Pairing Slave with Master
Duivleo
- Domoticz version: v4.10717
Hello all,
Since I changed from Domoticz v4.9700 to v4.10717, I have difficulties with setting-up switches.
I can set up ‘master’switches, with no problem. And at every master-switch, i can, via Edit, select slaves for each switch via the bottom part of the edit-screen. (The devices shown are all masters.)
However, when i create a (dummy or real) switch and select “slave” during set-up, i see an additional window below the two radio-buttons, from which to select the corresponding ‘master’. This is Always empty; no masters are shown! Hence, I can not create a real slave.
Anybody an idea how to resolve this?
Regards,
Leo
Regards,
Leo
jarmoboy
- Domoticz version: v2022.2
Re: Pairing Slave with Master
I have the same issue.
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
- FireWizard
Do you mean this:
If you click on the arrow, right on the field Sub/Slave Device,you should see all Masters.
I have seen sometimes in the past, that the drop down list was empty. A screen refresh (F5) mostly solved that problem.
Have you tried that?
Do you mean this:
alanlsmith
- Domoticz version: Latest β
It's when you are creating a new switch 'manually' and you select the slave radio button. Then from the drop down that appears titled 'Device:' there is nothing to select.
The screen you have shown is to select a slave device for a master (not too sure of the difference between the two approaches though).
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
- FireWizard
OK, yes I see it now.
The same here.
The same here.
microchip1974
- Domoticz version: 4.11774
Hello all, the same for me.
and i cannot also add a sub slave device from device manager. the windows pop ups but doesnt go away when finished. if i refresh the slave device is created but not working.
Pizigate Plugin version: 5.1.017
Firmware version: 0321
microchip1974
No one can help ?
- waaren
Seems like a bug. Suggest you post this as an issue on github
microchip1974
Still not working this basic function.... i cannot switch on and of a device with master/slave function.
jarmoboy
i made it with scenes because master/slave doesnt work at allmicrochip1974 wrote: Thursday 09 April 2020 19:02 Still not working this basic function.... i cannot switch on and of a device with master/slave function.
I've observed the same problem
I tried two different remotes:
- Aqara AQ2 button
- Philips Hue dimmer (4 buttons)
I tried the Debian packages, version 4.11020-2~bpo9+1 with domoticz-zigate-plugin package version 4.4.9~beta1-2~bpo9+1
I've now tried building a new package using the 2020.2 release from Github, the problem is the same. The package isn't published yet but it will be soon.
Summarizing the symptoms above, observed in my own testing with both versions of the package:
a) using the remote as a slave:
1) put the Zigate in permit join mode,
2) hold down the join button on the remote/dimmer,
3) go to the Setup->Devices page,
4) look for the new entry in the list, click the green Add Device arrow,
5) select the radio button for Sub/Slave device,
6) from the Device pulldown box, select a light bulb,
7) click the Add Device button, the button becomes disabled (can't click it again) but the popup stays open,
8) close the popup by pressing the Cancel button,
9) go to the Switches tab,
10) look under the Sub/Slave Devices heading, the button is there now but pressing the button does nothing,
11) check the logs, notice it does log something each time the button is pressed:
domoticz[64337]: (zigate0) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 1
domoticz[64337]: (zigate0) UpdateDevice - (zigate0 - lumi.remote.b1acn01_SwitchAQ2-0015xxxxxx-01) 1:00
b) if I go to the Scenes tab, add a Group and add the button in the group, it does work
Did anybody open a Github issue for this case and if so, can you please link to it?
- Aqara AQ2 button
Daniel Pocock, Debian Developer
https://danielpocock.com
