PiKrellCam
- Domoticz version: V4.10199
PiKrellCam
Anyone uses a script in PikrellCam to make an action in Domoticz on starting motion capture
Or sending email with pictures ?
- Egregius
- Domoticz version: v2024.7
Re: PiKrellCam
I do.
Will try to post something this evening.
- Egregius
Re: PiKrellCam
I have this in pikrellcam.
In .pikrellcam/pikrellcam.conf:
/home/pi/region.py:
I have multiple motion zones set. I only want zone 2 and 3 to sent me a telegram with the picture.
The rest is handled in a php script, but this should get you starting.
Let me know if you need anything else. Been using pikrellcam for several years now, I'm pretty happy with it.
on_motion_begin /home/pi/region.py
on_motion_end /home/pi/on_motion_end.sh
#!/usr/bin/env python
import os,sys,socket,time
from subprocess import Popen
from shutil import copyfile
hold = 5000
holdoff = 180000
filename = '/run/pikrellcam/motion-events'
file = open('/run/pikrellcam/motion-events','r')
state = 'wait'
tsent0 = open('/temp/tsent0').read()
tsent1 = open('/temp/tsent1').read()
tsent2 = open('/temp/tsent2').read()
while 1:
where = file.tell()
line = file.readline()
if not line:
time.sleep(0.01)
file.seek(where)
continue
line = line.strip('\n')
if (line.find('<motion') == 0):
state = 'motion'
elif (line.find('</motion>') == 0):
state = 'wait'
elif (line.find('<end>') == 0):
sys.exit(1)
elif (state == 'motion'):
if (line.startswith(str(2))):
tnow = int(round(time.time() * 1000))
if (tnow >= int(tsent2) + holdoff and tnow > int(tsent1) + hold and tnow > int(tsent0) + hold):
r, x, y, dx, dy, mag, count = line.split()
if (int(mag) >= 2 and int(mag) <= 40 and int(count) >= 110 and int(count) <= 3000):
copyfile('/run/pikrellcam/mjpeg.jpg', ('/temp/snapshot-%s-%s.jpg' % (r,tnow)))
tsent2 = tnow
with open('/temp/tsent2', 'w') as myFile:
myFile.write('{}'.format(tsent2))
Popen('/usr/bin/php /home/pi/pikrellcam/www/telegram.php %s %s %s %s' % (('/temp/snapshot-%s-%s.jpg' % (r,tnow)),str(r),str(mag),str(count),),shell=True)
elif (line.startswith(str(3))):
if (tnow >= int(tsent0) + holdoff and tnow > int(tsent1) + hold and tnow > int(tsent2) + hold):
if (int(mag) >= 2 and int(mag) <= 40 and int(count) >= 130 and int(count) <= 3000):
tsent0 = tnow
Re: PiKrellCam
I only want to switch a virtual switch by movement in 1 zone
Sending a snapshot can be done by sending a notification
Many thanks for the fast response
- Egregius
Re: PiKrellCam
What do you want to achive by setting a switch on movement?
In my case that’s handled by the php script wich first checks several switches like home/away, gate open etc.
Re: PiKrellCam
can i have a copy of that script ?
- Egregius
Re: PiKrellCam
I'll try, but it seems to be a mess
So the python script launches this script if movement is detected:
On my domoticz server I have camera.php wich gives the status of some devices. For instance I don't want to receive images if my garage port is open. And when I'm a sleep the notification must be delivered silent.
That script in turn triggers the beep.php script wich plays a sound on a Xiaomi gateway.
<?php
error_reporting(E_ALL);ini_set("display_errors","on");
$disnot=false;
$time=time();
$data=file_get_contents('http://192.168.2.2/camera.php');
if($data)$d=unserialize($data);
else {
$d=array();
$d['Weg']='On';
$d['meldingen']='On';
$d['poortrf']='Off';
if(isset($_REQUEST['silent'])){
$disnot=$_REQUEST['silent'];
if($d['Weg']==1||$d['meldingen']=='Off')$disnot=true;
if(isset($_REQUEST['snapshot'])||isset($_REQUEST['deurbel'])){
shell_exec('cp /run/pikrellcam/mjpeg.jpg /temp/snapshot.jpg');
$file='/temp/snapshot.jpg';
if($d['poortrf']=='On'||$d['meldingen']=='Off'){unlink($file);exit;}
$jpg_image=imagecreatefromjpeg($file);
$white=imagecolorallocate($jpg_image,0,0,0);
$font='/home/pi/pikrellcam/www/arial.ttf';
if(isset($_REQUEST['deurbel']))imagettftext($jpg_image,48,0,15,60,0,$font,'DEURBEL');
imagejpeg($jpg_image,$file);
imagedestroy($jpg_image);
usleep(20000);
$url="https://api.telegram.org/bot111TELEGRAMBOTID111/sendPhoto?chat_id=CHATID1";
$post_fields=array('chat_id'=>CHATID1,'photo'=>new CURLFile(realpath($file)),'disable_notification'=>$disnot);
for($x=1;$x<=100;$x++){
$ch=curl_init();
curl_setopt($ch,CURLOPT_HTTPHEADER,array("Content-Type:multipart/form-data"));
curl_setopt($ch,CURLOPT_URL,$url);
curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch,CURLOPT_POSTFIELDS,$post_fields);
$result=json_decode(curl_exec($ch),true);
if($result['ok']===true){echo 'OK';break;}
sleep($x*3);
$url="https://api.telegram.org/bot111TELEGRAMBOTID111/sendPhoto?chat_id=CHATID2";
