Python Plugin: LG Smart AC (SmartThinQ) Topic is solved
Melissen
Re: Python Plugin: LG Smart AC (SmartThinQ)
Post by Melissen »
Finally it works with ONE ac.. now I want to add my second ac. Anybody knows how to do that?
Many thanks in advance
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
Melissen
Post by Melissen »
Yeeaaahhhhhh, finally got it all to work.
When you have multiple AC's and you want to control them all in Domoticz you need to make some adjustments.
Copy for each AC the file LGACServerNew.py to LGACServerNew2.py (or LGACServerNew3.py and so on)
In this file you should change 127.0.0.1 to 127.0.0.2 ( or 127.0.0.3 and so on)
Also change 22233 to 22234 (or 22235 and so on)
And put the devicenumber of that airco in that file.
Do the same steps as LGACServerNew.py, but now with 2 (or 3 added)
So make it executable and test this file
Also copy the file TestServer.py to TestServer2.py (or 3 and so on)
Also change here the ip-adress and portnumber as above
Then make the systemd-file.... also the same as above. Copy this file and call it: LGAC_server2.service
Change the Execstart path with the right file. ExecStart=/usr/bin/python3 /home/pi/LGAC_SmartT/LGACServerNew2.py
Also add 2 or 3 after the filenames:
sudo systemctl daemon-reload
sudo systemctl enable lgac_server.service
sudo systemctl start lgac_server
sudo systemctl status lgac_server
So.... basicly it's all copying the existing files to a file with a higher number. Change the ip-adresses and portnumbers with a higher number.
After all this copying and pasting, run Domoticz.
Go to Hardware as described and select LG AC....
Now at the fields with ip-adress and portnumber, use the ip-adresses and portnumbers with the higher number.
Now you can see Domoticz added new AC to the switches.....
So you add bij Hardware for every AC a device.....
No faults in the log of Domoticz, and everything works great.
I've tested and use this on a Raspberry with the latest Stretch-version. Buster gave me some troubles in the beginning (but maybe I made some mistakes as you can see by my questions above in this topic)
Melissen
Post by Melissen »
Both ac's can be controlled in Domoticz. But after a few hours or days one or both ac's can't be controlled. Got some errors in Domoticz log. After a restart both ac's can be controlled again.
Who's got the same problem.and knows how to fix this?
javalin
Domoticz version: v2026.2
Post by javalin »
Melissen wrote:Both ac's can be controlled in Domoticz. But after a few hours or days one or both ac's can't be controlled. Got some errors in Domoticz log. After a restart both ac's can be controlled again.
I have the plugin running from 2 months ago and only once I had and issue with the AC. Works very well. Do you have good wireless coverage at home?
Sent from my SM-G973F using Tapatalk
Melissen
Post by Melissen »
When I start (or restart) Domoticz:
Schermafdruk 2020-03-20 00.01.34.png (242.29 KiB) Viewed 16325 times
After a while:
AC error.jpg (154.05 KiB) Viewed 16325 times
javalin
Post by javalin »
When you receive {'cmd': 'status', 'exception': "python-LGAC: 'Monitor' object has no attribute 'work_id'"} seems you loose connection with the server but don´t know why.
I would try to get a new "refresh_token".
Melissen
Post by Melissen »
It's strange, because when I reboot the Pi (not my AC's) everyting is running good again...
I'm going to make a fresh install again... but now installing this 'scripts' at the end of all my other devices (P1 meter, KWh-meter, GPIO-settings, Zigbee, MQTT etc...)
Also making different folders for my two airco-units. Hopefully this helps... Or has someone also 2 of more airco's running in Domoticz without any problems?
javalin
Post by javalin »
Melissen wrote:It's strange, because when I reboot the Pi (not my AC's) everyting is running good again...
You can check the server status when you get the error with the following telnet command:
Maybe you get more info.
I only have one LG AC connected to Domoticz
mattl0
Post by mattl0 »
Do you plan to support washer and dryer ?
I can see them with https://github.com/gladhorn/wideq/tree/api2_merged and it works.
