After upgrading from 11670 to 11724 dzVents doesn't work anymore. No logs, no actions. So dzVents scripts are ignored now.
Version: 4.11724
dzVents version: 3.0.0
Python Version 3.7.3 (default)
Raspbian 10 (buster)
i can see the domoticzData.lua and data folder is not updating anymore.
I already checked the comments from https://www.domoticz.com/forum/viewtopi ... 59&t=31404 but no solution. (cache clean, install to new domoticz folder, ...)
Any thoughts where to search/troubleshoot further?
dzVents not working after upgrade from 11670 to 11724. [Solved]
- waaren
Re: dzVents not working after upgrade from 11670 to 11724.
Assuming you already checked [setup][settings][other] tab to confirm EventSystem (Lua/Blockly/Scripts): and dzVents: are stil enabled
Can you share the first 30-40 of the log directly after starting domoticz ?
lepe
Yes i checked those settings. These worked normally fine but no results in the logs about dzVents. This is longer going one there are no logs anymore... but the dzVents worked fine with previous versions... (i had to take care about the logging... but time was the issue)waaren wrote: Tuesday 25 February 2020 21:53Assuming you already checked [setup][settings][other] tab to confirm EventSystem (Lua/Blockly/Scripts): and dzVents: are stil enabled
About the logs... Not much for the moment. (used x for masking)
i'm aware there was in the past some dzVents information... but that's gone.
2020-02-25 22:43:38.450 Sunrise: 07:34:00 SunSet: 18:14:00
2020-02-25 22:43:38.450 Day length: 10:39:00 Sun at south: 12:54:00
2020-02-25 22:43:38.450 Civil twilight start: 07:01:00 Civil twilight end: 18:47:00
2020-02-25 22:43:38.450 Nautical twilight start: 06:23:00 Nautical twilight end: 19:25:00
2020-02-25 22:43:38.450 Astronomical twilight start: 05:45:00 Astronomical twilight end: 20:03:00
2020-02-25 22:43:38.544 Active notification Subsystems: email, gcm, kodi, pushbullet (4/13)
2020-02-25 22:43:38.620 Starting shared server on: :::6144
2020-02-25 22:43:40.723 Kodi: (kodi master) Starting thread.
2020-02-25 22:43:40.823 Kodi: Starting I/O service thread.
2020-02-25 22:43:41.725 Kodi: (kodi master) Connected to 'x.x.x.x:9090'.
2020-02-25 22:43:42.127 MQTT: Topic: domoticz/in, Message: {"idx": xx, "nvalue": 0, "svalue": "0"}
2020-02-25 22:43:45.090 MQTT: Topic: domoticz/in, Message: {"idx": xx,"nvalue": 726}
2020-02-25 22:43:45.439 MQTT: Topic: domoticz/in, Message: {"idx": xx, "nvalue": 0, "svalue": "1"}
2020-02-25 22:43:46.259 (Xiaomi Gateway Central) Color Switch (Xiaomi RGB Gateway (x.x.x.x))
2020-02-25 22:43:46.315 (Xiaomi Gateway Central) Temp + Humidity + Baro (Xiaomi TempHumBaro)
2020-02-25 22:43:46.563 (Xiaomi Gateway Central) Temp + Humidity + Baro (x)
2020-02-25 22:43:46.614 (Zigbee2MQTT) Debug logging mask set to: PYTHON
2020-02-25 22:43:46.615 (Zigbee2MQTT) onStart called
2020-02-25 22:43:46.615 (Zigbee2MQTT) MqttClient::__init__
2020-02-25 22:43:46.615 (Zigbee2MQTT) MqttClient::open
2020-02-25 22:43:46.693 (Zigbee2MQTT) onConnect called
2020-02-25 22:43:46.694 (Zigbee2MQTT) Connected to MQTT Server: 127.0.0.1:1883
2020-02-25 22:43:46.694 (Zigbee2MQTT) MQTT CLIENT ID: 'Domoticz_158266xxxx_xxx'
2020-02-25 22:43:46.694 (AC) MELCloud connection OK
- waaren
I don't see this one confirming the Eventsystem is active.
2020-02-25 21:50:07.509 Status: EventSystem: reset all events...
lepe
Re: dzVents not working after upgrade from 11670 to 11724. [Solved]
yes, i've seen the issue now. Strange that i didn't noticed the entries of eventsystem earlier (This is because it's a 'status' line) It's the same issue off the missing logs...waaren wrote: Tuesday 25 February 2020 23:03 Can yo try to disable the event System and dzVents and apply the settings and after that enable them again ?
I changed the domoticz.sh file with the following information (found on this forum):
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal, status, error"I changed this to:
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"now i can see errors:
Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:644: attempt to concatenate a nil value (global 'moduleName')Strange thing is that dzVents works again now. (also with the 'defective' script enabled) Was timing an issue? just changing the loglevel cannot cause this? Maybe it's my environment specific.
Thanks for helping me in the right direction. (dzVents AND logging solved!)
