script to send mqtt message with percentage
megamarco83
hi, i'm playing a bit with esp8266 this time using tasmota firmware.
what i would like to implement is a script that read the percentage of sliding of dummy device type: inverted blind with percentage and send the conresponding value to esp.
the mqtt message to send is this one:
cmnd/<devicetopic>/shutterposition<Number> <%>
example
if i have this devices on esp that has name: tamota_blind_1 where i have:
1) blind_kitchen
2) blind_kitchen2
3) blind_kitchen3
and another esp that has name: tasmota_blind_2 where i have:
1) blind_bathroom
2) blind_stairs
and i move the percentage of blind stairs at 25%
the script should send to esp tasmota_blind_2 this message:
cmnd/tasmota_blind_2/shutterposition2 25
of course when the message come from esp to domoticz, domoticz should not react.
the message come from esp to domoticz when some one trigger gpio of esp, or when someone use the web interface of esp, in bothcase the command that comes from esp is:
publish domoticz/in {"idx":154,"nvalue":2,"svalue":"%value%"}
of course esp will adress the correct idx and %value% to set the conresponding blind and percentage.
last thing, should be better to have one "blind_master"
that can controll all blind at same % sending out in parallel all commands: cmnd/<devicetopic>/shutterposition<Number> <%>
example
1) blind_kitchen
2) blind_kitchen2
3) blind_kitchen3
1) blind_bathroom
2) blind_stairs
salvacalatayud
Re: script to send mqtt message with percentage
I'm now using shelly to control blinds, but some time ago I used this with tasmota:megamarco83 wrote: Sunday 23 February 2020 23:40 hi, i'm playing a bit with esp8266 this time using tasmota firmware.
example
1) blind_kitchen
2) blind_kitchen2
3) blind_kitchen3
1) blind_bathroom
2) blind_stairs
https://github.com/kungknut/Domoticz-MQTT-Translator
You can check: https://www.domoticz.com/forum/viewtopi ... 51&t=25604
megamarco83
hi, thanks for reply.salvacalatayud wrote: Thursday 27 February 2020 9:08
i install today nodered on raspberry with buster.
i import your script and give my mqtt adrress and domoticz ip:port
then i create inside domoticz uservar type string.
here first question:
i try to control 1st blind so i guess my string should be:
{"MQTT":{"devIdx" : 111,"inTopic" : "publish domoticz/in {"idx":111,"nvalue":2,"svalue":"%value%"}","outTopic" : "cmnd/tasmota_blind_1/shutterposition","slope" : 1, "intercept" : 0,"limits" : "0,0","type" : "dimmer"}}
but domoticz say that's can be saved....maybe too long?
if yes, how to manage for example 8 blinds?
i set as comand from domoticz:
after shutterposition should be put a number that is the percentage to reach
example:
cmnd/tasmota_blind_1/shutterposition 22
in this case tasmota will move blind1 at 22%
the comand that tasmota should send to domoticz if i move slide on web page of tasmota should be:
will be nodered to taking care about that?
with wall switch how to menage?
for example shutter1 has 2switch: switch1 and switch2
short press of switch1 => trigger 1second relay1
long press of switch1 => trigger relay1 till reach 100%open
short press of switch2 => trigger 1second relay2
long press of switch2 => trigger relay2 till reach 100%close
who will manage that?
i create inside tasmota a rule like this:
rule2 on switch1#state=2 do backlog power1 on;delay 10;power1 off endon on switch1#state=3 do power1 on endon
on switch2#state=2 do backlog power2 on;delay 10;power2 off endon on switch2#state=3 do power2 on endon
on switch3#state=2 do backlog power3 on;delay 10;power3 off endon on switch3#state=3 do power3 on endon
on switch4#state=2 do backlog power4 on;delay 10;power4 off endon on switch4#state=3 do power4 on endon
in this case i trigger the relay and due to do this, tasmota should send something, and nodered should automatically report the percentage in domoticz, without adding nothing else, correct?
anyway just to havse a first try i cut from the uservar string the inTopic
so used the string that i used is:
{"MQTT":{"devIdx" : 111,"inTopic" : "","outTopic" : "cmnd/tasmota_blind_1/shutterposition","slope" : 1, "intercept" : 0,"limits" : "0,0","type" : "dimmer"}} idx28 is the numebr of uservar created for nodered
then i try to slide the dummy device type blind inverted, but nothing happened.
i try to add a debug device to nodered as you can see in the pictures: that's are part of the errors.
