Soil probe based on esp8266 with domoticz
manuloup
Post by manuloup »
Hi, I just bought that kind of soil probe :
https://wiki.aprbrother.com/en/ESP_Soil ... ensor.html
It is based on TMP112 chip (I2C) for the sensor part.
I succesfully installed tasmota on it, and get the soil and temperature :
The thing is I can't get my virtual device updated on domoticz. Nothing's happen. MQQT settings are ok and domoticz's too.
My tasmota logs :
16:03:54 MQT: tele/Tamosta/LWT = Online (retained)
16:03:54 MQT: cmnd/Tamosta/POWER =
16:03:54 MQT: tele/Tamosta/INFO1 = {"Module":"Generic","Version":"8.1.0(tasmota)","FallbackTopic":"cmnd/DVES_DC1346_fb/","GroupTopic":"cmnd/tasmotas/"}
16:03:54 MQT: tele/Tamosta/INFO2 = {"WebServerMode":"Admin","Hostname":"Tamosta-4934","IPAddress":"192.168.1.49"}
16:03:54 MQT: tele/Tamosta/INFO3 = {"RestartReason":"Software/System restart"}
16:03:58 MQT: tele/Tamosta/STATE = {"Time":"2020-02-28T16:03:58","Uptime":"0T00:00:12","UptimeSec":12,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"Wifi":{"AP":1,"SSId":"manuwifi_ext","BSSId":"B0:BE:76:AC:B6:5B","Channel":3,"RSSI":100,"Signal":-42,"LinkCount":1,"Downtime":"0T00:00:06"}}
16:03:58 MQT: domoticz/in = {"idx":1562,"nvalue":0,"svalue":"24.3","Battery":100,"RSSI":10}
16:03:58 MQT: tele/Tamosta/SENSOR = {"Time":"2020-02-28T16:03:58","ANALOG":{"Moisture":10},"LM75AD":{"Temperature":24.3},"TempUnit":"C"}
16:04:48 LOG: SerialLog 2, WebLog 2, MqttLog 4, SysLog 3, LogHost , LogPort 514, TelePeriod 300
16:08:58 MQT: tele/Tamosta/STATE = {"Time":"2020-02-28T16:08:58","Uptime":"0T00:05:12","UptimeSec":312,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"manuwifi_ext","BSSId":"B0:BE:76:AC:B6:5B","Channel":3,"RSSI":100,"Signal":-47,"LinkCount":1,"Downtime":"0T00:00:06"}}
16:08:58 MQT: domoticz/in = {"idx":1562,"nvalue":0,"svalue":"24.0","Battery":100,"RSSI":10}
16:08:58 MQT: tele/Tamosta/SENSOR = {"Time":"2020-02-28T16:08:58","ANALOG":{"Moisture":9},"LM75AD":{"Temperature":24.0},"TempUnit":"C"}
16:13:58 MQT: tele/Tamosta/STATE = {"Time":"2020-02-28T16:13:58","Uptime":"0T00:10:12","UptimeSec":612,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"manuwifi_ext","BSSId":"B0:BE:76:AC:B6:5B","Channel":3,"RSSI":100,"Signal":-45,"LinkCount":1,"Downtime":"0T00:00:06"}}
16:13:58 MQT: domoticz/in = {"idx":1562,"nvalue":0,"svalue":"23.5","Battery":100,"RSSI":10}
16:13:58 MQT: tele/Tamosta/SENSOR = {"Time":"2020-02-28T16:13:58","ANALOG":{"Moisture":9},"LM75AD":{"Temperature":23.5},"TempUnit":"C"}
16:18:58 MQT: tele/Tamosta/STATE = {"Time":"2020-02-28T16:18:58","Uptime":"0T00:15:12","UptimeSec":912,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"manuwifi_ext","BSSId":"B0:BE:76:AC:B6:5B","Channel":3,"RSSI":100,"Signal":-47,"LinkCount":1,"Downtime":"0T00:00:06"}}
16:18:58 MQT: domoticz/in = {"idx":1562,"nvalue":0,"svalue":"23.4","Battery":100,"RSSI":10}
16:18:58 MQT: tele/Tamosta/SENSOR = {"Time":"2020-02-28T16:18:58","ANALOG":{"Moisture":9},"LM75AD":{"Temperature":23.4},"TempUnit":"C"}
Any idea how to fix this ?
Thanks in advance.
Manu
Last edited by manuloup on Friday 28 February 2020 16:34, edited 3 times in total.
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
manuloup
Re: Soil probe based on esp8266 with domoticz
Post by manuloup »
My MQTT settings :
My Domoticz settings :
