dzVents and RGBW functions
mikkel75
Post by mikkel75 »
I have a dummy RGBW dimmer switch, which I try to set using dzVents.
Maybe I don't use it right, but when I eg. do
devices('McLighting').setHex(0, 0, 0)
I would expect the RGB value to be set to 0x000000.
However my log says:
Status: setcolbrightnessvalue: ID: 281, bri: 0, color: '{m: 1, RGB: ffffff, CWWW: 0000, CT: 0}'
I have also tried:
devices('McLighting').setRGB(0,0,0)
or
devices('McLightingl').setColor(0, 0, 0, 0, 0, 0, 3, 0)
But nothing works.
Any suggestions?
I'm trying to set the RGB to 000000 and the white to 100.
/M
My Domoticz is:
Version: 4.11657
Build Hash: 1d05ce754-modified
Compile Date: 2020-01-27 09:08:42
dzVents Version: 2.5.7
Re: dzVents and RGBW functions
mikkel75 wrote: Friday 31 January 2020 14:45 I'm trying to set the RGB to 000000 and the white to 100.
Some quick tests.
dzVents method       : setHex(0, 0, 0 )
dzVents generated URL: json.htm?type=command&param=setcolbrightnessvalue&brightness=0.0&hex=000000&iswhite=false
domoticz response    : Status: setcolbrightnessvalue: bri: 0, color: '{m: 1, RGB: ffffff, CWWW: 0000, CT: 0}'
dzVents method       : setColor(0, 0, 0 )
dzVents generated URL: json.htm?type=command&param=setcolbrightnessvalue&brightness=100&color={"m":3,"t":0,"cw":0,"ww":0,"r":0,"g":0,"b":0}
domoticz response    : Status: setcolbrightnessvalue: bri: 0, color: '{m: 3, RGB: ffffff, CWWW: 0000, CT: 0}'
dzVents method       : setRGB(0, 0, 0 )
dzVents generated URL: json.htm?param=setcolbrightnessvalue&type=command&hue=300&brightness=0&iswhite=true
domoticz response    : Status: setcolbrightnessvalue: bri: 0, color: '{m: 1, RGB: ff00ff, CWWW: 0000, CT: 0}'
dzVents method       : setHue(0, 0)
dzVents generated URL: json.htm?type=command&param=setcolbrightnessvalue&brightness=0&hue=0&iswhite=false
domoticz response    : Status: setcolbrightnessvalue: bri: 0, color: '{m: 3, RGB: ff0000, CWWW: 0000, CT: 0}'
dzVents method       : setColorBrightness(0, 0, 0, 100, 0, 0, 4, 0 )
dzVents generated URL: /json.htm?type=command&setcolbrightnessvalue&brightness=100&color={"m":4,"t":0,"cw":0,"ww":0,"r":0,"g":0,"b":0}
domoticz response    : Status: setcolbrightnessvalue: bri: 100, color: '{m: 4, RGB: 000000, CWWW: 0000, CT: 0}'
so I guess you are looking for
mikkel75
Post by mikkel75 »
@waaren: Thanks for your reply.
Do you see your tests as successful - ie. the output is as you expect given the input?
I'm sure I see why the setHex(0, 0, 0) function would result in RGB set to ffffff!?
That function also seems to use mode "ColorModeWhite = 1, // White. Valid fields: none", which also seems off, since it's RGB we want to change.
It's a bit the same story with the other functions...
Is it a bug or can someone please explain how this is though to make sens?
Thanks.
M
mikkel75 wrote: Monday 03 February 2020 8:42 @waaren: Thanks for your reply.
Yes.
The output (the bulb) worked as expected based on the commands I gave. I tested this with a Yeelight RGBWW bulb.
the setRGB(0, 0, 0) and the setHex(0, 0, 0) both show me the expected white color. How that is internally handled in domoticz or the Yeelight hardware is not something I am willing to investigate. Color theory is too complicated for me.
mikkel75
Post by mikkel75 »
Hi again,
Have you tried with a dummy RGBW switch?
Don't you agree that setHex(0,0,0) resulting in RGB=ffffff seems like a bug?
It's not right to expect 0x000000 to be the same as 0xffffff, 000000 is black and ffffff is white.
/m
mikkel75 wrote: Monday 03 February 2020 11:17 Have you tried with a dummy RGBW switch?
No with a real one
Yes, I don't agree
Yes, That is what I expected. But I am happy that my lights turns white when I send that command via dzVents. As stated in my previous post I am no color expert and I don't have the urge to become one :)
mikkel75
Post by mikkel75 »
Well it looks like the setHex() function is actually not setting RGB values dirtectly, but converting them to HSB
from dzVents sources:
function device.setHex(r,g,b)
			local _ , _ , brightness = domoticz.utils.rgbToHSB(r, g, b)
			local hex = string.format("%02x",r) .. string.format("%02x", g) .. string.format("%02x", b)
			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=command&param=setcolbrightnessvalue' ..
				'&idx=' .. device.id ..
				'&brightness=' .. brightness ..
				'&hex=' .. hex ..
				'&iswhite=false'
			return domoticz.openURL(url)
So I guess Domoticz handles RGB(W) in HSB format and that the conversion is where the error comes from...
I guess I'll have to find a work-around...
boum
Domoticz version: 4.10717
Post by boum »
mikkel75 wrote: Monday 03 February 2020 13:29 So I guess Domoticz handles RGB(W) in HSB format and that the conversion is where the error comes from...
Well, the RGB to HSV is only used to compute the brightness (value) of the color, the R, G and B components are passed directly (I just wonder why 3 format calls are made instead of local hex = string.format("%02x%02x%02x",r,g,b), but it works too)
The RGB value is changed to ffffff inside domoticz code along with a brightness of 0.
About a workaround, @waaren provided you with one above:
setColorBrightness(r, g, b, 100, 0, w, 4, 0 )
With all values supposed to be in 0..255 range.
mikkel75
Post by mikkel75 »
You are right :roll: Must have been looking at this before coffee....
Why would it be needed to fix RGB to 0xffffff if brightness is 0?
/M