27/2/2020, 20:07:12node: Convert to urlfunction : (error)
"TypeError: Cannot read property 'length' of undefined"
27/2/2020, 20:07:13node: Format MQTTfunction : (error)
27/2/2020, 20:07:13node: 834676a2.6a9a88domoticz/out : msg.payload : string[264]
"{↵ "Battery" : 255,↵ "RSSI" : 12,↵ "description" : "",↵ "dtype" : "Light/Switch",↵ "id" : "000140C7",↵ "idx" : 119,↵ "name" : "rele_caldaia_ACS",↵ "nvalue" : 0,↵ "stype" : "Switch",↵ "svalue1" : "0",↵ "switchType" : "On/Off",↵ "unit" : 1↵}↵"
27/2/2020, 20:07:14node: Convert to urlfunction : (error)
27/2/2020, 20:07:15node: Format MQTTfunction : (error)
27/2/2020, 20:07:16node: 834676a2.6a9a88domoticz/out : msg.payload : string[310]
"{↵ "Battery" : 255,↵ "RSSI" : 9,↵ "description" : "",↵ "dtype" : "Temp + Humidity",↵ "id" : "82153",↵ "idx" : 153,↵ "name" : "Cucina cantina",↵ "nvalue" : 0,↵ "stype" : "THGN122/123/132, THGR122/228/238/268",↵ "svalue1" : "16.50",↵ "svalue2" : "46.8",↵ "svalue3" : "1",↵ "unit" : 1↵}↵"
27/2/2020, 20:07:17node: Convert to urlfunction : (error)
27/2/2020, 20:07:18node: Format MQTTfunction : (error)
"TypeError: Cannot read property 'length' of undefined"-
salvacalatayud
Edited
In topic is the topic that tasmota should recive from domoticz, in your case "cmnd/tasmota_blind_1/shutterposition"
Try this:
{"MQTT":{"devIdx" : 111,"inTopic" : "cmnd/tasmota_blind_1/shutterposition","outTopic" : "stat/tasmota_blind_1/SHUTTER1","slope" : 1, "intercept" : 0,"limits" : "0,0","type" : "dimmer"}
You must create a new user variable for each blind, with a diferent idx and topic (only tasmota_blind_1).
In your tasmota you must give the same topic.
Out topic is the topic coming from tasmota that should be translated by de node-red flow, in your case "stat/tasmota_blind_1/SHUTTER1"megamarco83 wrote: Thursday 27 February 2020 20:19
example:
Try this:
Last edited by salvacalatayud on Friday 28 February 2020 13:25, edited 3 times in total.
megamarco83
but the intopic should not something like that:salvacalatayud wrote: Friday 28 February 2020 13:01
In topic is the topic coming from tasmota that should be translated by de node-red flow, in your case "state/tasmota_blind_1/shutterposition"
Out topic is the topic that tasmota should recive from domoticz, in your case "cmnd/tasmota_blind_1/shutterposition"
Try this:
{"MQTT":{"devIdx" : 111,"inTopic" : "state/tasmota_blind_1/shutterposition","outTopic" : "cmnd/tasmota_blind_1/shutterposition","slope" : 1, "intercept" : 0,"limits" : "0,0","type" : "dimmer"}
You must create a new user variable for each blind, with a diferent idx and topic.
where tasmota send to domoticz the percentage and idx of blid?
why:
if from tasmota console i write: state/tasmota_blind_1/shutterposition
the response is:
13:08:13 CMD: state/tasmota_blind_1/shutterposition
13:08:13 MQT: stat/tasmota_blind/RESULT = {"Shutter1":{"Position":40,"Direction":0},"Shutter2":{"Position":39,"Direction":0}}
13:08:13 MQT: stat/tasmota_blind/RESULT = {"ShutterPosition1":40}anyway i also tested your proposal of domoticz uservar:
but if i slide the domoticz slider of dummy device set as inverted blind with percentage nothing happened.
iside nodered i create a debug switch and connect to uservar from domoticz
this is the log:
it seams that it not read the uservar, possible??