this is the command i used to register
python3 example.py -c CA -l en-CA
this is the washing machien when using it
[code]        "washerDryer": {
            "extraRinse": "EXTRARINSE_OFF",
            "stainCare": "STAINCARE_OFF",
            "initialTimeMinute": 6.0,
            "smartCourseTLBaseUS": "NOT_SELECTED",
            "waterPlus": "WATERPLUS_OFF",
            "addGarment": "ADDGARMENT_OFF",
            "remoteStart": "REMOTE_START_OFF",
            "state": "RUNNING",
            "doorLock": "DOOR_LOCK_ON",
            "wifiSDS": "WIFI_SDS_OFF",
            "smallUE": "SMALLUE_OFF",
            "turboWash": "TURBOWASH_ON",
            "preState": "DETECTING",
            "spin": "SPIN_EXTRA_HIGH",
            "initialBit": "INITIAL_BIT_OFF",
            "reserveTimeMinute": 0.0,
            "initialTimeHour": 1.0,
            "reserveTimeHour": 0.0,
            "error": "ERROR_NO",
            "remainTimeHour": 1.0,
            "courseTLBaseUS": "PREWASH_PLUS",
            "rinse": "NO_RINSE",
            "soilWash": "SOILWASH_NORMAL",
            "dnnReady": "DNNREADY_OFF",
            "preWash": "PREWASH_OFF",
            "soak": "SOAK_OFF",
            "TCLCount": 1.0,
            "temp": "TEMP_TAP_COLD",
            "fabricSoftener": "FABRICSOFTENER_OFF",
            "downloadedCourseTLBaseUS": "SMALL_LOAD",
            "soakBit": "SOAK_OFF",
            "coldWash": "COLDWASH_OFF",
            "saveEnergy": "SAVE_ENERGY_OFF",
            "remainTimeMinute": 3.0,
            "steam": "STEAM_OFF",
            "childLock": "CHILDLOCK_OFF"
And this is the dryer when i use it :
        "washerDryer": {
            "dampDrySignal": "DAMPDRYSIGNAL_OFF",
            "initialTimeMinute": 59.0,
            "antiBacterial": "ANTIBACTERIAL_OFF",
            "state": "DRYING",
            "energySaver": "ENERGYSAVER_OFF",
            "easyIron": "EASYIRON_OFF",
            "moreLessTime": 0.0,
            "turboSteam": "TURBOSTEAM_OFF",
            "courseDryer27inchBase": "NORMAL",
            "wrinkleCare": "WRINKLECARE_OFF",
            "preState": "INITIAL",
            "loadItem": "LOADITEM_OFF",
            "initialTimeHour": 0.0,
            "downloadedCourseDryer27inchBase": "SUPERDRY",
            "remainTimeHour": 0.0,
            "reduceStatic": "REDUCESTATIC_OFF",
            "smartCourseDryer27inchBase": "NOT_SELECTED",
            "dryLevel": "DRYLEVEL_VERYDRY",
            "temp": "TEMP_MEDIUM",
            "timeDry": "TIMEDRY_OFF",
            "remainTimeMinute": 57.0,
Melissen
Post by Melissen »
After the Domoticz upgrade to 2020.1.. I need to have Buster installed.
Now I get errors on :
pi@raspberrypi:~/LGAC_SmartT $ sudo systemctl status lgac_serverW
● lgac_serverW.service - LG AC Device Server
Loaded: loaded (/lib/systemd/system/lgac_serverW.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2020-04-02 20:12:45 CEST; 10min ago
Process: 1643 ExecStart=/usr/bin/python3 /home/pi/LGAC_SmartT/LGACServerNewW.py (code=exited, status=1/FAILURE)
Main PID: 1643 (code=exited, status=1/FAILURE)
apr 02 20:12:44 raspberrypi systemd[1]: Started LG AC Device Server.
apr 02 20:12:45 raspberrypi python3[1643]: Traceback (most recent call last):
apr 02 20:12:45 raspberrypi python3[1643]: File "/home/pi/LGAC_SmartT/LGACServerNewW.py", line 12, in <module>
apr 02 20:12:45 raspberrypi python3[1643]: import msgpack
apr 02 20:12:45 raspberrypi python3[1643]: ModuleNotFoundError: No module named 'msgpack'
apr 02 20:12:45 raspberrypi systemd[1]: lgac_serverW.service: Main process exited, code=exited, status=1/FAILURE
apr 02 20:12:45 raspberrypi systemd[1]: lgac_serverW.service: Failed with result 'exit-code'.
So I need a solution for "IMPORT MSGPACK"
How can I solve this in Buster.... (in Stretch there are no problems)
romansladecek
Post by romansladecek »
fix for errors with ssl:
sudo sed -i "s|TLSv1.2|TLSv1.0|g" /etc/ssl/openssl.cnf
arma_esiea
Post by arma_esiea »
Anybody use a LG washer (new model) with this plugin ?
I have found this fork who display washer in list item but i don't how send an ON command :
https://github.com/tinkerborg/wideq
Sincerely
stingone
Post by stingone »
Any update how to get this working on buster? The scripts are giving a lot of errors.
stingone
Post by stingone »
Thierry33700 wrote: Sunday 03 November 2019 15:41
luckymr2201 wrote: Monday 26 August 2019 8:53 Thierry,
Once you logged in using the provided URL you should see that the resulting URL has 3 data in it. access_token, refresh_token and oauth2_backend_url
This is all that would go in the resulting json file anyway.
I suggest you simply move to the next step using the raw information from the URL that you can copy / paste in a text editor.
