"Groups & network" not working Topic is solved
PBdA
Domoticz version: 3.5893
Post by PBdA »
I run Domoticz stable with an Aeotec Gen 5 USB stick. My zwave network (17 devices) works well but when I try to access "Groups & network", screen is greyed out and web interface hangs. Anything I can do to recover "Groups & network" screen ?
Thank you for your help.
PBdA
Peterus
Domoticz version: 2021.1
Re: "Groups & network" not working
Post by Peterus »
I have the same problem.
2 of my devices are configured in "Groups & Network" so they don't work after upgrade.
I can still see the option under "Node management" if I use Chrome.
That option is not even available when using Firefox or IE
Peterus
Post by Peterus »
Now I can see them. They are seen in Firefox (but not in Chrome!!) as tabs under "Hardware"/"Setup".
in Chrome the option was still seen under "node management" but didn't work.
Some problem with old cache perhaps?
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
Peterus wrote:Now I can see them. They are seen in Firefox (but not in Chrome!!) as tabs under "Hardware"/"Setup".
Most likely - clear your Chrome Cache and Appcache - 2 different settings ;)
Peterus
Post by Peterus »
Yes, that was very likely the problem.
