Hi All,
I was wondering if anyone ever placed the new Fibaro Walli dimmer in a 3 way
changeover circuit (in dutch wisselschakeling/Hotelschakeling).
Is this even possible and if so, how?
thx,
Installing Walli Dimmer in hotelschakeling/ changeover circuit
Grover
- Domoticz version: 2020.2
RPi 3b+
Domoticz 2020.2 (build 12723
Aeotec Zwave Gen5 stick
Aeotec Sirene
Hank Flood sensor
Mi-Light box 5 and 6
NodOn Zwave
Fibaro Zwave plus modules
KlikAanKlikUit Dawn/Dusk sensor
Di-O RFX
Wunderground
RFXcom
X10
Aeotec Sirene
Hank Flood sensor
NodOn Zwave
Di-O RFX
Wunderground
RFXcom
X10
terrorsource
Re: Installing Walli Dimmer in hotelschakeling/ changeover circuit
Yes it is possible. But not hardware/cable based. You can do it virtually over Z-wave
Simple version:
IF Switch1 = ON THEN Switch2 = ON
IF Switch2 = ON THEN Switch1 = ON
IF Switch1 = OFF THEN Switch2 = OFF
IF Switch2 = OFF THEN Switch1 = OFF
Simple version:
- Domoticz version: 2025.1
Is suppose he means with a script (Blockly, dzVents or Lua)
rrozema
It is possible to use a zwave/ZigBee/wifi dimmer with a change over wiring (dutch: hotel schakeling). The smart switch must however be an in-wall module, it can not be an "operatable" device like your walli module or the neo coolcam touch switches.
So, no, it can't be done with those walli switches, unless you're willing to use a software solution using your own script or you can use for example my auto-onoff script. The software solutions can however sometimes have a noticable delay. Plus if Domoticz doesn't work, the light can only be switched on or off using the 'master' switch.
