Same issue here: no config options for my TZ78.Fiury wrote: Thursday 05 April 2018 18:32 Thanks i solved it 2 hours ago.. , i found the same info like you posted .
TZ78 + TZ74 fixed , XML reworked, also with function config.
Thanks to all !!!
Info above is useful: I changed manufacturer_specific.xml and added tz78.xml. Result is that the name of the device is now showing, but still no configuration options (in Domoticz Hardware nor OpenZWave Control Panel).
I included/restarted/excluded in all possible orders, but no config. Any suggestions?
