This might be very stupid question, but I can't figure out solution..
tapas wrote: ↑Wednesday 07 June 2017 10:03 Hi, is there a way to control On/off switch default status? I have an On/off switch that is connected to relay. Problem is simple: When relay is off, my button status is ON and vice versa. Because the default status of relay is OFF i'd like the switch also be OFF by default.
This might be very stupid question, but I can't figure out solution..Any help will be appreciated!
It will be a lot easier if that was an option in switch setup.GeoBonas wrote: ↑Friday 20 September 2019 19:21 You must read https://www.domoticz.com/wiki/GPIO
Active low relays.
