Gledopto not recognized correct
chaot4ever
Re: Gledopto not recognized correct
Post by chaot4ever »
I do have the same problem with my new Gledopto GL-C-0085, also a RGB+CCT LED Controller. I'm running the newest Beta the Zigbee plugin with the newest Beta of Domoticz, both from yesterday. It is recognised, but makes only one dimming light switch and nothing else.
Here the Devices Raw (json):
export.json.txt
(17.62 KiB) Downloaded 33 times
pipiche
Post by pipiche »
chaot4ever wrote: Wednesday 25 March 2020 15:26 I do have the same problem with my new Gledopto GL-C-0085, also a RGB+CCT LED Controller. I'm running the newest Beta the Zigbee plugin with the newest Beta of Domoticz, both from yesterday. It is recognised, but makes only one dimming light switch and nothing else.
export.json.txt
Try to redo the pairing, you might got some timing issue and during the pairing process, the GL-C-0085 was not recognized as a known model. If the problem perssist, could you please provide me the logs of pairing
Wiki is available here.
Zigbee for Domoticz FAQ
chaot4ever
Deleted the GL-C-008S and redid the pairing, but same story as before!
ZigBeePairingLog.txt
(10.09 KiB) Downloaded 42 times
export(2).json.txt
(3.65 KiB) Downloaded 45 times
pipiche
Post by pipiche »
Please do update the beta branche and redo the pairing you should get a RGB+WW Widget
chaot4ever
Perfectly running now! Thank's a lot!!!!
stx233
Post by stx233 »
Hello I have raised a problem on GH :
https://github.com/pipiche38/Domoticz-Zigate/issues/494
After migrating to beta, the problem is not solve so here is the json export.
pipiche
Post by pipiche »
After switching to beta branch, did you delete the widget/paired device and then redo the pairing ? If not this could explain, please delete the widget Id 387 from Domoticz and then redo the pairing, you should get a Color RGB Widget
stx233
Post by stx233 »
pipiche wrote: Saturday 04 April 2020 22:35 After switching to beta branch, did you delete the widget/paired device and then redo the pairing ? If not this could explain, please delete the widget Id 387 from Domoticz and then redo the pairing, you should get a Color RGB Widget
Hi Color RGB wheel is correctly displayed with beta branch but we lost the warm/cold light panel. Therefore we cannot change the white light to warm or cold.
pipiche
Post by pipiche »
stx233 wrote: Thursday 30 April 2020 23:58
Did you redo a pairing with beta branch ?
pleaqse provide an export of Plugin Device List raw (json)
stx233
Post by stx233 »
pipiche wrote: Friday 01 May 2020 11:38
Yes pairing was done with beta branch directly
Here is the export
pipiche
Post by pipiche »
It is created as specified. is that not a RGB strip led ?
Are you sure it is capable to do White Colour ?
stx233
Post by stx233 »
pipiche wrote: Friday 01 May 2020 19:26 It is created as specified. is that not a RGB strip led ?
Hi i have no doubt the strip led. It is a RGB + CCT strip led (it is written on the zigbee module).
Before domoticz version 2020, there was a specific panel with the ability to choose wam or cold white. Now this menu is gone.
pipiche
Post by pipiche »
I’ll fix it , but it has always been like that for this device.
pipiche
Post by pipiche »
Could you please get the latest 'beta' version
git pull
then remove the existing widget , and redo the pairing
stx233
Post by stx233 »
pipiche wrote: Saturday 02 May 2020 14:54 Could you please get the latest 'beta' version
git pull
Hi pipiche,
Now it is fixed with your last update, the cold/warm menu is available again. Thank you for your support
