I'm very interested on using these beautiful Dashticz dashboards on my Domoticz brand new installation.
Is it possible to run it on the same Pi as Domoticz ?
Thank you for the advice.
Dashticz on the same Pi as Domoticz
Re: Dashticz on the same Pi as Domoticz
Yes, no problem. I would advise to try the autoinstall first.
Ok fine, thank you for your quick answer
As I'm new to Raspberry and "command lines", can someone tell me how to stop or uninstall Dashticz ? Thank you
Since I installed it, I saw the memory usage rised about 10% more.
I fear that it consumes too much ressources on the Pi.
As long as you don't start a browser on the PI itself Dashticz will not use a lot of resources: Dashticz almost completely runs on the client.
To uninstall Dashticz, after automatic install.
If you want to uninstall docker as well:
https://askubuntu.com/questions/935569/ ... all-docker
To uninstall Dashticz, after manual install:
You may want to uninstall Apache and PHP as well.
(If you don't use them, their resource usage is very very limited. Apache and/or PHP may be used by other applications as well)
cd <dashticz>
make stop
cd ..
rm -rf <dashticz>
cd <dashticz>
cd ..
rm -rf <dashticz>
ok, thank you for your answer and your time.
I appreciate
I appreciate
