Dashticz on the same Pi as Domoticz
mattx38
Post by mattx38 »
I'm very interested on using these beautiful Dashticz dashboards on my Domoticz brand new installation.
Is it possible to run it on the same Pi as Domoticz ?
Thank you for the advice.
Lokonli
Re: Dashticz on the same Pi as Domoticz
Post by Lokonli »
Yes, no problem. I would advise to try the autoinstall first.
Lokonli
Post by Lokonli »
https://dashticz.readthedocs.io/en/mast ... stall.html
mattx38
Post by mattx38 »
Ok fine, thank you for your quick answer
mattx38
Post by mattx38 »
As I'm new to Raspberry and "command lines", can someone tell me how to stop or uninstall Dashticz ? Thank you
Since I installed it, I saw the memory usage rised about 10% more.
I fear that it consumes too much ressources on the Pi.
Lokonli
Post by Lokonli »
As long as you don't start a browser on the PI itself Dashticz will not use a lot of resources: Dashticz almost completely runs on the client.
To uninstall Dashticz, after automatic install.
cd <dashticz>
make stop
cd ..
rm -rf <dashticz>
If you want to uninstall docker as well:
https://askubuntu.com/questions/935569/ ... all-docker
To uninstall Dashticz, after manual install:
cd <dashticz>
cd ..
rm -rf <dashticz>
You may want to uninstall Apache and PHP as well.
(If you don't use them, their resource usage is very very limited. Apache and/or PHP may be used by other applications as well)
mattx38
Post by mattx38 »
ok, thank you for your answer and your time.
I appreciate
