Gledopto not recognized correct
- Target OS: -
Re: Gledopto not recognized correct
I do have the same problem with my new Gledopto GL-C-0085, also a RGB+CCT LED Controller. I'm running the newest Beta the Zigbee plugin with the newest Beta of Domoticz, both from yesterday. It is recognised, but makes only one dimming light switch and nothing else.
Here the Devices Raw (json):
Try to redo the pairing, you might got some timing issue and during the pairing process, the GL-C-0085 was not recognized as a known model. If the problem perssist, could you please provide me the logs of pairingchaot4ever wrote: ↑Wednesday 25 March 2020 15:26 I do have the same problem with my new Gledopto GL-C-0085, also a RGB+CCT LED Controller. I'm running the newest Beta the Zigbee plugin with the newest Beta of Domoticz, both from yesterday. It is recognised, but makes only one dimming light switch and nothing else.
export.json.txt
Wiki is available here.
Zigbee for Domoticz FAQ
- Target OS: -
Deleted the GL-C-008S and redid the pairing, but same story as before!
Please do update the beta branche and redo the pairing you should get a RGB+WW Widget
- Target OS: -
Perfectly running now! Thank's a lot!!!!
Hello I have raised a problem on GH :
https://github.com/pipiche38/Domoticz-Zigate/issues/494
After migrating to beta, the problem is not solve so here is the json export.
After switching to beta branch, did you delete the widget/paired device and then redo the pairing ? If not this could explain, please delete the widget Id 387 from Domoticz and then redo the pairing, you should get a Color RGB Widget
Hi Color RGB wheel is correctly displayed with beta branch but we lost the warm/cold light panel. Therefore we cannot change the white light to warm or cold.
Did you redo a pairing with beta branch ?
pleaqse provide an export of Plugin Device List raw (json)
Yes pairing was done with beta branch directlypipiche wrote: ↑Friday 01 May 2020 11:38Did you redo a pairing with beta branch ?
Here is the export
It is created as specified. is that not a RGB strip led ?
Are you sure it is capable to do White Colour ?
Hi i have no doubt the strip led. It is a RGB + CCT strip led (it is written on the zigbee module).
Before domoticz version 2020, there was a specific panel with the ability to choose wam or cold white. Now this menu is gone.
I’ll fix it , but it has always been like that for this device.
Could you please get the latest 'beta' version
then remove the existing widget , and redo the pairing
git pull
Hi pipiche,pipiche wrote: ↑Saturday 02 May 2020 14:54 Could you please get the latest 'beta' version
then remove the existing widget , and redo the pairingCode: Select all
git pull
Now it is fixed with your last update, the cold/warm menu is available again. Thank you for your support
