Fibaro FGS-223 not responding to on/off commands
ropske
Domoticz version: V3_8394
Re: Fibaro FGS-223 not responding to on/off commands
Post by ropske »
Still no update on this??
ropske
Post by ropske »
hmm, restarting Domoticz server => sudo service domoticz.sh restart
worked for me ; just wait untill all nodes are queried and awake!
Bomans007
Post by Bomans007 »
Hi All,
first of all, I registered myself many years ago, but it took me "some" time to finally switch over to ZWave/Domoticz.
Since last moth the ZWave area arrived at my place so therefor I was a bit inactive (till now :oops: ).
I'm facing the same problem too with all mine Fibaro FGS-223 nodes (Windows build of Domoticz):
- they do not respond to any command comming from Domoticz: NOK
- status updates from the FGS-223 tool works fine: OK
- Controlling it via the physical switch works also fine :OK[/list][/list]
All my Qubino nodes (ZMNHDD1 Flush Dimmer) work fine in all directions(switch, commands, updates).
I did not see a any post so far which pinpointed the "real" reason of the issue, or a possible solution which seems to work out for everyone.
So therefor I'm trying to hibernate this thread :)
It seems that the problem is indeed related to the Domoticz(openZWave) build as mentioned earlier in this thread(since it is working without any problem for the e.g. Qubino nodes ).
As skippy711 posed earlier (post_id=185630 time=1530821818) it might be related to the windows build, since it seems to work on the linux build?
So my questions:
- @virtualfreak: were you already able to solve the issue in the meantime yourself?
- @anyone/skippy711: is this issue indeed fixed by switching over from the windows to the linux version?
Bomans007
Post by Bomans007 »
I All
Since no replies so far, I will reply myself :)
The issue is solved after intalling the latest domoticz release(V2020.1).
Solved means here that I'm now abel to send (switch) commands to the FGS-223 module.
Beforehand this was not possible and I could only see the switch status but any switch on/off command send by domoticz did not do anything.
So Glad this is solved.
Thanks Domoticz team!!!!
