PiKrellCam
MarnixO
Domoticz version: V4.10199
PiKrellCam
Post by MarnixO »
Anyone uses a script in PikrellCam to make an action in Domoticz on starting motion capture
Or sending email with pictures ?
Egregius
Domoticz version: v2024.7
Re: PiKrellCam
Post by Egregius »
I do. :D
Will try to post something this evening.
Egregius
Re: PiKrellCam
Post by Egregius »
I have this in pikrellcam.
In .pikrellcam/pikrellcam.conf:
on_motion_begin /home/pi/region.py
on_motion_end /home/pi/on_motion_end.sh
/home/pi/region.py:
#!/usr/bin/env python
import os,sys,socket,time
from subprocess import Popen
from shutil import copyfile
hold = 5000
holdoff = 180000
filename = '/run/pikrellcam/motion-events'
file = open('/run/pikrellcam/motion-events','r')
state = 'wait'
tsent0 = open('/temp/tsent0').read()
tsent1 = open('/temp/tsent1').read()
tsent2 = open('/temp/tsent2').read()
while 1:
	where = file.tell()
	line = file.readline()
	if not line:
		time.sleep(0.01)
		file.seek(where)
		continue
	line = line.strip('\n')
	if (line.find('<motion') == 0):
		state = 'motion'
	elif (line.find('</motion>') == 0):
		state = 'wait'
	elif (line.find('<end>') == 0):
		sys.exit(1)
	elif (state == 'motion'):
		if (line.startswith(str(2))):
			tnow = int(round(time.time() * 1000))
			if (tnow >= int(tsent2) + holdoff and tnow > int(tsent1) + hold and tnow > int(tsent0) + hold):
				r, x, y, dx, dy, mag, count = line.split()
				if (int(mag) >= 2 and int(mag) <= 40 and int(count) >= 110 and int(count) <= 3000):
					copyfile('/run/pikrellcam/mjpeg.jpg', ('/temp/snapshot-%s-%s.jpg' % (r,tnow)))
					tsent2 = tnow
					with open('/temp/tsent2', 'w') as myFile:
						myFile.write('{}'.format(tsent2))
					Popen('/usr/bin/php /home/pi/pikrellcam/www/telegram.php %s %s %s %s' % (('/temp/snapshot-%s-%s.jpg' % (r,tnow)),str(r),str(mag),str(count),),shell=True)
		elif (line.startswith(str(3))):
			if (tnow >= int(tsent0) + holdoff and tnow > int(tsent1) + hold and tnow > int(tsent2) + hold):
				if (int(mag) >= 2 and int(mag) <= 40 and int(count) >= 130 and int(count) <= 3000):
					tsent0 = tnow
I have multiple motion zones set. I only want zone 2 and 3 to sent me a telegram with the picture.
The rest is handled in a php script, but this should get you starting.
Let me know if you need anything else. Been using pikrellcam for several years now, I'm pretty happy with it.
MarnixO
Re: PiKrellCam
Post by MarnixO »
I only want to switch a virtual switch by movement in 1 zone
Sending a snapshot can be done by sending a notification
Many thanks for the fast response
Egregius
Re: PiKrellCam
Post by Egregius »
What do you want to achive by setting a switch on movement?
In my case that’s handled by the php script wich first checks several switches like home/away, gate open etc.
MarnixO
Re: PiKrellCam
Post by MarnixO »
can i have a copy of that script ?
