Light on at different dim level depending on daytime, with auto off  [SOLVED]
cogliostrio
Post by cogliostrio »
Thought Id share a script I made for turning on a light at different dim levels, depending on the time of day.
Hopefully it can be useful for others as well. Id also be interested to know if there are better ways to write something like this.
		devices = {'PIR'}, -- Change out PIR
   execute = function(domoticz, PIR)
   local Light = domoticz.devices('Light') -- Change out light
        if (PIR.state == 'On') and (domoticz.time.matchesRule('at 00:01-08:00')) then
            Light.dimTo(2)
            domoticz.log('DzVents: Light 2%, 00:00-08:00')
        elseif (PIR.state == 'On') and (domoticz.time.matchesRule('at 08:01-12:00')) then
            Light.dimTo(20)
            domoticz.log('DzVents: Light 20%, 08:00-12:00')
        elseif (PIR.state == 'On') and (domoticz.time.matchesRule('at 12:01-23:00')) then
            Light.dimTo(100)
            domoticz.log('DzVents: Light 100%, 12:00-23:00')
        elseif (PIR.state == 'On') and (domoticz.time.matchesRule('at 23:01-24:00')) then
            Light.dimTo(30)
            domoticz.log('DzVents: Light 30%, 23:00-24:00')
            Light.switchOff().afterMin(1)
            domoticz.log('DzVents: Light off')
Re: Light on at different dim level depending on daytime, with auto off
cogliostrio wrote: Friday 15 February 2019 16:50 Thought Id share a script I made for turning on a light at different dim levels, depending on the time of day.
Thx for sharing. As long as the script does where it is designed for, 'better' is subjective. The example below could be seen as easier to maintain and/or extend but it is still a matter of personal preference how you like your code to look like.
   execute = function(dz, PIR)
        local Light = dz.devices('Light') -- Change out light
        local dimTimeTable  = { --  [   'timeSlot'   ]  = dimValue
                                    ['at 00:01-08:00']  = 2,
                                    ['at 08:01-12:00']  = 20,
                                    ['at 12:01-23:00']  = 100,
                                    ['at 23:01-24:00']  = 30,
        if PIR.state ~= 'On' then
            dz.log(Light.name .. ' switched Off')
            for timeSlot, dimValue in pairs (dimTimeTable) do
               if dz.time.matchesRule(timeSlot) then
                    Light.dimTo(dimValue)
                    dz.log(Light.name .. ' switched On (dimlevel: ' .. dimValue .. ')')
                    return false
tezzlicious
Post by tezzlicious »
waaren wrote: Saturday 16 February 2019 7:58 Thx for sharing. As long as the script does where it is designed for, 'better' is subjective. The example below could be seen as easier to maintain and/or extend but it is still a matter of personal preference how you like your code to look like.
Hi Waaren. How would this script look like when you want to do this depending on lux level ranges from a lux device within time slots :?:
tezzlicious wrote: Sunday 17 February 2019 14:07 How would this script look like when you want to do this depending on lux level ranges from a lux device within time slots :?:
Can you give some examples on what mean ?
something like if between 08:00-12:00 and lux between 100-500 then dimLevel 30 ?
tezzlicious
waaren wrote: Sunday 17 February 2019 18:14
Yes, exactly that. I have groups, possible to dim them as a group? Or I can just make scenes and trigger them instead of dim level?
tezzlicious wrote: Sunday 17 February 2019 20:53 something like if between 08:00-12:00 and lux between 100-500 then dimLevel 30 ?
Dim as a group to a variable dimLevel is not natively possible in domoticz but with dzVents you can loop over devices in a group to do this
See attached
        local Lux           = dz.devices('Lux')
        local dimmerGroup   = dz.groups("dimGroup")
        local dimTimeTable  = { --  [   'timeSlot'   ]  = { [measuredLux]   = dimLevel
                                    ['at 00:01-08:00']  = {
        [200]       = 2,
        [300]       = 6,
        [500]       = 9,
                                    ['at 08:01-12:00']  = {
        [300]       = 20,
        [500]       = 40,
        [900]       = 60,
                                    ['at 12:01-23:00']  = {
        [800]       = 30,
        [1200]      = 60,
        [3000]      = 90,
                                    ['at 23:01-24:00']  = {
        [0]         = 15
        function getDimlevelBasedOnLux(t, measuredLux)
            local delta = 999999
            local keyDimLevel = 1
            for key, dimLevel in pairs(t) do
                if math.abs(measuredLux - key) < delta then
                    delta = math.abs(measuredLux - key)
                    keyDimLevel = key
            return t[keyDimLevel]
        function dimDevicesInGroup(groupName,dimValue)
            dz.groups(groupName).devices().forEach(function(device)
                device.cancelQueuedCommands()
                device.dimTo(dimValue)
                dz.log(device.name .. ' switched On (dimlevel: ' .. dimValue .. ')')
            end)
        function switchOffDevicesInGroup(groupName,delay)
                 device.switchOff().afterSec(delay)
                 dz.log(device.name .. ' will be switched Off after ' .. delay .. ' seconds.')
