iRobot Roomba 980 integration
- Domoticz version: 2024.4
Re: iRobot Roomba 980 integration
Hello bewo,bewo wrote: ↑Saturday 18 January 2020 13:50 Hi Vondee,
yes that could be.
If you copied my script 1:1, just add this lines above the "end" of the for loop:Code: Select all
-- Count the working time if otherdevices[Roboter.Name] == 'Saugen' then working_time = tonumber(uservariables[Roboter.Name..'_Laufzeit']) + 1 commandArray[#commandArray+1]={['Variable:'..Roboter.Name..'_Laufzeit'] = tostring(working_time)} end
I copied your scripts 1:1 and also the part above.
The user variable Roboter.Name_Laufzeit is updated every minute (in Domoticz) but the RFXmetercounter stays at " 0"
When I add (to check if it's working) print(working_time) I see the same value as in Roboter.Name_Laufzeit so that works.
The RFXMeter name is: (Zähler (Roboter.Name) Laufzeit.
What's missing ?
Thanks in advance
- bewo
- Domoticz version: 2021.1
Hi Garfield,
i've another script in use to count the working time time of several devices in my house, so i've count the robots there too.
To fill the RFXcounter with the robot script use this code instead the lines i wrote to vondee:
Should work...
counter = 'Zähler '..Roboter.Name..' Laufzeit'
working_time_variable = tonumber(uservariables[Roboter.Name..'_Laufzeit']) + 1
working_time_counter = tonumber(otherdevices_svalues[counter]) + 1
commandArray[#commandArray+1]={['Variable:'..Roboter.Name..'_Laufzeit'] = tostring(working_time_variable)}
commandArray[#commandArray+1]={['UpdateDevice'] = otherdevices_idx[counter]..'|1|'..tonumber(working_time_counter)}
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
- Domoticz version: v2022.2
Vonde, can you please publish your script? Iam trying to use Bewo"s one but i cant repair it just for one roomba. Thank you
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
- bewo
Hi jarmoboy,
the number of robots doesn't matter for the script. It works with 100 robots or only with one.
What's the problem? What doesn't work? Let's repair or correct this together...
- Domoticz version: latest
Hi! Trying to get it work, and I'm stuck on running rest980. It's my first 'deep dive' into scripts like that i have moderate knowledge about linux, so tryig to resolve my problems myself, but now I don't know where to start looking for what can be issue.
I successfully created config, but after trying to test that everything works I'll get this error:
I tried to google for solution, but there is nothing or too many different (not connected to rest980) answers/different cases.
If someone of you will give me a hint where to search or what can make issue like that I'll be very honest.
I'm running domoticz on rpi2 with latest raspbian nodejs, etc (everything seems to be updated).
Cheers!
Edit:
When I set variable in my config:
It can successfully run
And my iRobot starts to clean. So the 'cloud' option seems to make some problems here.
It looks that working well.
pi@raspberrypi:~/rest980 $ DEBUG=rest980:* npm start
> [email protected] start /home/pi/rest980
> node ./bin/www
/home/pi/rest980/node_modules/dorita980/lib/v2/cloud.js:7
throw new Error('Not implemented.');
Error: Not implemented.
at dorita980 (/home/pi/rest980/node_modules/dorita980/lib/v2/cloud.js:7:9)
at new cloud (/home/pi/rest980/node_modules/dorita980/index.js:12:10)
at /home/pi/rest980/routes/api.js:33:46
at handleIP (/home/pi/rest980/routes/api.js:26:68)
at Object.<anonymous> (/home/pi/rest980/routes/api.js:27:1)
at Module._compile (internal/modules/cjs/loader.js:1158:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1178:10)
at Module.load (internal/modules/cjs/loader.js:1002:32)
at Function.Module._load (internal/modules/cjs/loader.js:901:14)
at Module.require (internal/modules/cjs/loader.js:1044:19)
at require (internal/modules/cjs/helpers.js:77:18)
at Object.<anonymous> (/home/pi/rest980/app.js:11:16)
at Object.<anonymous> (/home/pi/rest980/bin/www:7:11)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node ./bin/www`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
Cheers!
Edit:
"enableCloud": "no",
wget http://127.0.0.1:3000/api/local/action/start > /dev/null
After everyting works well for my 960 Irobot, I thought it was time to buy a nice frend for him (e5). I succesfully could get the BLID and so on, but now I am puzzling how to to get this in the 'default.json'. Or do I have to install a 2nd instance of the rest980 server?
