ZigBee devices tested and confirmed to work with ConBee II stick
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Hi All,
I thought it to be a good idea to create a list of ZigBee devices that have been confirmed by users to work with the ConBee II stick.
The purpose of this thread is to create the list of supported devices that are not currently on the Phoscon list (found here: https://phoscon.de/en/conbee2/compatible and as pointed out by Thorgal789 here: https://github.com/dresden-elektronik/d ... ed-Devices).
This thread is not meant to be a discussion thread on individual devices. Please open a separate thread for this so others can help and this thread remains what it is supposed to be: a list of supported devices
There are loads of ZigBee devices available on the 'net and some work, others don't. I have been fortunate that most devices I have bought work so I thought I'd share them with you.
#1
Type of device: smoke sensor
Make: Heiman
Model number/name: HS1SA-N
Supported: Partly
Notes: Get's identified and found in Phoscon app. Not recognized as a smoke sensor but as a switch. Might get supported in new version of DeConz is proposed merge is accepted
#2
Type of device: dimmer (leading edge)
Make: Unknown
Model number/name: LXZB-02A
Supported: Fully
Notes: Works with dimmable LED bulbs
Sold under numerous names and model numbers. More info here: https://www.domoticz.com/forum/viewtopi ... 96#p234561
Currently sold here: https://www.aliexpress.com/item/4000261055890.html
#3
Type of device: dimmer (trailing edge/triac)
Make: YSRSAI
Model number/name: HLC821-Z
Supported: Fully
Sold under numerous names and model numbers. More info here: https://www.domoticz.com/forum/viewtopi ... 96#p234713
Currently sold here: https://www.aliexpress.com/item/10000015886428.html
Hope you're willing to share the devices you have found to work with the ConBee II stick! :mrgreen:
Greetz,
Sjonnie
Last edited by Sjonnie2017 on Saturday 01 February 2020 16:26, edited 1 time in total.
YouLess Energy meter
Thorgal789
Re: ZigBee devices tested and confirmed to work with ConBee II stick
Post by Thorgal789 »
There is already a sort of link for that https://github.com/dresden-elektronik/d ... ed-Devices you can edit the page when you want.
This list is not updated neither, but more in date than your first link.
Sjonnie2017
Agreed! But wouldn't it be nice to have a list on this forum where users can add devices not already on the official list and the list you are referring to? I can't find the devices I have listed on both lists. :roll:
EDIT: I have just tried to amend the list but that's not as simple as one would expect :|
Derik
Post by Derik »
Dear...
Is this working out f the box?
Or do i need some plugin?
A litle explane how o use?
Sjonnie2017
Derik wrote: Saturday 01 February 2020 16:37 Dear...
Working out of the box with the plugin from @thorgal789. That's the idea behind this thread: devices that work with the ConBee II stick out of the box (or with a little fiddling :P )
Derik
Post by Derik »
Sjonnie2017 wrote: Saturday 01 February 2020 16:44
Why not zigbee2mqtt?
Sjonnie2017
Derik wrote: Saturday 01 February 2020 16:50 Why not zigbee2mqtt?
Well... maybe because this thread is specifically meant to inform users which devices work with the ConBee II stick? ;)
Thorgal789
@Derik, you have some information about the conbee plugin here https://www.domoticz.com/forum/viewtopi ... 68&t=25631
And yes I m agree, the wiki list is not easy to edit, I think it's for that the list is outdated, I usualy use the issue search to find if a device is supported or not.
But I think more users will read the wiki than a domoticz post.
Sjonnie2017
Thorgal789 wrote: Saturday 01 February 2020 18:18 But I think more users will read the wiki than a domoticz post.
That might be true but I for one, happen to look at this forum first for supported devices. But hey, that's just me ;)
Users browsing this forum: Ahrefs [Bot] and 1 guest
