Fixed in latest beta. I''ve removed the 'calendars.' part as well, so now you will get: data-id='f1_cal'HansieNL wrote: Sunday 29 March 2020 13:53 I'm trying to change css settings for a calendar, but I don't get the right unique key identifier back.If I inspect the element I get this data-id: data-id="calendars.block_48"Code: Select all
var calendars = {} calendars.f1 = { maxitems: 3, key: 'f1_cal', image: '../custom/img/f1.png', url: 'https://www.f1calendar.com/#!/timezone/Europe-Amsterdam', icalurl: 'https://www.f1calendar.com/download/f1-calendar_gp.ics?t=1???????????3', // startonly: true }
Dashticz - v.3.4.1 beta
Lokonli
Re: Dashticz - v.3.4.1 beta
- Minglarn
- Domoticz version: v3.8153
Okey, regarding the SCROLLBARS in iframes...
Did some digging into the main.js and found a differance from the old Dashticz code...
At line 912 in latest beta:
html += '<iframe src="' + frame.frameurl + '" style="width:100%;border:0px;height:' + (frame.height - 14) + 'px;" scrolling="no"></iframe>';
In the old code there is no "scrolling". When I removed this part the scrollbars vanished.
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
Lokonli
Are you sure you are running latest beta? In latest beta the above line is line 20 in components/frame.jsMinglarn wrote: Sunday 29 March 2020 15:40 Okey, regarding the SCROLLBARS in iframes...
In the old code there is no "scrolling". When I removed this part the scrollbars vanished.![]()
What is the output of 'git remote -v'' ?
Should be something like:
origin https://github.com/Dashticz/dashticz (fetch)
origin https://github.com/Dashticz/dashticz (push)
This should give:
On branch beta
Your branch is up to date with 'origin/beta'.
nothing to commit, working tree clean
- HansieNL
It look like the thermostat setpoint will not be set in Domoticz set after change in Dashticz.
Someone else has the same problem?
Blah blah blah
- Minglarn
Holy Crap! I did download the Dastichz, but not BETA branch.. Sorry.. Was on the latest stable.. 2.5.11...Lokonli wrote: Sunday 29 March 2020 16:14Are you sure you are running latest beta? In latest beta the above line is line 20 in components/frame.jsMinglarn wrote: Sunday 29 March 2020 15:40 Okey, regarding the SCROLLBARS in iframes...
Should be something like:and 'git status' ?Code: Select all
origin https://github.com/Dashticz/dashticz (fetch) origin https://github.com/Dashticz/dashticz (push)
This should give:Code: Select all
On branch beta Your branch is up to date with 'origin/beta'. nothing to commit, working tree clean
Lokonli
It seems the setpoint gets adjusted. Domoticz shows the adjusted value on the tile, only Domoticz doesn't show the new value in the 'Adjust' (=Aanpassen) screen.HansieNL wrote: Sunday 29 March 2020 21:16 It look like the thermostat setpoint will not be set in Domoticz set after change in Dashticz.
Is this also what you noticed, or do you experience something else?
- HansieNL
What I see is that the setpoint is not ajusted on the Domoticz tile at all.Lokonli wrote: Sunday 29 March 2020 22:43It seems the setpoint gets adjusted. Domoticz shows the adjusted value on the tile, only Domoticz doesn't show the new value in the 'Adjust' (=Aanpassen) screen.HansieNL wrote: Sunday 29 March 2020 21:16 It look like the thermostat setpoint will not be set in Domoticz set after change in Dashticz.
Blah blah blah
Janco
Using a device more than once (with the idx parameter) is certainly a welcome addition, but it's not very clear to me whether it applies to all kinds of blocks. I tried it quickly on a switch device and on a sensor device. For the sensor device it worked, for the switch it didn't (I got an empty block).
So the question is: Is it supposed to work for any type of block?
Also, the parameter name is' idx'. Wouldn't it be more consistent to call it 'device', more or less same name as for multiple graphs, where it is called 'devices'?
I wonder if it would be an option to define all blocks, graphs and multigraphs in the same, uniform way, giving it just any name and then defining which device or devices it represents by simple or array parameter. I know it's all still beta, but it's just a thought.
Lokonli
Thanks for testing. It should work for any type of block. How did you define your switch block? What is the Domoticz device type?Janco wrote: Monday 30 March 2020 1:06 Using a device more than once (with the idx parameter) is certainly a welcome addition, but it's not very clear to me whether it applies to all kinds of blocks. I tried it quickly on a switch device and on a sensor device. For the sensor device it worked, for the switch it didn't (I got an empty block).
The 'idx'-property can also be a variable ('v123') or a scene/group ('s123'), so for that reason I thought let's use a different property name.
On the uniform way of block definition: I'm indeed moving into that direction. In fact it's working already for all blocks, except the string blocks (like 'news', 'traffic'). For the string blocks probably I'll start using the 'type' property, since that's being used for blocktitles as well.
- HansieNL
FIXED in latest betaHansieNL wrote: Sunday 29 March 2020 23:06What I see is that the setpoint is not ajusted on the Domoticz tile at all.Lokonli wrote: Sunday 29 March 2020 22:43It seems the setpoint gets adjusted. Domoticz shows the adjusted value on the tile, only Domoticz doesn't show the new value in the 'Adjust' (=Aanpassen) screen.HansieNL wrote: Sunday 29 March 2020 21:16 It look like the thermostat setpoint will not be set in Domoticz set after change in Dashticz.