I hope this will be enough to get you out of trouble.
Hello luckymr2201,
Thanks for your help, unfortunately i was not able to go next step, i created a wideq_state.json file like follow :
"access_token": "1ca3e111112234e543cfada616f65ee60493d136640adc1e1f841989a7fe9cf3350594da1c6ae485e6e6e8182f4f42451d",
"refresh_token": "194be3b7596111111a5eb8ee484e180d3adb4644a63fc4f8ce9709e3f1c696fb20d1329e022d56daab51ac820893bd7",
"oauth2_backend_url": "https://gb.lgeapi.com/"
But i had the same issue when running 'python3 example.py ls' :
File "example.py", line 214, in <module>
example(sys.argv[1:])
File "example.py", line 200, in example
example_command(client, args)
File "example.py", line 180, in example_command
func(client, *args[1:])
File "example.py", line 25, in ls
for device in client.devices:
File "/root/LGAC_SmartT/wideq.py", line 474, in devices
self._devices = self.session.get_devices()
File "/root/LGAC_SmartT/wideq.py", line 465, in session
self._session, self._devices = self.auth.start_session()
File "/root/LGAC_SmartT/wideq.py", line 257, in start_session
return Session(self, session_id), as_list(session_info['item'])
KeyError: 'item'
Can't go further. Hope someone has the same issue and help ;-)
Thx.
Thierry
How did you solve this? get the same error. With both Buster and Stretch
Thierry33700
Post by Thierry33700 »
stingone wrote: Saturday 27 June 2020 21:51
Hello luckymr2201,
KeyError: 'item'
Thx.
Thierry
Hello, i did not solve this problem,, can't use the plugin ;-(
stingone
Post by stingone »
[/quote]
[/quote]
[/quote]
Seems to be a APIv2 issue that is not implemented in this plugin. :(
heggink
Domoticz version: 12451
Post by heggink »
Since this repo had not been updated for quite a while and there were a bunch of issues I encountered, Forked it and made a couple of changes:
- update to the latest msgpack (which has utf8 by default)
- that in turn allows plugin restart (thanks @dnpwwo!!!)
- some connection management optimisations
- general logging improvements
Tested on rpi3 / buster. Still many thanks to olinek2 for doing the work to begin with.
https://github.com/heggink/LGAC_SmartT
H
P1 meter & solar panel
Thierry33700
Re: Python Plugin: LG Smart AC (SmartThinQ) - SOLVED
Hello luckymr2201,
KeyError: 'item'
Thx.
Thierry
After lot of several new tests, i succeded. Here is what i did to make it work.
First, i deleted /home/pi/LGAC_SmartT folder:
sudo rm -rf LGAC_SmartT/
then i choosed fork from https://github.com/heggink/LGAC_SmartT. - Thanks to heggink !!!
I followed mostly his installation process, get the same problem ... BUT then i had the idea to change this line in the installation process :
python3 example.py
was changed into
sudo python3 example.py
then everything worked for the server.
Then in domoticz, i get the following errors in domoticz's logs :
2020-10-04 11:42:09.327 Error: (LG-SmartThinq-AC) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/LG-SThinq-AC/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-10-04 11:42:09.328 Error: (Clim_Salon) Module Import failed, exception: 'AttributeError'
2020-10-04 11:42:09.328 Error: (Clim_Salon) Error Line details not available.
2020-10-04 11:43:20.329 Error: Clim_Salon hardware (7) thread seems to have ended unexpectedly
I found a similar issue there : https://github.com/mrin/domoticz-mirobo ... /issues/26
So i followed to type :
sudo pip3 install -U --ignore-installed msgpack=="0.6.2"
Then domoticz started to use the plugin !!
Next i'll add others Climatisers by creating duplications of the server scripts as explain.
And i will now prepare or look for a script to manage start and stop within a given temperature in the room.
Thanks to all developpers that worked on this.
Thierry
Devious
Domoticz version: 4.10717
Post by Devious »
I'm still getting the same error
7&oauth2_backend_url=https://gb.lgeapi.com/
File "example.py", line 177, in example_command
ls(client)
File "/home/pi/LGAC_SmartT/wideq.py", line 474, in devices
File "/home/pi/LGAC_SmartT/wideq.py", line 465, in session
File "/home/pi/LGAC_SmartT/wideq.py", line 257, in start_session
KeyError: 'item'
I used the sudo python3 example.py
anyone else?
molnaratti
Post by molnaratti »
mattl0 wrote: Wednesday 25 March 2020 5:49 Do you plan to support washer and dryer ?
            "state": "RUNNING",
            "soak": "SOAK_OFF",
            "TCLCount": 1.0,
        "washerDryer": {
            "state": "DRYING",
Thank you! works . Domoticz plugin expected?
