I run Domoticz stable with an Aeotec Gen 5 USB stick. My zwave network (17 devices) works well but when I try to access "Groups & network", screen is greyed out and web interface hangs. Anything I can do to recover "Groups & network" screen ?
Thank you for your help.
"Groups & network" not working Topic is solved
- Domoticz version: 2021.1
Re: "Groups & network" not working
I have the same problem.
2 of my devices are configured in "Groups & Network" so they don't work after upgrade.
I can still see the option under "Node management" if I use Chrome.
That option is not even available when using Firefox or IE
Now I can see them. They are seen in Firefox (but not in Chrome!!) as tabs under "Hardware"/"Setup".
in Chrome the option was still seen under "node management" but didn't work.
Some problem with old cache perhaps?
- Domoticz version: 4.10915
Most likely - clear your Chrome Cache and Appcache - 2 different settingsPeterus wrote:Now I can see them. They are seen in Firefox (but not in Chrome!!) as tabs under "Hardware"/"Setup".
Yes, that was very likely the problem.
