Dashticz V3.4.2 beta
- clinkadink
- Domoticz version: 2020.2
Re: Dashticz V3.4.2 beta
I have responded on the 'corona block' thread.
https://www.domoticz.com/forum/viewtopi ... 21#p242221
Did you define the subblocks in CONFIG.js?geertvercamer wrote: ↑Friday 03 April 2020 18:13 you're welcome.
Glad to learn something new.
new beta: the title of those blocks is gone
That might have been solved in the most recent beta.
If not, can you post your CONFIG.js parts for this block? (the block and column definition)
Hi just tried this Corona graph, and works gine on my pc but I am unable to view in my Ipad, I have it on the 3rd screen and just get a blank screen nothing just my selected backgrouns. it is an old ipad V3 running 9.35 any help cheers
Scene behaving strange.
I have a scene which turns off 8 lights.
If one or more lights are ON, the scene turns ON
Clicking the scene, the scene and all the lights turn off.
This is what happens in Domoticz, and in the Master version of Dashticz.
In 4.3.2 however, this happens:
If I turn on a light, only the light button turns on.
If I then click the scene button, the light is turned OFF, but the scene turns ON
If I refresh the page (F5) the scene is OFF.
Also, if the light is ON and the scene stays OFF, after F5 the scene is turned ON.
I noticed the temps of my temp sensors are not updating. Only when I reload the page they update. Don't know if this was already like this in the previous beta.
Other sensors like power usage works fine.
Am I doing something wrong?
I'll check the scenes and the temp sensors
For the scenes/groups: Domoticz only sends a status update if the group/scene itself is clicked, not when one or more devices get a new state.
I'll think of a workaround.
As of 3.4.2 the configuration of 'units' doesn't work anymore. I don't find it back (anymore) either in the documentation.
Somewher in 2018 this feature was introduced
However, in 3.4.2 I have 2 different results in 2 blocks:
1:
blocks['142_1'] = {}
blocks['142_1']['width'] = 4;
blocks['142_1']['title'] = 'Usage' //power in Watt 'Smart Meter P1'
blocks['142_1']['unit'] = 'Watt;W';
It now shows as 100 W Watt;W (when I remove the last line about 'units', it shows as 100 Watt (instead of 'W'))
2:
blocks['240_1'] = {}
blocks['240_1']['width'] = 4;
blocks['240_1']['title'] = 'Harvested'; //power in Watt 'Solar Total Power'
blocks['240_1']['icon'] = 'fas fa-sun';
It shows as 100W (this is as it is wanted)
So, my 142 P1 meter doesn't seem to be recognized equal as the virtual device 240
1:How can I get both devices recognized the same, both showing the unit 'W'?
2:To show from a distance when electricity usage is negative (more solar power than consumption) I made the background of the block green in custom.js. This doesn't work anymore, but it shows a '-' minus sign when there is a negative usage. What has changed?
Custom.js:
config['units'] = {
names: {
kwh: 'kWh',
watt: 'W',
gas: 'm3',
water: 'l',
time: ''
decimals: {
kwh: 1,
watt: 0,
gas: 1,
water: 0,
time: 0
1:
2:
Custom.js:
function getStatus_142_1(idx,value,device){ //P1-smart meter: electricity usage
if(parseFloat(device['UsageDeliv'])>0){
$('div.block_142_1').addClass('background_green');
else {
$('div.block_142_1').removeClass('background_green');
- Domoticz version: 2020.1
Look at this Jake. There were a few changes: https://dashticz.readthedocs.io/en/bloc ... -idx-blockjake wrote: 2:To show from a distance when electricity usage is negative (more solar power than consumption) I made the background of the block green in custom.js. This doesn't work anymore, but it shows a '-' minus sign when there is a negative usage. What has changed?
Custom.js:Code: Select all
function getStatus_142_1(idx,value,device){ //P1-smart meter: electricity usage if(parseFloat(device['UsageDeliv'])>0){ $('div.block_142_1').addClass('background_green'); } else { $('div.block_142_1').removeClass('background_green'); } }
I'll look into the units, but it will take some time to fix.jake wrote: ↑Sunday 05 April 2020 20:04 As of 3.4.2 the configuration of 'units' doesn't work anymore. I don't find it back (anymore) either in the documentation.
Somewher in 2018 this feature was introducedHowever, in 3.4.2 I have 2 different results in 2 blocks:Code: Select all
config['units'] = { names: { kwh: 'kWh', watt: 'W', gas: 'm3', water: 'l', time: '' }, decimals: { kwh: 1, watt: 0, gas: 1, water: 0, time: 0 }
1:
2:
For the P1 meter: There was a request to present the value as a negative number in case of energy delivery, which I have implemented.