28/2/2020, 13:05:53node: Convert to urlfunction : (error)
28/2/2020, 13:05:53node: Format MQTTfunction : (error)
28/2/2020, 13:05:55node: Convert to urlfunction : (error)
28/2/2020, 13:05:56node: Format MQTTfunction : (error)
28/2/2020, 13:05:57node: Convert to urlfunction : (error)
28/2/2020, 13:05:58node: Format MQTTfunction : (error)
28/2/2020, 13:05:59node: Convert to urlfunction : (error)
28/2/2020, 13:06:00node: Format MQTTfunction : (error)
28/2/2020, 13:06:00node: Convert to urlfunction : (error)
28/2/2020, 13:06:02node: Convert to urlfunction : (error)
28/2/2020, 13:06:02node: Format MQTTfunction : (error)
28/2/2020, 13:06:03node: Convert to urlfunction : (error)
28/2/2020, 13:06:03node: Format MQTTfunction : (error)
28/2/2020, 13:06:04node: Convert to urlfunction : (error)
28/2/2020, 13:06:04node: Format MQTTfunction : (error)
28/2/2020, 13:06:07node: Convert to urlfunction : (error)
28/2/2020, 13:06:07node: Format MQTTfunction : (error)
salvacalatayud
Sorry, here you have the right user variable:
Try this:
(edited previous post)
Try this:
megamarco83
but stat/tasmota_blind_1/shutter1 doesn't exist:
13:26:08 CMD: stat/tasmota_blind_1/shutter1
13:26:08 MQT: stat/tasmota_blind_1/RESULT = {"Command":"Unknown"}
anyway i try also your last sugestion, but nothing happened.
how i can be sure that nodered read correctly the uservar?
did you see the debug log that i posted?
salvacalatayud
in tasmota console, if you send "shutterposition 50" what response do you get?megamarco83 wrote: Friday 28 February 2020 13:27 but stat/tasmota_blind_1/shutter1 doesn't exist:
13:26:08 MQT: stat/tasmota_blind/RESULT = {"Command":"Unknown"}
megamarco83
i try shutterposition 50
last two raws:
are createt bu rule:
and thanks to my rule1 i'm able to report in domoticz the statud of blind if the command start from ESP.
that's also the reason why i asked why you poso the outTopic as:
and not as:
13:33:29 CMD: shutterposition 50
13:33:29 SHT: Start in dir 0
13:33:29 MQT: stat/tasmota_blind/RESULT = {"POWER2":"ON"}
13:33:29 MQT: stat/tasmota_blind/POWER2 = ON
13:33:29 MQT: stat/tasmota_blind/RESULT = {"ShutterPosition1":50}
13:33:30 SHT: Shutter1 Real 24900, Start 26700, Stop 15000, Dir -1, Delay 0, Rtc 0.30 [s], Freq 1875
13:33:30 MQT: stat/tasmota_blind/RESULT = {"Shutter1":{"Position":83,"Direction":-1},"Shutter2":{"Position":51,"Direction":0}}
13:33:30 SHT: Shutter1 Real 20400, Start 26700, Stop 15000, Dir -1, Delay 0, Rtc 1.05 [s], Freq 1875
13:33:30 MQT: stat/tasmota_blind/RESULT = {"Shutter1":{"Position":68,"Direction":-1},"Shutter2":{"Position":51,"Direction":0}}
13:33:31 MQT: stat/tasmota_blind/RESULT = {"POWER2":"OFF"}
13:33:31 MQT: stat/tasmota_blind/POWER2 = OFF
13:33:31 SHT: Shutter1 Real 15000, Start 26700, Stop 15000, Dir -1, Delay 0, Rtc 1.95 [s], Freq 1875
13:33:31 MQT: stat/tasmota_blind/SHUTTER1 = 50
13:33:31 MQT: stat/tasmota_blind/RESULT = {"Shutter1":{"Position":50,"Direction":0},"Shutter2":{"Position":51,"Direction":0}}
13:33:31 RUL: SHUTTER1#POSITION performs "publish domoticz/in {"idx":111,"nvalue":2,"svalue":"50"}"
13:33:31 MQT: domoticz/in = {"idx":111,"nvalue":2,"svalue":"50"}
13:33:31 RUL: SHUTTER2#POSITION performs "publish domoticz/in {"idx":154,"nvalue":2,"svalue":"51"}"
13:33:31 MQT: domoticz/in = {"idx":154,"nvalue":2,"svalue":"51"}Code: Select all
13:33:31 RUL: SHUTTER2#POSITION performs "publish domoticz/in {"idx":154,"nvalue":2,"svalue":"51"}"Code: Select all
Rule1 ON Shutter1#Position DO publish domoticz/in {"idx":111,"nvalue":2,"svalue":"%value%"} endon ON Shutter2#Position DO publish domoticz/in {"idx":154,"nvalue":2,"svalue":"%value%"} endonthat's also the reason why i asked why you poso the outTopic as:
and not as:
salvacalatayud
Ok, so you get as response "stat/tasmota_blind/SHUTTER1 = 50"
The problem here is the topic itself. You are sending from domoticz to topic tasmota_blind_1 but in tasmota you are using topic tasmota_blind
The rule is not needed if you use translator.