- bewo
Hi Vondee,
it depends on what solution you are using... The script/solution from BakSeeDaa, my script/solution, or the plugin which damsmaa created.
In case using still my script:
Best regards!
Yes you need an instance for each robot. (Don't forget to use an different port. For example 3001 instead if 3000.)
Best regards!
Got it working now and the robots are real friends now talking to Domoticz. The 'Status' script works well and I translated to Dutch. The 'Command' script I stumbled upon
and I did not exactly do with it, so I used the 'old' version of the command script and works well!.dofile("/opt/domoticz/scripts/lua/Eigene_Funktionen.lua")
Hi Bewo,bewo wrote: ↑Sunday 05 January 2020 16:16 Hi guys...
Thank's for the idea's, your scripts and the inspiration... I've did it in a different way.
The Rest API which offered beside dorita980 by koalazak (linked above) is updated and works.
So i thougt this an nicer way...
In my house are working two roboters. So i've set up an instance of the restAPI for each robot. Then i use two lua scripts. One time triggered for status updating and the other one device triggered to control the robots.
My comments are german.So if there's somebody who want to use, or there is a question -> just ask, i will do my best @translating.
Best regards and a Happy New Year together!![]()
Thanks for sharing, it looks great !
I'm trying to make it work, but unluckyly, i'm not able to !
I've a only one Roomba 980, and eveything is fine ith the dorita980 (i'me able to start the robot from the shell).
I copied your script 1/1 in Domoticz editor, modified the robot name, and commented the second line with the second robot.
I also created the var and the switch, and did a little bit of translation to try to understand how it works !
First point: what the line
Second point : the status script seems to run, but my customize var stays empty, is it normal ?
Thanks in advance,
Can you share your script with us maybe?Vondee wrote: ↑Sunday 12 April 2020 20:47 Got it working now and the robots are real friends now talking to Domoticz. The 'Status' script works well and I translated to Dutch. The 'Command' script I stumbled uponand I did not exactly do with it, so I used the 'old' version of the command script and works well!.dofile("/opt/domoticz/scripts/lua/Eigene_Funktionen.lua")
Thanks!![]()
- bewo
Hey guys,
Sorry for my late reply. I hope my answer helps anyway.
This line loads a file with all my functions which i use multiple in several scripts. I think in the Roomba-Script only the timedifference-function ist called. So just replace the line with:Makss39 wrote: ↑Wednesday 06 May 2020 15:46 First point: what the linedoes ?Code: Select all
function timedifference(timestamp)
y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
difference = os.difftime(os.time(), os.time{year=y, month=m, day=d, hour=H, min=M, sec=S})
return difference
No it isn't. When the script runs, there must be an entry.
I just bought a Roomba model i7556.
Do you think this script should be working too ?
Thanks.
Thanks.
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
- bewo
Hi manuloup,
yes i think it should work. Just try out.
Bewo,
Thanks for your answer. Is there any translation in english or french of your scripts somewhere ?
Congratulation for the good work.
Hello Bewo,
Do you have the full instructions? Can't get my head around it.
- Domoticz version: 2022.1
Hello everyone,
I’m quite new to the integration of a Roomba into Domoticz. I’ve Rest980 working. But I want to see the status of the Roomba in Domoticz. So if the Roomba is going to work in de evening/night some lights will go on.
Is there anybody who can help me with that? Preferabele in Dutch.
English is possible to. But is takes a little more time for me.
I’m using a RPi4 with domoticz.
Thank you in advance.
I made a plugin for the ROOMBA i7... Don't know if it works with the Roomba 980 however would be interesting if somebody can give it a try and give feedback. The plugin is available on https://github.com/FilipDem/Domoticz-iR ... MBA-plugin.
Hi filip,
I have a Roomba I7+ . I will install the plugin and let you know
Manu
Manu
Filip,
It is installed and works successfully !
Just for your information, I followed the installation procedure :
When it comes to :
That's all, thanks for your work.
When it comes to :
My service was failing and I added the debug parameter. It appears it was because the config.ini was not created yet, so may be you should add a word about it.Start the service with sudo service roomba start
You can check if the service is correctly started with sudo service roomba status (should show active (running))
