks.
I can see that full-screen views are switching between cameras. How can I control it ?
BR
HansieNL
Post by HansieNL »
janumix wrote: Monday 13 April 2020 0:15 "Ghost" icons disappeared ! Thanks.
BR
There will be a handle at the bottom center of the screen, used to display the camera tray. When clicked any other cameras will be presented in the tray. If you click on them, it will update the fullscreen video stream.
Blah blah blah
Trigun
Domoticz version: 4.10717
Post by Trigun »
Hi guys,
Any chance anyone knows how to rotate the camera image in html?
I have a foscam FI9961EP camera which can only flip and mirror but not rotate.
Thnx in advance!
nfuse
Post by nfuse »
nfuse wrote: Tuesday 07 April 2020 11:16 nice work on the camera plugin i also try'd days to get the popup screen to work with iframe scaling but it was a pain and never workt the way i wanted it.
i only have a small problem (not a big one for me) but the focussed icons from dashtics are seeing true the popup when i click my camera picture.
i apply'd the latest beta but i cant figure it out.
here is an example:
any ideas?
sorry for the late response but the problem has fixed with the latest beta stil no luck with the live stream but i keep trying thanks !
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
janumix
Post by janumix »
HansieNL wrote: Monday 13 April 2020 6:29
BR
There are 2 cases:
1. Using direct link to snapshots from cameras
2. Using links to cameras in domoticz.
Ad.1. Full-screen vies are refreshing according to refresh parameter but thumbnails are not shown. Moreover, main/full-screen view switches between cameras randomly (refresh: 1000). It seems to me as it's too fast ???
Ad.2. All look pretty fine but they do not refresh at all:
BR
pimseb
Domoticz version: 2020.1
Post by pimseb »
I have 4 cameras in my dashticz but one of them isn't displayed. The 3 others do work.
The camera giving me problem is an Amcrest IPM-721S.
According to them the snapshot command is : cgi-bin/snapshot.cgi?1
Here is my CONFIG.js :
blocks['cam_buanderie'] = {
        type: 'camera',
        imageUrl: 'http://admin:[email protected]:7800/cgi-bin/snapshot.cgi?1',
        refresh: 1000,
        width: 5,
        height: 220
If I enter this URL in a browser the image is shown just fine. But within dashticz it doesn't work. Maybe it has something to do with the user:password string ? I know I could use the camera idx from domoticz and put it into dashticz, but if I do it this way, it slows down my raspberry system drastically. So it's not a solution for me.
Thank you
clinkadink
It could be because because you passing your credentials via basic auth (i.e. before the '@' sign), which is being blocked by many browsers now. It maybe that's not what wrong here, but its worth trying to rule it out. There maybe some other url constructs that you can use, e.g. below.
cgi-bin/snapshot.cgi?1&loginuse=admin&loginpas=[PASSWORD]
cgi-bin/snapshot.cgi?chn=1&u=admin&p=[PASSWORD]
Btw - Amcrest are rebranded Dahua cameras. You can check their urls here: https://www.ispyconnect.com/man.aspx?n=Dahua
Trigun
Post by Trigun »
Hi, I am really looking forward using your camera setup.
i've tried but couldn't get it to work. does it work on the latest Master Branch?
Thnx in advance
pimseb
Post by pimseb »
I had to install beta. Master branch didn't work
Trigun
Post by Trigun »
pimseb wrote: Monday 18 May 2020 12:36 I had to install beta. Master branch didn't work
Works like a charm in Beta, thanks a lot!
hopefully it will be release in the master branche soon!
Trigun
Post by Trigun »
If I may take the liberty to add a suggestion to you great work, I would say; it would be cool to have one big picture that rotates all the cameras every X seconds with a small preview of all camera's in the bottom. if you click on the specific (rotated) image you will see the view you have already created. Nevertheless fantastic setup and definitly something I've been waiting for! Cheers.
pimseb
Post by pimseb »
That's a great idea.
clinkadink : I tried all the cgi-bin possible for my Amcrest camera with user, pass but the cam always sends a popup that asks for user/password. The only way to get the picture in a browser is user:pass@server:port and it unfortunately doesn't work in dashticz
Maybe I need to change the camera
Trigun
Post by Trigun »
pimseb wrote:That's a great idea.
You could try using the camera url from domoticz. Or add your cameras to zoneminder and use the zoneminder url
clinkadink
pimseb wrote: Monday 18 May 2020 14:19 I tried all the cgi-bin possible for my Amcrest camera with user, pass but the cam always sends a popup that asks for user/password. The only way to get the picture in a browser is user:pass@server:port and it unfortunately doesn't work in dashticz. Maybe I need to change the camera.
That's a shame. I have seen this many times before. Even in Dashticz. For me, user:pass@server:port works in any browser, but it does not work in Dashticz. I have to use server:port?u=user&p=pass configuration. But Trigon raised a safe bet, the Domoticz camera stream will work - and it will save you from buying another camera. Cheers ;)
clinkadink
Trigun wrote: Monday 18 May 2020 13:47 If I may take the liberty to add a suggestion to you great work, I would say; it would be cool to have one big picture that rotates all the cameras every X seconds with a small preview of all camera's in the bottom. if you click on the specific (rotated) image you will see the view you have already created. Nevertheless fantastic setup and definitly something I've been waiting for! Cheers.
Yes, that is possible. I have something very similar for my Dashticz Plex component. It basically cycles through each item indefinitely - with animation of course ;) I will add it as a feature request.
viewtopic.php?f=78&t=32751#p247907
Trigun
Post by Trigun »
Cool!! That’s sounds great! CheersImage
Also I am curious now what you did with plex? Image
clinkadink
Trigun wrote: Monday 18 May 2020 22:29 Also I am curious now what you did with plex? Image
Its a 'carousel', like a photo stream, that cycles through all the media that the family are watching, or have watched recently. I added a webhook in Plex and connected to Domoticz as a dummy device. I then just styled it in Dashticz ;)
jjnh
Domoticz version: 2023.1
Post by jjnh »
Great work!! this plugin is work so much better that the previous option.
I am also suffering from the "screen flipping" issue.
Currently I have 2 camera's (more planned) and sometimes (not always), when selecting one camera for full screen, the shown image will flip to the other camera once every x seconds. The swap is very short (less than 1 second) and seems to be in sync with the image refresh.
Keep up the good work!!
Odroid N2+ 4GB, Finally updated to 2025.2, with an RfxTrx433E, Zigbee2MQTT with Slaesh's CC2652RB, Zwave-JS-UI, SolarEdge, iRobot and P1 connected.