megamarco83
maybe i understand
you are right, sorry
i change the uservar:
{"MQTT":{"devIdx" : 111,"inTopic" : "cmnd/tasmota_blind/shutterposition1","outTopic" : "stat/tasmota_blind/SHUTTER1","slope" : 1, "intercept" : 0,"limits" : "0,0","type" : "dimmer"}
using as tocpic
tasmota_blind
i deactivare my rule:
rule1 0
but again no lucky. if i move the blind using tasmota webpage domoticz is not updated.
if i move the slide inside domoticz web page, relays are not triggered and web page of tasmota not updated.
if i have to move the blind1 inside tasmota console i have to write:
cmnd/tasmota_blind/shutterposition1 32
and blind1 will move at 32%
if i move the slide in tasmota in which way domoticz pass the 32 percentage?
inside uservar there is only:
using as tocpic
tasmota_blind
rule1 0
salvacalatayud
Can you check by subscribing to your mqtt server what messages are sended?
And also check if in domoticz settings page if you have given rights to ip 127.0.0.1 (or ip where node-red is running) to acces from local network
anyway, I will send you my flow as soon as I get home
megamarco83
here i need some help....salvacalatayud wrote: Friday 28 February 2020 14:06 Can you check by subscribing to your mqtt server what messages are sended?
what i have to do to see what message are sended?
i have raspberry where is installed mqtt
or pc with windows. is it possible to us this to see the mqtt messages?
salvacalatayud wrote: Friday 28 February 2020 14:06 And also check if in domoticz settings page if you have given rights to ip 127.0.0.1 (or ip where node-red is running) to acces from local network[/quote
inside settings web page i have:
local networks without passords: 127.0.0.1;192.168.0.*
my mqtt broker is on raspberry, same raspberry where is installed domoticzthanks so much!!salvacalatayud wrote: Friday 28 February 2020 14:06 anyway, I will send you my flow as soon as I get home
salvacalatayud
I use mac, but look for a mqtt client for windows and check all the topics on your servermegamarco83 wrote: Friday 28 February 2020 14:33here i need some help....salvacalatayud wrote: Friday 28 February 2020 14:06 Can you check by subscribing to your mqtt server what messages are sended?
megamarco83
thanks i find and extension of google chrome: mqttLens
i configure the IP of broker and make a connection.
now it ask me subscrive topic or publish topic.
what i have to enter?
