I thought it to be a good idea to create a list of ZigBee devices that have been confirmed by users to work with the ConBee II stick.
The purpose of this thread is to create the list of supported devices that are not currently on the Phoscon list (found here: https://phoscon.de/en/conbee2/compatible and as pointed out by Thorgal789 here: https://github.com/dresden-elektronik/d ... ed-Devices).
This thread is not meant to be a discussion thread on individual devices. Please open a separate thread for this so others can help and this thread remains what it is supposed to be: a list of supported devices
There are loads of ZigBee devices available on the 'net and some work, others don't. I have been fortunate that most devices I have bought work so I thought I'd share them with you.
#1
Type of device: smoke sensor
Make: Heiman
Model number/name: HS1SA-N
Supported: Partly
Notes: Get's identified and found in Phoscon app. Not recognized as a smoke sensor but as a switch. Might get supported in new version of DeConz is proposed merge is accepted
#2
Type of device: dimmer (leading edge)
Make: Unknown
Model number/name: LXZB-02A
Supported: Fully
Notes: Works with dimmable LED bulbs
Sold under numerous names and model numbers. More info here: https://www.domoticz.com/forum/viewtopi ... 96#p234561
Currently sold here: https://www.aliexpress.com/item/4000261055890.html
#3
Type of device: dimmer (trailing edge/triac)
Make: YSRSAI
Model number/name: HLC821-Z
Supported: Fully
Sold under numerous names and model numbers. More info here: https://www.domoticz.com/forum/viewtopi ... 96#p234713
Currently sold here: https://www.aliexpress.com/item/10000015886428.html
Hope you're willing to share the devices you have found to work with the ConBee II stick!
Greetz,
Sjonnie