$post_fields=array('chat_id'=>CHATID2,'photo'=>new CURLFile(realpath($file)),'disable_notification'=>$disnot);
$ch=curl_init();
sleep($x*3);
$folder='/temp/stills/'.strftime("%Y/%m/%d",$time);
if(!file_exists($folder))mkdir($folder, 0777, true);
rename($file , $folder.'/'.str_replace('temp','',str_replace('.jpg','',$file)).'-'.strftime("%Y%m%d-%H%M%S",$time).'.jpg');
}elseif(isset($argv[1])){
$file=$argv[1];
$r=$argv[2];
$mag=$argv[3];
$count=$argv[4];
imagettftext($jpg_image,24,0,10,30,0,$font,"count=$count");
imagettftext($jpg_image,24,0,10,60,0,$font,"mag=$mag");
imagettftext($jpg_image,24,0,10,90,0,$font,"r=$r");
usleep(20000);
$ch=curl_init();
if($result['ok']===true){break;}
sleep($x*3);
$ch=curl_init();
sleep($x*3);
$timestamp=substr($file,-17);$timestamp=str_replace('.jpg','',$timestamp);$timestamp=$timestamp/1000;
$folder='/temp/stills/'.strftime("%Y/%m",$time);
rename($file , $folder.'/PiCam3-'.strftime("%Y-%m-%d_%H-%M-%S",$timestamp).'-'.$r.'.jpg');
<?php
* Pass2PHP
* php version 7.3.4-2
* @category Home_Automation
* @package Pass2PHP
* @author Guy Verschuere <[email protected]>
* @license GNU GPLv3
* @link https://egregius.be
require '/var/www/config.php';
$mysqli=new mysqli('localhost', $dbuser, $dbpass, $dbname);
$result = $mysqli->query("select n,i,s,UNIX_TIMESTAMP(t) as t,m from devices;") or trigger_error($mysqli->error." [$sql]");
while ($row = $result->fetch_array()) {
$d[$row['n']]['i'] = $row['i'];
$d[$row['n']]['s'] = $row['s'];
$d[$row['n']]['t'] = $row['t'];
$d[$row['n']]['m'] = $row['m'];
$data=array();
$data['Weg']=$d['Weg']['s'];
$data['meldingen']=$d['auto']['s'];
$data['poortrf']=$d['poortrf']['s'];
echo serialize($data);
shell_exec('curl -s "http://127.0.0.1/beep.php" > /dev/null 2>/dev/null &');
<?php
* Pass2PHP
* @package Pass2PHP
require 'secure/functions.php';
$d=fetchdata();
if ($d['Weg']['s']>0) {
die('Slapen of niet thuis');
if (past('Xlight')<60) {
die('To soon');
if (past('belknop')<60) {
die('To soon');
if ($d['poortrf']['s']=='On') {
die('Poort on');
if ($d['auto']['s']=='Off') {
die('Meldingen uitgeschakeld');
if ($d['lgtv']['s']=='On') {
shell_exec('python3 secure/lgtv.py -c send-message -a "Beweging oprit" 192.168.2.27');
if ($d['Xvol']['s']!=5) {
sl('Xvol', 5, basename(__FILE__).':'.__LINE__);
sl('Xbel', 20, basename(__FILE__).':'.__LINE__);
Re: PiKrellCam
I think my programming knowledge is a bit inadequate for this
- Egregius
Re: PiKrellCam
What do you want to achive with it?
- Egregius
Re: PiKrellCam
Out of my head, in other words: not tested...
Maybe this will do for your case:
Set a switch to on when there's motion, set it to off when motion stops.
Keep in mind that this will trigger the on status on every new movement detected. If you don't want that you'll have to look at my tsent0 stuff in my first python script in this topic.
import os,sys,socket,time,urllib2
state = 'wait'
while 1:
where = file.tell()
if not line:
time.sleep(0.01)
file.seek(where)
continue
state = 'motion'
state = 'wait'
urllib2.urlopen("http://192.168.2.2:8080/json.htm?type=command¶m=switchlight&idx=1383&switchcmd=Off")
sys.exit(1)
urllib2.urlopen("http://192.168.2.2:8080/json.htm?type=command¶m=switchlight&idx=1383&switchcmd=On")
Re: PiKrellCam
Wonderful, I will only be able to try this weekend because the pikrellcam is in a remote location
Re: PiKrellCam
I noticed that there was no subdirectory scripts in the pikrell directory and I created them
then I placed the script with the extension .py in this directory and made it executable
I also noticed that there is an asterisk in front of script.py, does this have any influence on the script ?
In the log window I do not see any message or reference to the script
- Egregius
Re: PiKrellCam
Where is that asterisk?
And has never been a mention about a scripts folder. The config on_motion_begin holds a absolute path to avoid issues with that.
Re: PiKrellCam
The asterix appears in the directory list in Midnight Comander
If I understand correctly I have to uncomment the on_motion_begin section
and put the script afterwards in the pikrellcam.conf
- Egregius
Re: PiKrellCam
Don’t know what that asterisk means, never heard of mc before. Will check that tomorrow.
Yes, add the complete path to the python script in pikrellcam.conf as mentioned in one of my first replies.
Re: PiKrellCam
Thank you very much for your help
Once you know it, it's easy, but you have to know where to start
I am starting to get more and more interested in the script language, thanks to you
