Light on at different dim level depending on daytime, with auto off  [SOLVED]
Re: Light on at different dim level depending on daytime, with auto off
botany wrote: Thursday 30 January 2020 15:39 getting a error
Try with a comma behind 'Koof Sensor'
I also edited my example that had the same error..
botany
Domoticz version: 4.10717
Post by botany »
2020-01-30 16:36:38.585 Status: dzVents: Error (2.4.19): .../domoticz/scripts/dzVents/generated_scripts/dzevents.lua:78: attempt to index global 'PIR' (a nil value)
if PIR.state ~= 'On' and override.state ~= 'Off' then
thats line 78
what im doing wrong.. :cry: :x
botany wrote: Thursday 30 January 2020 16:39 if PIR.state ~= 'On' and override.state ~= 'Off' then
thats line 78
Change this line to
if item.state ~= 'On' and override.state ~= 'Off' then
botany
Post by botany »
waaren wrote: Thursday 30 January 2020 23:39
thats line 78
Change this line to
Okay, wil try after work. Thanks Waaren
botany
Re: Light on at different dim level depending on daytime, with auto off  [SOLVED]
Post by botany »
this works now.
Thanks.
(but still not the same as i use on fibaro. thinking im going keep using two system, until something comes what i got)
nitpicker
Domoticz version: 2022.2
Post by nitpicker »
Sorry for bumping up and old post, but I use a version of this script (thanks!) but when this part of the script is running:
Light.dimTo(dimValue)
The light will turn on, and after that it will dim to the value that is set. Can this be changed? That it will turn on on the level that is set.
nitpicker wrote: Thursday 05 November 2020 12:54 When this part of the script is running: Light.dimTo(dimValue)
Please show your version and the log it produces. From you description I do not understand what is happening so please elaborate.
nitpicker
Post by nitpicker »
The script:
		devices = {234, 236}, -- Change out PIR
   execute = function(dz, devices)
        local Light = dz.devices('Overloop licht') -- Change out light
        local ms = dz.devices(234) -- MS Trap 1
        local ms2 = dz.devices(236) -- MS Overloop
        local luxSensor = dz.devices(192) -- MS6 Lux
        local dimTimeTable  = { --  [   'timeSlot'   ]  = dimValue
                                    ['at 00:01-07:00']  = 2,
                                    ['at 07:01-12:00']  = 20,
                                    ['at 12:01-19:45']  = 60,
                                    ['at 22:00-24:00']  = 2,
        if ((ms.state ~= 'On' and ms2.state ~= 'On' and dz.time.matchesRule('at 22:00-19:45')) or (luxSensor.lux > 20)) then
            Light.switchOff()
            dz.log(Light.name .. ' switched Off')
            for timeSlot, dimValue in pairs (dimTimeTable) do
               if dz.time.matchesRule(timeSlot) and (luxSensor.lux < 20) then
                    dz.log(Light.name .. ' switched On (dimlevel: ' .. dimValue .. ')')
                    return false
The log:
2020-11-05 13:22:44.110 Status: dzVents: Info: Handling events for: "MS trap 1", value: "On"
2020-11-05 13:22:44.111 Status: dzVents: Info: ------ Start internal script: Lamp overloop: Device: "MS trap 1 (deCONZ)", Index: 234
2020-11-05 13:22:44.115 Status: dzVents: Info: Overloop licht switched On (dimlevel: 60)
2020-11-05 13:22:44.116 Status: dzVents: Info: ------ Finished Lamp overloop
2020-11-05 13:22:44.117 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
The script switches the Hue lamp on and then it dims to the value I want.
But at night, the value is super small, but the light is first bright and then it dims to the low value. Can the light switch on with the low value without first shining bright?
nitpicker wrote: Thursday 05 November 2020 13:29 The script switches the Hue lamp on and then it dims to the value I want.
You could try this but I am not not sure if it solves your issue.
        local ms = dz.devices(234) -- Motion Sensor Trap 1
        local ms2 = dz.devices(236) -- Motion Sensor Overloop
            Light.dimTo(2)
            Light.switchOff().afterSec(1)
nitpicker
Post by nitpicker »
Good thinking, maybe the light bulb is indeed lightning up with the last value.
nitpicker
Post by nitpicker »
Because of the OR statement in the script it doesn't work as hoped. I have to find another solution... or maybe anyone else has an option?