thanks
thanks
salvacalatayud
subscribe to tasmota_blindmegamarco83 wrote: Friday 28 February 2020 14:49 thanks i find and extension of google chrome: mqttLens
thanks
salvacalatayud
Try this flow:
Change your user variable type to "shutter"
[{"id":"17010ea5.44ab11","type":"tab","label":"mqtt traductor salva","disabled":false,"info":""},{"id":"2f099dcf.665432","type":"comment","z":"17010ea5.44ab11","name":"Version: v.1.0.0","info":"","x":200,"y":140,"wires":[]},{"id":"e3fd556.de12ba8","type":"comment","z":"17010ea5.44ab11","name":"ABOUT","info":"This software originate from https://github.com/kungknut/Domoticz-MQTT-Translator\n\nIf you find a bug or want to contribute to make this software better? Feel \nfree to open an issue or a pull request.","x":170,"y":180,"wires":[]},{"id":"de6a25fe.da91c8","type":"mqtt out","z":"17010ea5.44ab11","name":"To 3rd party","topic":"","qos":"","retain":"","broker":"8bc033be.f9277","x":730,"y":480,"wires":[]},{"id":"4f21a53f.99596c","type":"mqtt in","z":"17010ea5.44ab11","name":"From 3rd party","topic":"#","qos":"0","broker":"8bc033be.f9277","x":200,"y":420,"wires":[["813bffcb.6c1a1"]]},{"id":"cc5613c.108d2f","type":"http request","z":"17010ea5.44ab11","name":"To Domoticz","method":"GET","ret":"txt","url":"","tls":"","x":730,"y":420,"wires":[[]]},{"id":"5e1ae03c.9df0b","type":"mqtt in","z":"17010ea5.44ab11","name":"From Domoticz","topic":"domoticz/out","qos":"0","broker":"8bc033be.f9277","x":200,"y":480,"wires":[["3a5786d1.d605ca"]]},{"id":"3a5786d1.d605ca","type":"function","z":"17010ea5.44ab11","name":"Format MQTT","func":"var domoticzServer = \"http://localhost\";\nvar userVarValues = flow.get(\"userVarValues\");\n\n// Find what row in the userVarValues array that hold the settings for the reporting device\nvar mqttPayload = JSON.parse(msg.payload);\nvar arrI = null;\nfor (var i = 0; i < userVarValues.length; i++){\n if(mqttPayload.idx == userVarValues[i].devIdx){\n arrI = i;\n }\n}\n\n// If no match is found, exit this function and return null\nif(arrI !== null){\n // Find out which type of device that submitted the value\n var userVar = userVarValues[arrI];\n if(typeof userVar.slope === 'undefined') userVar.slope = 1;\n if(typeof userVar.intercept === 'undefined') userVar.intercept = 0;\n if(userVar.type != \"switch\") var aval = (mqttPayload.svalue1 - userVar.intercept) / userVar.slope;\n \n switch(userVar.type) {\n case \"dimmer\":\n // DIMMER 0-100%\n msg.topic = userVar.outTopic;\n msg.payload = aval;\n switch(mqttPayload.nvalue) {\n case 0:\n msg.payload = 0;\n break;\n case 1:\n msg.payload = context.get(userVar.outTopic)||50;\n break;\n case 2:\n context.set(userVar.outTopic, aval);\n break;\n }\n break;\n case \"switch\":\n // SWITCH ON/OFF\n // OBS - Domoticz is case sensitive\n msg.topic = userVar.outTopic;\n if(mqttPayload.nvalue == \"1\"){\n msg.payload = \"ON\";\n } else if (mqttPayload.nvalue == \"0\"){\n msg.payload = \"OFF\";\n }\n break;\n case \"shutter\":\n // SHUTTER 0-100%\n msg.topic = userVar.outTopic;\n msg.payload = aval;\n switch(mqttPayload.nvalue) {\n case 0:\n msg.payload = 0;\n break;\n case 1:\n msg.payload = 100;\n break;\n case 2:\n context.set(userVar.outTopic, aval);\n break;\n }\n break;\n case \"svalue1\":\n // Thermostat setpoint\n msg.topic = userVar.outTopic;\n msg.payload = aval;\n break;\n default:\n msg.topic = null;\n }\n}else {\n msg.topic = null;\n}\n\nif(msg.topic !== null){\n return msg;\n}","outputs":1,"noerr":0,"x":380,"y":480,"wires":[["cf7bf70d.710d38"]]},{"id":"813bffcb.6c1a1","type":"function","z":"17010ea5.44ab11","name":"Convert to url","func":"var domoticzServer = \"http://localhost:8080\";\nvar userVarValues = flow.get(\"userVarValues\");\n\n// Find what row in the userVarValues array that hold the settings for the reporting device\nvar arrI = null;\nfor (var i = 0; i < userVarValues.length; i++){\n if(msg.topic == userVarValues[i].inTopic){\n arrI = i;\n }\n}\n\n// If no match is found, exit this function and return null\nif(arrI !