            end)
            switchOffDevicesInGroup(dimmerGroup.name,6)
            dz.log("Lights in " .. dimmerGroup.name .. ' will be switched Off after one minute')
            for timeSlot, luxLevels in pairs (dimTimeTable) do
                    local dimValue = getDimlevelBasedOnLux(luxLevels, Lux.lux )
                    dz.log('Devices in ' .. dimmerGroup.name .. ' will be switched On (dimlevel: ' .. dimValue .. '); Based on: timeslot ('.. timeSlot .. '), measured Lux (' .. Lux.lux ..')')
                    dimDevicesInGroup(dimmerGroup.name,dimValue)
                    return false
tezzlicious
waaren wrote: Sunday 17 February 2019 23:35 Dim as a group to a variable dimLevel is not natively possible in domoticz but with dzVents you can loop over devices in a group to do this
See attached
Thanks waaren. Managed to test it. It seems to work, but a few things I noticed:
  • Using the following time slots:
                                        ['at 00:01-15:00']  = {
        [2]       = 70,
        [3]       = 70,
        [4]       = 70,
        [5]       = 70,
        [6]       = 80,
        [7]       = 80,
        [8]       = 80,
        [9]       = 80,
        [10]       = 80,
        [12]       = 90,
        [15]       = 90,
    it still switches the lights on to 90% at a lux level of 73 at the moment.
  • I have a dummy on/off switch which groups 4 spots. The dummy switch is also in the group which I use in your script. When your script kicks in it switches this dummy switch to off. Where it should switch it to on.
  • How does your script handle the lux levels exactly? What if I want to match a range of lux level to the same dim level? Like the 0-5 lux range to dim level 70 and 6-10 to 80?
  • Is it possible to embed a threshold to switch off the lights above a certain lux level? Or does it work like that already? I didn't notice that maybe?
Thanks again. Already helped me a lot.
tezzlicious wrote: Monday 25 February 2019 14:42
        [2]       = 70,
        [3]       = 70,
        [4]       = 70,
        [5]       = 70,
        [6]       = 80,
        [7]       = 80,
        [8]       = 80,
        [9]       = 80,
        [10]       = 80,
        [12]       = 90,
        [15]       = 90,
Correct. The script picks the percentages from the lux level that is closest. If you want to a different percentage above a certain level you should add that combination. eg if you want a dimlevel percentage of 0 when lux >= 50 you should add something like
[49] = 90,
[50] = 0,
to the dimTimeTable
The script is not designed for an on/off switch. It is designed and tested for dimmable devices.
set dimTimeTable to
[5] = 70, -- lux 0-5 will set dim% to 70
[6] = 80, -- lux 6-10 will set dim% to 80
[10] = 80, --
[11] = othervalue, -- lux 11 and above wil set dim% to othervalue
set dimTimeTable to
[5] = 70,
[6] = 80,
[11] = 0,
tezzlicious
Thanks waaren. Working perfectly now.
jaaap
Post by jaaap »
Hi, this is exactly why I started using Domoticz in the first place :-) So good job!
However, I'm a huge n00b in this area and I need a little guidance, since I don't get the script to work. My question is: do I need to create something in order to make this work? For instance a dummy switch, groups, anything?
Or, mayby I don't understand the working of the script :-) As I understand it: lights are turned off, then when I switch them on, they flip on at a certain dim level, depending on the time. Correct?
Hope you can help!
jaaap wrote: Sunday 28 July 2019 23:04 Or, maybe I don't understand the working of the script :-) As I understand it: lights are turned off, then when I switch them on, they flip on at a certain dim level, depending on the time. Correct?
The script is triggered by a motion sensor and set a dimmable light to a certain dim level based on a combination of measured Lux and time of day. So to get it working, you need a Lux measuring device (real or virtual), - a motion sensor (can also be a switch) and a dimmable light.
jaaap
Post by jaaap »
What device do you use for the PIR? I mean, what hardware?
jaaap wrote: Sunday 11 August 2019 13:34 What device do you use for the PIR? I mean, what hardware?