For the background color, add something like this in custom.js (the interface of the function slightly changed)
function getStatus_142_1(block) {
if(parseInt(block.device.UsageDeliv)>0 ) {
block.addClass= 'background_green'
block.addClass=''
Good to hear it's fixed.
You mean implementing the 'units' again, or straighting out the issue that one blocks says 'W' and the next 'Watt'?Lokonli wrote:I'll look into the units, but it will take some time to fix.jake wrote: ↑Sunday 05 April 2020 20:04 As of 3.4.2 the configuration of 'units' doesn't work anymore. I don't find it back (anymore) either in the documentation.
1:
2:
Yes, this worked nice. I tried to build on to this example to upgrade my 2nd background thing as well. This one is slightly more complex, because I update the background color of block 321_1, based on status of block 79 (this is to color the gasmeter value red when the OTGWdevice 'central heater' is 'on'), but it doesn't do anything, although it used to do before:For the P1 meter: There was a request to present the value as a negative number in case of energy delivery, which I have implemented.
For the background color, add something like this in custom.js (the interface of the function slightly changed)Code: Select all
function getStatus_142_1(block) { if(parseInt(block.device.UsageDeliv)>0 ) { block.addClass= 'background_green' } else block.addClass='' }
function getStatus_79(block) {
if(block.device.Status == 'Off' ) { //switch: Central Heating ON
'block_321_1'.addClass= 'background_red';
'block_321_1'.addClass='';
function getStatus_79(idx,value,device){ //switch: Central Heating ON
if(device['Status']=='On'){
$('div.block_321_1').addClass('background_red'); //gas usage: Central Heating
else {
$('div.block_321_1').removeClass('background_red');
Because of the inline block definitions and the possibility to add domoticz IDs with different settings more than once I had to refactor the code significantly.
But the good news: I've added a function call to set the block parameters of a different block as well.
See https://dashticz.readthedocs.io/en/beta ... ther-block for an example.
In your case:
I think you must have explicitly added '321_1' to a column. I'm not sure whether it works if you've added '321'
Let me know
Further, you might have to replace Off with On in the above function.
In your case:
Dashticz.setBlock('321_1', {
addClass: 'background_red'
addClass: ''
Let me know
Correct, correct:Lokonli wrote:Because of the inline block definitions and the possibility to add domoticz IDs with different settings more than once I had to refactor the code significantly.
In your case:I think you must have explicitly added '321_1' to a column. I'm not sure whether it works if you've added '321'Code: Select all
function getStatus_79(block) { if(block.device.Status == 'Off' ) { //switch: Central Heating ON Dashticz.setBlock('321_1', { addClass: 'background_red' }); } else Dashticz.setBlock('321_1', { addClass: '' }); }
Let me know
I had seen the example, but since it manipulated a title and icon, I didn't know how or if it could manipulate the background as well.
Yes, I already had 321_1 defined, because I had it working in previous versions
Yes, I meant 'On', but I used 'Off' while playing with the code. Good catch!
The addClass block parameter is new, and pretty convenient for this kind of use case.
- Target OS: -
after the update to 3.4.2 my custom.js functions are not working anymore. Maybe i missed something and the code changed?
These are my functions:
and
any idea? I hope someone can help me!
function getStatus_84(idx,value,device){
if(device['Status']=='Open'){
$('div.block_84').addClass('warning');
blocks['84']['icon'] = 'fas fa-door-open';
else {
$('div.block_84').removeClass('warning');
blocks['84']['icon'] = 'fas fa-door-closed';
function getStatus_413(idx,value,device){
if(parseFloat(device['Usage'])>0){
blocks['413_1']['icon'] = 'fas fa-sun slow-spin'; //if you use "fa-spin" instead of "slow-spin" then it is not necessary to add code to custom.css
blocks['413_2']['icon'] = 'fas fa-sun slow-spin'; //if you use "fa-spin" instead of "slow-spin" then it is not necessary to add code to custom.css
blocks['413_3']['icon'] = 'fas fa-sun slow-spin'; //if you use "fa-spin" instead of "slow-spin" then it is not necessary to add code to custom.css
else {
blocks['413_1']['icon'] = 'fas fa-sun';
blocks['413_2']['icon'] = 'fas fa-sun';
blocks['413_3']['icon'] = 'fas fa-sun';
function getStatus_76_1(idx,value,device){
blocks['76_1']['icon'] = 'fas fa-bolt';
else {
blocks['76_1']['icon'] = 'fas fa-sun slow-spin'; //if you use "fa-spin" instead of "slow-spin" then it is not necessary to add code to custom.css
Please check a few posts earlier, and read:
https://dashticz.readthedocs.io/en/beta ... fterupdate
- Target OS: -
thanks, probably i missed something