== null){\n // Find out which type of device that submitted the value\n var userVar = userVarValues[arrI];\n if(typeof userVar.limits === 'undefined') userVar.limits = \"0,0\";\n if(typeof userVar.slope === 'undefined') userVar.slope = 1;\n if(typeof userVar.intercept === 'undefined') userVar.intercept = 0;\n if(userVar.type != \"switch\") var aval = (msg.payload * userVar.slope) + userVar.intercept;\n \n switch(userVar.type) {\n case \"svalue\": // Temperature, Percent, Pressure, Voltage, Text, Distance\n case \"svalue1\": // Thermostat setpoint\n msg.url = domoticzServer + \"/json.htm?type=command¶m=udevice&idx=\" + userVar.devIdx + \"&nvalue=0&svalue=\" + aval;\n break;\n case \"shutter_old\": // Thermostat setpoint\n msg.url = domoticzServer + \"/json.htm?type=command¶m=udevice&idx=\" + userVar.devIdx + \"&nvalue=2&svalue=\" + aval;\n break;\n case \"humidity\":\n // Humidity level\n var humStat = 0; // 0 = Normal, 1 = Comfortable, 2 = Dry, 3 = Wet\n var lims = userVar.limits.split(\";\");\n var limits = [];\n for (var i = 0; i < lims.length; i++){\n var obj = lims[i].split(\",\");\n if(aval >= obj[1]) humStat = obj[0];\n }\n msg.url = domoticzServer + \"/json.htm?type=command¶m=udevice&idx=\" + userVar.devIdx + \"&nvalue=\" + aval + \"&svalue=\" + humStat;\n break;\n case \"switch\":\n // Binary switch (ON/OFF)\n // Domoticz is case sensitive\n if(msg.payload == \"ON\" || msg.payload == \"OFF\"){\n msg.payload = msg.payload.toLowerCase();\n msg.payload = msg.payload.charAt(0).toUpperCase() + msg.payload.slice(1);\n msg.url = domoticzServer + \"/json.htm?type=command¶m=switchlight&idx=\" + userVar.devIdx + \"&switchcmd=\" + msg.payload;\n }\n break;\n case \"dimmer\":\n // Dimmer 0-100%\n var level = parseInt(aval) + 1; // Bug in Domoticz require the \"in\" message to be 1 higher than actual value.\n msg.url = domoticzServer + \"/json.htm?type=command¶m=switchlight&idx=\" + userVar.devIdx + \"&switchcmd=Set%20Level&level=\" + level;\n if(msg.payload == \"0\"){\n msg.url = domoticzServer + \"/json.htm?type=command¶m=switchlight&idx=\" + userVar.devIdx + \"&switchcmd=Off\";\n }\n break;\n case \"shutter\":\n // Shutter 0-100%\n var level = parseInt(aval); // Bug in Domoticz require the \"in\" message to be 1 higher than actual value.\n msg.url = domoticzServer + \"/json.htm?type=command¶m=switchlight&idx=\" + userVar.devIdx + \"&switchcmd=Set%20Level&level=\" + level;\n if(msg.payload == \"0\"){\n msg.url = domoticzServer + \"/json.htm?type=command¶m=switchlight&idx=\" + userVar.devIdx + \"&switchcmd=Off\";\n }\n break;\n default:\n msg.url = null;\n break;\n }\n} else {\n msg.url = null;\n}\n\nif(msg.url !== null){\n return msg;\n}","outputs":1,"noerr":0,"x":380,"y":420,"wires":[["f1960ba6.853bb8"]]},{"id":"65eafdbd.a7c764","type":"comment","z":"17010ea5.44ab11","name":"GET USER VARIABLES FROM DOMOTICZ","info":"","x":290,"y":240,"wires":[]},{"id":"e412dc01.a3452","type":"comment","z":"17010ea5.44ab11","name":"TRANSLATION FUNCTIONS","info":"","x":240,"y":380,"wires":[]},{"id":"5167d1a1.edf9e","type":"http request","z":"17010ea5.44ab11","name":"Read user variables","method":"GET","ret":"txt","url":"http://localhost:8080/json.htm?type=command¶m=getuservariables","tls":"","x":380,"y":320,"wires":[["537a1ec2.9b5ba"]]},{"id":"537a1ec2.9b5ba","type":"function","z":"17010ea5.44ab11","name":"Cache to flow context","func":"msg.payload = JSON.parse(msg.payload);\nvar userVarRes = msg.payload.result,\n userVarValues = [],\n hueStats = {};\n\n\nfor (var i = 0; i < userVarRes.length; i++){\n var obj = userVarRes[i];\n for (var key in obj){\n if(key == \"Value\"){\n var val = JSON.parse(obj[key]);\n if(val.MQTT !== undefined) {\n userVarValues.push(val.MQTT);\n }\n }\n }\n}\n\nflow.set(\"userVarValues\", userVarValues);\n\n//msg.payload = flow.get(\"userVarValues\");\n//return msg;","outputs":1,"noerr":0,"x":600,"y":320,"wires":[[]]},{"id":"9ae0eedd.09a41","type":"mqtt in","z":"17010ea5.44ab11","name":"trigger","topic":"nodered/update-uservar","qos":"2","broker":"8bc033be.f9277","x":170,"y":320,"wires":[["5167d1a1.edf9e"]]},{"id":"b84d9ce3.f5c28","type":"inject","z":"17010ea5.44ab11","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":170,"y":280,"wires":[["5167d1a1.edf9e"]]},{"id":"f1960ba6.853bb8","type":"delay","z":"17010ea5.44ab11","name":"rateLim 2msg/s","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"2","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":560,"y":420,"wires":[["cc5613c.108d2f"]]},{"id":"cf7bf70d.710d38","type":"delay","z":"17010ea5.44ab11","name":"rateLim 1msg/s","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":560,"y":480,"wires":[["de6a25fe.da91c8"]]},{"id":"8bc033be.f9277","type":"mqtt-broker","z":"17010ea5.44ab11","broker":"localhost","port":"1883","clientid":"MQTTTRANSLATORNODEREDMQTTCLIENT","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
megamarco83
hi, i imported your flow, but didn't working.