I use three different types. I started with a KlikAan KlikUit (RFtrx433 /RFLink). Then I tried a Fibaro type (zwave) and now I use Xiaomi Mijia IR Intelligent Human Body Sensors.
They all do the job so that's why, for now, I stick to the last one (cheapest)
jaaap
Post by jaaap »
Great, then I'll order a couple of those, with the gateway of course :-)
Verstuurd vanaf mijn POCOPHONE F1 met Tapatalk
botany
Domoticz version: 4.10717
Post by botany »
is it possible to change dim level manual ?
and if there is movement. lights stay on same level as i put it manually?
because sometimes its nice to change the dim level depending on the situation .
botany wrote: Wednesday 29 January 2020 16:13 is it possible to change dim level manual ?
Yes that is possible. My approach would be to use a virtual dimmer as override that sets the dimlevel of the devices in the group to the same level as the virtual dimmer and use that same virtual dimmer as override if it is not 'Off' or has dimlevel 0.
Something like
return
    on =
        devices =
            'PIR',
            'virtualDimmer',
    logging =
        level = domoticz.LOG_DEBUG,  -- set to error when script is tested and OK
        marker = conditionalDimmer,
    execute = function(dz, item)
        local dimmerGroup   = dz.groups('dimGroup')
        local override = dz.devices('virtualDimmer')
        [200]       = 2,
        [300]       = 6,
        [500]       = 9,
        [300]       = 20,
        [500]       = 40,
        [900]       = 60,
        [800]       = 30,
        [1200]      = 60,
        [3000]      = 90,
        [0]         = 15
                    keyDimLevel = key
                dz.log(device.name .. ' switched On (dimlevel: ' .. dimValue .. ')',dz.LOG_DEBUG)
            end)
                 dz.log(device.name .. ' will be switched Off after ' .. delay .. ' seconds.',dz.LOG_DEBUG)
            end)
        if item.switchType == 'Dimmer' then
            if item.state ~= 'Off' then
                dimDevicesInGroup(dimmerGroup.name, item.level)
                dimDevicesInGroup(dimmerGroup.name, 0)
        elseif item.state ~= 'On' and override.state ~= 'Off' then
            switchOffDevicesInGroup(dimmerGroup.name,60)
            dz.log('Lights in ' .. dimmerGroup.name .. ' will be switched Off after one minute',dz.LOG_DEBUG)
        elseif override.state ~= 'Off' then
                    dz.log( 'Devices in ' .. dimmerGroup.name .. ' will be switched On (dimlevel: ' .. dimValue ..
                            '); Based on: timeslot ('.. timeSlot .. '), measured Lux (' .. Lux.lux ..')',dz.LOG_DEBUG)
                    return false
            dz.log('Groupdim level is overrided by ' .. override.name .. ' and fixed at level ' .. override.level ,dz.LOG_DEBUG)
(not tested)
botany
Post by botany »
thanks.
will try it out tonight.
I'm coming from Fibaro. trying to get out of the close system of them.
was only possible to use (expensive) zwave module/hardware.
i used a scene with fibaro made by Sankotronic.
very smart light- https://forum.fibaro.com/topic/28726-ve ... hts-scene/
now im looking for same scene like his.
so i can switch to Domoticz. this was the only scene is used with Fibaro. others where on and off and time based.
botany wrote: Thursday 30 January 2020 14:53 I'm coming from Fibaro. trying to get out of the close system of them.
Not only the system is closed; also the forum :) I am not allowed to view the topic without a user-id...
botany
Post by botany »
https://drive.google.com/open?id=1AtGnK ... KNUvYTC3Ct
i download it for ya... if you like to look at it.. :roll:
botany
Post by botany »
getting a error
2020-01-30 15:36:50.683 ...domoticz/scripts/dzVents/generated_scripts/dzevents3.lua:8: '}' expected (to close '{' at line 6) near ''virtualDimmer''
return
    on =
        devices =
            'Koof Sensor'
            'virtualDimmer',
    logging =
        local Lux           = dz.devices('KoofLux')
        local dimmerGroup   = dz.groups('Living room')
        [30]       = 2,
        [30]       = 6,
        [30]       = 9,
        [30]       = 20,
        [30]       = 40,
        [30]       = 60,
        [30]        = 30,
        [30]        = 60,
        [30]        = 90,
        [30]         = 15
                    keyDimLevel = key
            end)
            end)
        elseif PIR.state ~= 'On' and override.state ~= 'Off' then
                    return false