Egregius
Re: PiKrellCam
Post by Egregius »
I'll try, but it seems to be a mess :lol:
So the python script launches this script if movement is detected:
<?php
error_reporting(E_ALL);ini_set("display_errors","on");
$disnot=false;
$time=time();
$data=file_get_contents('http://192.168.2.2/camera.php');
if($data)$d=unserialize($data);
else {
	$d=array();
	$d['Weg']='On';
	$d['meldingen']='On';
	$d['poortrf']='Off';
if(isset($_REQUEST['silent'])){
	$disnot=$_REQUEST['silent'];
if($d['Weg']==1||$d['meldingen']=='Off')$disnot=true;
if(isset($_REQUEST['snapshot'])||isset($_REQUEST['deurbel'])){
	shell_exec('cp /run/pikrellcam/mjpeg.jpg /temp/snapshot.jpg');
	$file='/temp/snapshot.jpg';
	if($d['poortrf']=='On'||$d['meldingen']=='Off'){unlink($file);exit;}
	$jpg_image=imagecreatefromjpeg($file);
	$white=imagecolorallocate($jpg_image,0,0,0);
	$font='/home/pi/pikrellcam/www/arial.ttf';
	if(isset($_REQUEST['deurbel']))imagettftext($jpg_image,48,0,15,60,0,$font,'DEURBEL');
	imagejpeg($jpg_image,$file);
	imagedestroy($jpg_image);
	usleep(20000);
	$url="https://api.telegram.org/bot111TELEGRAMBOTID111/sendPhoto?chat_id=CHATID1";
	$post_fields=array('chat_id'=>CHATID1,'photo'=>new CURLFile(realpath($file)),'disable_notification'=>$disnot);
	for($x=1;$x<=100;$x++){
		$ch=curl_init();
		curl_setopt($ch,CURLOPT_HTTPHEADER,array("Content-Type:multipart/form-data"));
		curl_setopt($ch,CURLOPT_URL,$url);
		curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);
		curl_setopt($ch,CURLOPT_POSTFIELDS,$post_fields);
		$result=json_decode(curl_exec($ch),true);
		if($result['ok']===true){echo 'OK';break;}
		sleep($x*3);
	$url="https://api.telegram.org/bot111TELEGRAMBOTID111/sendPhoto?chat_id=CHATID2";
	$post_fields=array('chat_id'=>CHATID2,'photo'=>new CURLFile(realpath($file)),'disable_notification'=>$disnot);
		$ch=curl_init();
		sleep($x*3);
	$folder='/temp/stills/'.strftime("%Y/%m/%d",$time);
	if(!file_exists($folder))mkdir($folder, 0777, true);
	rename($file , $folder.'/'.str_replace('temp','',str_replace('.jpg','',$file)).'-'.strftime("%Y%m%d-%H%M%S",$time).'.jpg');
}elseif(isset($argv[1])){
	$file=$argv[1];
	$r=$argv[2];
	$mag=$argv[3];
	$count=$argv[4];
	imagettftext($jpg_image,24,0,10,30,0,$font,"count=$count");
	imagettftext($jpg_image,24,0,10,60,0,$font,"mag=$mag");
	imagettftext($jpg_image,24,0,10,90,0,$font,"r=$r");
	usleep(20000);
		$ch=curl_init();
		if($result['ok']===true){break;}
		sleep($x*3);
		$ch=curl_init();
		sleep($x*3);
	$timestamp=substr($file,-17);$timestamp=str_replace('.jpg','',$timestamp);$timestamp=$timestamp/1000;
	$folder='/temp/stills/'.strftime("%Y/%m",$time);
	rename($file , $folder.'/PiCam3-'.strftime("%Y-%m-%d_%H-%M-%S",$timestamp).'-'.$r.'.jpg');
On my domoticz server I have camera.php wich gives the status of some devices. For instance I don't want to receive images if my garage port is open. And when I'm a sleep the notification must be delivered silent.