i also subscribe to topic:
tasmota_blind
but if i move slide inside domoticz i didn't see nothing.
this is my uservar:
{"MQTT":{"devIdx" : 111,"inTopic" : "cmnd/tasmota_blind/shutterposition1","outTopic" : "stat/tasmota_blind/SHUTTER1","slope" : 1, "intercept" : 0,"limits" : "0,0","type" : "shutter"}topic = cmnd/tasmota_blind/shutterposition1
payload = 41
in this case the relay is triggered but can't see nothing: i try to change the topic
topic = tasmota_blind
payload = shutterposition1 41
and now i'm able to see the subscriber but in this case the relay is not trigered
of course when i import your rednote i changed with my mqtt adress and domoticIP:port
megamarco83
just to be sure, this my information about mqtt:salvacalatayud wrote: Friday 28 February 2020 18:07 Try this flow:
Change your user variable type to "shutter"Code: Select all
MQTT Host 192.168.0.105
MQTT Port 1883
MQTT User DVES_USER
MQTT Client DVES_328390
MQTT Topic tasmota_blind
MQTT Group Topic cmnd/tasmotas/
MQTT Full Topic cmnd/tasmota_blind/
MQTT Fallback Topic cmnd/DVES_328390_fb
megamarco83
additional information, i find inside raspberry in /var/log/daeomon.log
this:
it continue to increase, maybe is here the problem?
that's my "read user variable" inside node red:
and this is the json if i put that string inside web brawser:
using the MQTTlens i see that if i use:
1) as topic to publish = cmnd/tasmota_blind/shutterposition
payload = 33 (for example to put blind at 33%)
2) i'm subscrive to:
i receive: 33
i'm subscrive to:
i receive:
if i'm subscrive to topic:
domoticz/in}
domoticz/out
we should not interpretate this message to move or receive commands?
