dzVents not working after upgrade from 11670 to 11724.  [Solved]
lepe
Post by lepe »
After upgrading from 11670 to 11724 dzVents doesn't work anymore. No logs, no actions. So dzVents scripts are ignored now.
Version: 4.11724
dzVents version: 3.0.0
Python Version 3.7.3 (default)
Raspbian 10 (buster)
i can see the domoticzData.lua and data folder is not updating anymore.
I already checked the comments from https://www.domoticz.com/forum/viewtopi ... 59&t=31404 but no solution. (cache clean, install to new domoticz folder, ...)
Any thoughts where to search/troubleshoot further?
Re: dzVents not working after upgrade from 11670 to 11724.
lepe wrote: Tuesday 25 February 2020 21:29 Any thoughts where to search/troubleshoot further?
Assuming you already checked [setup][settings][other] tab to confirm EventSystem (Lua/Blockly/Scripts): and dzVents: are stil enabled
Can you share the first 30-40 of the log directly after starting domoticz ?
lepe
Post by lepe »
waaren wrote: Tuesday 25 February 2020 21:53
Yes i checked those settings. These worked normally fine but no results in the logs about dzVents. This is longer going one there are no logs anymore... but the dzVents worked fine with previous versions... (i had to take care about the logging... but time was the issue)
About the logs... Not much for the moment. (used x for masking)
i'm aware there was in the past some dzVents information... but that's gone.
2020-02-25 22:43:38.450  Sunrise: 07:34:00 SunSet: 18:14:00
2020-02-25 22:43:38.450  Day length: 10:39:00 Sun at south: 12:54:00
2020-02-25 22:43:38.450  Civil twilight start: 07:01:00 Civil twilight end: 18:47:00
2020-02-25 22:43:38.450  Nautical twilight start: 06:23:00 Nautical twilight end: 19:25:00
2020-02-25 22:43:38.450  Astronomical twilight start: 05:45:00 Astronomical twilight end: 20:03:00
2020-02-25 22:43:38.544  Active notification Subsystems: email, gcm, kodi, pushbullet (4/13)
2020-02-25 22:43:38.620  Starting shared server on: :::6144
2020-02-25 22:43:40.723  Kodi: (kodi master) Starting thread.
2020-02-25 22:43:40.823  Kodi: Starting I/O service thread.
2020-02-25 22:43:41.725  Kodi: (kodi master) Connected to 'x.x.x.x:9090'.
2020-02-25 22:43:42.127  MQTT: Topic: domoticz/in, Message: {"idx": xx, "nvalue": 0, "svalue": "0"}
2020-02-25 22:43:45.090  MQTT: Topic: domoticz/in, Message: {"idx": xx,"nvalue": 726}
2020-02-25 22:43:45.439  MQTT: Topic: domoticz/in, Message: {"idx": xx, "nvalue": 0, "svalue": "1"}
2020-02-25 22:43:46.259  (Xiaomi Gateway Central) Color Switch (Xiaomi RGB Gateway (x.x.x.x))
2020-02-25 22:43:46.315  (Xiaomi Gateway Central) Temp + Humidity + Baro (Xiaomi TempHumBaro)
2020-02-25 22:43:46.563  (Xiaomi Gateway Central) Temp + Humidity + Baro (x)
2020-02-25 22:43:46.614  (Zigbee2MQTT) Debug logging mask set to: PYTHON
2020-02-25 22:43:46.615  (Zigbee2MQTT) onStart called
2020-02-25 22:43:46.615  (Zigbee2MQTT) MqttClient::__init__
2020-02-25 22:43:46.615  (Zigbee2MQTT) MqttClient::open
2020-02-25 22:43:46.693  (Zigbee2MQTT) onConnect called
2020-02-25 22:43:46.694  (Zigbee2MQTT) Connected to MQTT Server: 127.0.0.1:1883
2020-02-25 22:43:46.694  (Zigbee2MQTT) MQTT CLIENT ID: 'Domoticz_158266xxxx_xxx'
2020-02-25 22:43:46.694  (AC) MELCloud connection OK
thanks!
lepe wrote: Tuesday 25 February 2020 22:51
I don't see this one confirming the Eventsystem is active.
2020-02-25 21:50:07.509  Status: EventSystem: reset all events...
Can yo try to disable the event System and dzVents and apply the settings and after that enable them again ?
lepe
Re: dzVents not working after upgrade from 11670 to 11724.  [Solved]
Post by lepe »
waaren wrote: Tuesday 25 February 2020 23:03 Can yo try to disable the event System and dzVents and apply the settings and after that enable them again ?
yes, i've seen the issue now. Strange that i didn't noticed the entries of eventsystem earlier (This is because it's a 'status' line) It's the same issue off the missing logs...
I changed the domoticz.sh file with the following information (found on this forum):
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal, status, error"
but this didn't gave me the LOG results.
I changed this to:
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"
(just removed the spaces) and the LOGS are populated fine now.
now i can see errors:
Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:644: attempt to concatenate a nil value (global 'moduleName')
I disabled a dzVents script and error is gone. Strange thing is that i use that script. I'll have to check that later (not important)
Strange thing is that dzVents works again now. (also with the 'defective' script enabled) Was timing an issue? just changing the loglevel cannot cause this? Maybe it's my environment specific.
Thanks for helping me in the right direction. (dzVents AND logging solved!)