Blah blah blah
- Minglarn
AS I'm trying out the latest beta i've got a few issues..
One of them is the FLASH option in blocks.
This wont work, it's a pir sensor and when it's activated only the last seen info is changed but no flash of the button.
Am I missing some settings?
blocks[69] = {flash: 5000};“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
albertomarrod
- Domoticz version: Latest
Hi guys!
Maybe you can help me...
I am trying to update to the latest version. I am currently in 3.4.0 beta.
When in do "git pull" on dashticz_v3 folder nothing happens. I am just getting an error and nothing more.
Image:
https://www.imagenes-temporales.com/subidas/ver/BB6Dqn/
Am I doing something wrong? It is not the way to update it?
Thank you in advance
Image:
Pi3, latest beta
z-wave (AEOTEC, switches, temhum, pir, contacts, roller shutter),
Pylips, WiFi ping, Mi-Light,
Xiaomi Xiaofang cams, zigbee2mqtt,
dashticz v3
dashticz v3
Lokonli
Apparently this bug was introduced some time ago already.Minglarn wrote: Monday 30 March 2020 18:43 AS I'm trying out the latest beta i've got a few issues..
It's fixed in latest beta.
Lokonli
The link doesn't work. Can you repost?albertomarrod wrote: Monday 30 March 2020 21:40 Hi guys!
Image:
albertomarrod
It worked, I had to forced the "git pull" after tried it worked.Lokonli wrote: Monday 30 March 2020 22:32The link doesn't work. Can you repost?albertomarrod wrote: Monday 30 March 2020 21:40 Hi guys!
Image:
Thank you anyway =) You did a great job
Pi3, latest beta
dashticz v3
dashticz v3
i'am afraid i need some help with the custom.js code with the last v.3.4.1 beta my custom.js code is not working anymore.
after a lot of trial and error i have some parts working but not as it should. ( i'am not a coder)
old code
new code
old code
//controller for 4 switch wtw fan
function getStatus_73(idx,value,device){
if(parseFloat(device['Level'])==30){
$('div.block_73').removeClass('warninggreen').removeClass('warningblue').addClass('warningred');
else if(parseFloat(device['Level'])==20){
$('div.block_73').removeClass('warninggreen').removeClass('warningred').addClass('warningblue');
else if(parseFloat(device['Level'])==10){
$('div.block_73').removeClass('warningblue').removeClass('warningred').addClass('warninggreen');
else if(parseFloat(device['Level'])==40){
// Watt consumption
function getStatus_15_1(idx,value,device){
if(parseFloat(device['Usage'])>6500){
$('div.block_15_1').removeClass('warninggreen').removeClass('warningblue').addClass('warningred');
else if(parseFloat(device['Usage'])>2000){
$('div.block_15_1').removeClass('warninggreen').removeClass('warningred').addClass('warningblue');
else if(parseFloat(device['Usage'])<2000){
$('div.block_15_1').removeClass('warningblue').removeClass('warningred').addClass('warninggreen');
// mailbin delivery notification
function getStatus_152(idx,value,device){
if(device['Data']==""){
$('div.block_152').removeClass('warningred').addClass('warninggreen');
blocks['152']['icon'] = 'fas fa-envelope';
blocks['152']['title'] = 'geen post';
else if(device['Data']=="er is Post!"){
$('div.block_152').addClass('warningred').removeClass('warninggreen');
blocks['152']['icon'] = 'fas fa-envelope-open';
blocks['152']['title'] = '';
}Code: Select all
//controller for 4 switch wtw fan ( how to add multiple entry's in one block this is a 4 switch funtion
function getStatus_20(block, afterupdate){
var idx = block.idx;
var device = block.device;
if(parseFloat(device['Usage'])>4000){
block.addClass='warningred';
else {
block.addClass='warninggreen';
function getStatus_73(block, afterupdate){
else {
// Watt consumption ( i need 3 levels
// level <0 solar return = green
// level >0 normal usage 0 to 2000 watt
// lever >4000 high usage e.g. (shower is on message)
function getStatus_15_1(block, afterupdate){
if(parseFloat(device['Usage'])>0){
block.addClass='warningblue';
else {
// mailbin delivery notification how can i add the icons?
function getStatus_152(block){
// block.icon='fas fa-envelope-open'; (option not working
else {
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
Lokonli
For block 73 I think you would like it to be as follows:
and for 15_1 something similar:
For device 152 I read 'option not working' for setting the icon.
This should work. I'll check.
What is your question for device 20?
var level = parseFloat(device['Level']);
if(level>=20){
if(level>=30){
var usage= parseFloat(device['Usage']);
if(usage>=0){
if(usage>=2000){
Lokonli
With my system setting the icon in the getStatus function works as normal.
Device 152 is a normal Domoticz text device?
If you set the icon in the getStatus function, then you should not define an image in the block definition in CONFIG.js
(or set the image in the getStatus function to an empty string as well)
If you open Devtools in Chrome (F12), and you refresh Dashticz, do you then see any error in the Devtools console tab?
Thanks Lokonli exactly what i needed!
no need for device 20 just een alternative i try'd
for option 152 i have it working , i think there was nothing wrong but i made a typo
the code below is working
else {
block.icon='fas fa-envelope';
block.title=' ';
}docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
Lokonli
ok, thanks for the update!