this:
Feb 29 17:43:26 raspberrypi Node-RED[265]: 29 Feb 17:43:26 - [error] [function:Format MQTT] TypeError: Cannot read property 'length' of undefined
Feb 29 17:43:26 raspberrypi Node-RED[265]: 29 Feb 17:43:26 - [error] [function:Convert to url] TypeError: Cannot read property 'length' of undefined
Feb 29 17:43:26 raspberrypi Node-RED[265]: 29 Feb 17:43:26 - [error] [function:Format MQTT] TypeError: Cannot read property 'length' of undefinedthat's my "read user variable" inside node red:
http://192.168.0.105:8085/json.htm?type=command¶m=getuservariablesCode: Select all
"result" : [
"LastUpdate" : "2019-12-19 08:45:12",
"Name" : "Calorifero_Bagno_PT_manuale",
"Type" : "0",
"Value" : "0",
"idx" : "3"
"LastUpdate" : "2020-01-18 19:24:35",
"Name" : "Calorifero_Bagno_Mansarda_manuale",
"Type" : "0",
"Value" : "0",
"idx" : "4"
"LastUpdate" : "2019-12-08 18:04:13",
"Name" : "myRooms",
"Type" : "2",
"Value" : "{\"heater\":48,\"cooler\":49,\"selector\":\"Season\",\"rooms\":[{\"room\":\"room_A\",\"s\":42,\"t\":39,\"v\":45},{\"room\":\"room_B\",\"s\":43,\"t\":40,\"v\":46},{\"room\":\"room_C\",\"s\":44,\"t\":41,\"v\":47}]}",
"idx" : "6"
"LastUpdate" : "2020-02-26 21:36:35",
"Name" : "blindControl",
"Type" : "2",
"Value" : "blind_esp32_1;Down;42",
"idx" : "7"
"LastUpdate" : "2019-09-13 00:23:37",
"Name" : "dimmer",
"Type" : "0",
"Value" : "99",
"idx" : "9"
"LastUpdate" : "2018-12-30 22:06:57",
"Name" : "led_dimmer",
"Type" : "0",
"Value" : "0",
"idx" : "10"
"LastUpdate" : "2019-09-13 00:28:59",
"Name" : "dimm",
"Type" : "0",
"Value" : "90",
"idx" : "11"
"LastUpdate" : "2020-02-29 17:30:11",
"Name" : "VCM_Mansarda_manuale",
"Type" : "0",
"Value" : "0",
"idx" : "12"
"LastUpdate" : "2020-02-04 11:45:11",
"Name" : "VCM_Piano_Terra_manuale",
"Type" : "0",
"Value" : "0",
"idx" : "13"
"LastUpdate" : "2020-02-29 17:47:35",
"Name" : "energyTrigger",
"Type" : "2",
"Value" : "This will trigger the dzVents script again",
"idx" : "14"
"Name" : "hotWaterThermostatControlled",
"Type" : "2",
"Value" : "false",
"idx" : "15"
"LastUpdate" : "2020-02-29 17:37:29",
"Name" : "hotWaterValvesESPBooted",
"Type" : "2",
"Value" : "ESP204_rebootMQTT",
"idx" : "21"
"Name" : "PDC_manuale",
"Type" : "0",
"Value" : "0",
"idx" : "22"
"LastUpdate" : "2020-02-28 01:00:46",
"Name" : "ValvolaTreVie_ESP205_REBOOT",
"Type" : "2",
"Value" : "Esp_TreVie_205_Rebooted",
"idx" : "24"
"LastUpdate" : "2020-02-27 20:21:51",
"Name" : "IFTTTvar",
"Type" : "2",
"Value" : "[{\"obj\":\"piantana camera\",\"act\":\"On\"}]",
"idx" : "25"
"LastUpdate" : "2020-02-11 20:40:33",
"Name" : "stoveControl",
"Type" : "0",
"Value" : "2",
"idx" : "26"
"LastUpdate" : "2020-02-29 17:18:45",
"Name" : "reboot_sonoff",
"Type" : "2",
"Value" : "sonoff_200_rebootMQTT",
"idx" : "27"
"LastUpdate" : "2020-02-29 17:38:49",
"Name" : "nodered",
"Type" : "2",
"Value" : "{\"MQTT\":{\"devIdx\" : 111,\"inTopic\" : \"stat/tasmota_blind/shutterposition\",\"outTopic\" : \"stat/tasmota_blind/shutterposition1\",\"slope\" : 1, \"intercept\" : 0,\"limits\" : \"0,0\",\"type\" : \"shutter\"}",
"idx" : "28"
"status" : "OK",
"title" : "GetUserVariables"
i receive: 33
i'm subscrive to:
i receive:
{"Shutter1":{"Position":33,"Direction":0},"Shutter2":{"Position":40,"Direction":0}}
{"POWER2":"OFF"}
{"Shutter1":{"Position":52,"Direction":-1},"Shutter2":{"Position":40,"Direction":0}}
{"ShutterPosition1":33}
{"POWER2":"ON"}domoticz/in
{"idx":154,"nvalue":2,"svalue":"51","Battery":100,"RSSI":6if i'm subscrive to topic:
domoticz/out
{ "Battery" : 255, "LevelNames" : "Off|Level1|Level2|Level3", "RSSI" : 12, "SelectorStyle" : "0", "description" : "", "dtype" : "Light/Switch", "id" : "000140BF", "idx" : 111, "name" : "tapp_tasmota", "nvalue" : 2, "stype" : "Selector Switch", "svalue1" : "81", "switchType" : "Blinds Percentage Inverted", "unit" : 1 }Who is online