<?php
 * Pass2PHP
 * php version 7.3.4-2
 * @category Home_Automation
 * @package  Pass2PHP
 * @author   Guy Verschuere <[email protected]>
 * @license  GNU GPLv3
 * @link     https://egregius.be
require '/var/www/config.php';
$mysqli=new mysqli('localhost', $dbuser, $dbpass, $dbname);
$result = $mysqli->query("select n,i,s,UNIX_TIMESTAMP(t) as t,m from devices;") or trigger_error($mysqli->error." [$sql]");
while ($row = $result->fetch_array()) {
    $d[$row['n']]['i'] = $row['i'];
    $d[$row['n']]['s'] = $row['s'];
    $d[$row['n']]['t'] = $row['t'];
    $d[$row['n']]['m'] = $row['m'];
$data=array();
$data['Weg']=$d['Weg']['s'];
$data['meldingen']=$d['auto']['s'];
$data['poortrf']=$d['poortrf']['s'];
echo serialize($data);
shell_exec('curl -s "http://127.0.0.1/beep.php" > /dev/null 2>/dev/null &');
That script in turn triggers the beep.php script wich plays a sound on a Xiaomi gateway.
<?php
 * Pass2PHP
 * @package  Pass2PHP
require 'secure/functions.php';
$d=fetchdata();
if ($d['Weg']['s']>0) {
    die('Slapen of niet thuis');
if (past('Xlight')<60) {
    die('To soon');
if (past('belknop')<60) {
    die('To soon');
if ($d['poortrf']['s']=='On') {
    die('Poort on');
if ($d['auto']['s']=='Off') {
    die('Meldingen uitgeschakeld');
if ($d['lgtv']['s']=='On') {
    shell_exec('python3 secure/lgtv.py -c send-message -a "Beweging oprit" 192.168.2.27');
if ($d['Xvol']['s']!=5) {
    sl('Xvol', 5, basename(__FILE__).':'.__LINE__);
sl('Xbel', 20, basename(__FILE__).':'.__LINE__);
MarnixO
Re: PiKrellCam
Post by MarnixO »
I think my programming knowledge is a bit inadequate for this
Egregius
Re: PiKrellCam
Post by Egregius »
What do you want to achive with it?
Egregius
Re: PiKrellCam
Post by Egregius »
Out of my head, in other words: not tested...
Maybe this will do for your case:
Set a switch to on when there's motion, set it to off when motion stops.
Keep in mind that this will trigger the on status on every new movement detected. If you don't want that you'll have to look at my tsent0 stuff in my first python script in this topic.
import os,sys,socket,time,urllib2
state = 'wait'
while 1:
	where = file.tell()
	if not line:
		time.sleep(0.01)
		file.seek(where)
		continue
		state = 'motion'
		state = 'wait'
		urllib2.urlopen("http://192.168.2.2:8080/json.htm?type=command&param=switchlight&idx=1383&switchcmd=Off")
		sys.exit(1)
		urllib2.urlopen("http://192.168.2.2:8080/json.htm?type=command&param=switchlight&idx=1383&switchcmd=On")
MarnixO
Re: PiKrellCam
Post by MarnixO »
Wonderful, I will only be able to try this weekend because the pikrellcam is in a remote location
MarnixO
Re: PiKrellCam
Post by MarnixO »
I noticed that there was no subdirectory scripts in the pikrell directory and I created them
then I placed the script with the extension .py in this directory and made it executable
I also noticed that there is an asterisk in front of script.py, does this have any influence on the script ?
In the log window I do not see any message or reference to the script
Egregius
Re: PiKrellCam
Post by Egregius »
Where is that asterisk?
And has never been a mention about a scripts folder. The config on_motion_begin holds a absolute path to avoid issues with that.
MarnixO
Re: PiKrellCam
Post by MarnixO »
The asterix appears in the directory list in Midnight Comander
If I understand correctly I have to uncomment the on_motion_begin section
and put the script afterwards in the pikrellcam.conf
Egregius
Re: PiKrellCam
Post by Egregius »
Don’t know what that asterisk means, never heard of mc before. Will check that tomorrow.
Yes, add the complete path to the python script in pikrellcam.conf as mentioned in one of my first replies.
MarnixO
Re: PiKrellCam
Post by MarnixO »
Thank you very much for your help
Once you know it, it's easy, but you have to know where to start
I am starting to get more and more interested in the script language, thanks to you
