mikkel75 wrote: Friday 31 January 2020 14:45
I'm trying to set the RGB to 000000 and the white to 100.
Some quick tests.
dzVents method : setHex(0, 0, 0 )
dzVents generated URL: json.htm?type=command¶m=setcolbrightnessvalue&brightness=0.0&hex=000000&iswhite=false
domoticz response : Status: setcolbrightnessvalue: bri: 0, color: '{m: 1, RGB: ffffff, CWWW: 0000, CT: 0}'
dzVents method : setColor(0, 0, 0 )
dzVents generated URL: json.htm?type=command¶m=setcolbrightnessvalue&brightness=100&color={"m":3,"t":0,"cw":0,"ww":0,"r":0,"g":0,"b":0}
domoticz response : Status: setcolbrightnessvalue: bri: 0, color: '{m: 3, RGB: ffffff, CWWW: 0000, CT: 0}'
dzVents method : setRGB(0, 0, 0 )
dzVents generated URL: json.htm?param=setcolbrightnessvalue&type=command&hue=300&brightness=0&iswhite=true
domoticz response : Status: setcolbrightnessvalue: bri: 0, color: '{m: 1, RGB: ff00ff, CWWW: 0000, CT: 0}'
dzVents method : setHue(0, 0)
dzVents generated URL: json.htm?type=command¶m=setcolbrightnessvalue&brightness=0&hue=0&iswhite=false
domoticz response : Status: setcolbrightnessvalue: bri: 0, color: '{m: 3, RGB: ff0000, CWWW: 0000, CT: 0}'
dzVents method : setColorBrightness(0, 0, 0, 100, 0, 0, 4, 0 )
dzVents generated URL: /json.htm?type=command&setcolbrightnessvalue&brightness=100&color={"m":4,"t":0,"cw":0,"ww":0,"r":0,"g":0,"b":0}
domoticz response : Status: setcolbrightnessvalue: bri: 100, color: '{m: 4, RGB: 000000, CWWW: 0000, CT: 0}'
so I guess you are looking for
dzVents wiki
